Question about Delphi Roady XT XM Radio Receiver
Delphi Roady XT Quit Working
I have a Delphi Roady XT, it has been working fine. All it displays is "XM Satelite Radio". After a period of time it will display "Loading...." Any help? Thanks
  • 1 more comment
  • Anonymous Dec 26, 2007
    no sinal reception.... with road xt indoors should i jut returrn item?????
  • mrcooper68 Dec 29, 2007
    I am having a problem with the screen only having the XM Satellite Radio on the display and nothing else.
  • Anonymous Mar 27, 2009
    same problem, love the raody xt, this is actually my third unit. i wish i could find another receiver with as good of a transmitter. the auidovox i have now sucks. i dont what to change the radios in my vechicles. does anybody know of a reciever with a good fm transmitter?
This sounds like the problem I posted about the a/c adapter. The radio doesn't get enough power because the scr in the a/c adapter is failing.
Posted on May 14, 2007
Chances are it's not picking up the XM signal. First, contact XM to resend your setup. if that doesn't work check your antenna connections.
Posted on Apr 12, 2007
    New Friend:
Need help. Install to honda goldwing
Posted on May 04, 2013
  • Gail May 04, 2013
    How to get power to 5v connector port from motorcycle
2 Suggested Answers
SOURCE:
Slinteriors
  • 8617 Answers
SOURCE: Delphi Roady XT Quit Working
Here is a link where you can download a user manual for free that may give you the info that you need to reboot/ rset it. Let me know if you need any further assistance.
Posted on Jan 24, 2008
I have enjoyed my radio for about 2 years. For about two weeks I get the message"loading" on my radio. It does not happen all the time, but it seems like it is happening more frequently. It will...
Just a few weeks ago Sirius XM changed there channels. That might have been one problem. But it shouldn't be loading all the time. It might be losing the channels and have to reload the channels.
May 26, 2011 | Delphi Roady XT XM Radio Receiver
Jan 24, 2008 | Delphi Roady XT XM Radio Receiver
My Delphi Roady XT just stopped working. The only thing it does is show "XM Satellite Radio" on the screen. No lights come on and no buttons work. Is there anything I can do? There is no reset button...
Its probably time to just replace it. They are not worth repairing. If you contact XM customer service they may offer you one at a discount. They replaced one of mine for $20. I thought that was a fair deal.
Nov 20, 2009 | Delphi Roady XT XM Radio Receiver
Roady XT "Antenna" problem
one of 3 things, either your antenna is not insight of a skies view to receive the signal, or its wire is broken at the antenna, but if you remove the antenna connection frequently it pulls the center wire out of the connection on the end that fits into the radio when its plugged in push on the conductor at the back of the plug and see if this helps,alos if connection is loose take a safety pin and carefully between the outer plug case ans the ground fingers around the center pin push these in so you get a better ground, and lastly try another substitute antenna, I have re-soldered my connections numerous times to fix this issue, delphi doesn't make a very rugged product, good luck
Nov 17, 2009 | Delphi Roady XT XM Radio Receiver
XM radio overheats
The radio if it does not work in the car too. You can turn off the back light it may help it cool down press "menu" go to Display light hit select set it to 10 sec. press select again and try it
Feb 24, 2009 | Delphi Roady XT XM Radio Receiver
Roady XT Problem
Sounds like a software glitch, you should try
I need to get my Delphi XM Roady, Roady2, or RoadyXT repaired, where can I take it?
At this time, Delphi does not currently have an authorized repair center. If you are within your one-year warranty period, please contact the Delphi Warranty Center at 1.877.GO.DELPHI (1.877.463.3574). Hope this is helpful
Mar 11, 2008 | Delphi Roady XT XM Radio Receiver
Great signal, so sound
My XM Boombox is also white and it is a Belkin. The folks at Delphi told me the receiver in the boombox is screwed up which over time also screws up the Delphi receiver. Belkin is sending me a new boombox and Delphi is sending me a new Roady XT.
Mar 01, 2008 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT Radio won't turn on
You need to replace the transformer that plugs into the wall.
Dec 17, 2007 | Delphi Roady XT XM Radio Receiver
Roady XT periodic errors
The pins get easily damaged when switching from the car dock to the Belkin boom box. I have to constintly squeeze very ******* the top of the xt in order for it to make contact. Belkin will send you a plastic alignment fixture but it is too late. It still does the same thing.
Jun 18, 2007 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT XM Radio Receiver Logo
1,339 people viewed this question
Top Delphi Audio Players & Recorders Experts
xxxxxx xxx
Larry Tezekjian
Larry Tezekjian
Colin Stickland
Colin Stickland
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
