Question about Candy DQW150 Front Load Washer / Dryer
Programme 1 When the machine is switched onto the above programme 1, there is a loud humming noise and water leaks out from the front detergent dispenser. The machine only partly fills, and does not dry properly in that programme. That does not happen in other programme numbers. I have checked all hoses and there are no apparent leaks Both drier elements are ok, all overload swithches are ok and condenser seems to be unblocked and water flows through it.The dryer fan motor is running as is the drain pump motor. Is there a cold solenoid problem here or is it something else?
  • 46 Answers
Make sure both solenoids have a working supply (if two fitted) at rear.
Posted on Feb 08, 2008
Tricity Bendix AW1400W Loud noise when spinning
The turning tube's belt or bearing may have problem.
If you know how to tighting the drive belt, you may try.
If not, maintenance or service persone should to call.
May 28, 2017 | Tricity Bendix Washing Machines
Candy Futura CDF 325 beeping alarm
Is there a sequence to the beeps?
Jun 04, 2013 | Candy Dishwashers
Bosch SGS43C12 dishwasher fills with water as normal at start of programme, then you can hear a quiet 'click click' normally the cycle would start, but nothing happens. I can press reset and it drains the...
Where does the clicking sound seem to be coming from? Start the machine and when it's filled with water, try to identify where the clicking noise is emanating from. I suggest putting you ear next to the programme selector and start/stop switch and see if you can hear it more loudly/clearly.
Sounds like a faulty control module to me. Try the above and report back . . .
Oct 11, 2010 | Bosch 24 in. SGS43C12 Classixx...
Rotating programme unit stops mid cycle, all programmes
according to that i think the problem come from timer after you fix this problem pleas donot select your program during conncting electrical power thankyou
May 27, 2009 | Whirlpool AWM5145/2 Front Load Washer
BWD 129
pull dispenser out and clean out behind it.probably using to much detergent or wrong brand.you should get flash light and look deep inside.Is the machine front load or top?
Mar 05, 2009 | Washing Machines
I have a Zanussi WDA1055W washer/dryer. I never
the water should only be filling up to approc 2in above the drum bottom...........look inside when its filling..........if its filling to nearly the bottom of the door you either have a faulty pressure switch or grit/dirt in the internal filter.......as a result the machine will not spin if there is too much weight in the drum
Feb 23, 2009 | Zanussi F1045W Front Load Washer
Tricity Bendix AW1002W
my washing machine is making funny noise before it starts and today it will not start at all just the funny noise
Oct 18, 2008 | Tricity Bendix AW1000W Front Load Washer
Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Oct 07, 2007 | Washing Machines
Hotpoint WD440
On the power pcb panel, there is an eeprom. This gets corrupted and throws the machine into a frenzy. A replacement should include a new pcb and a new eeprom. Only from dealers unfortunately.
Aug 28, 2007 | Hotpoint Aquarius WD63 Front Load...
Candy DQW150 Front Load Washer / Dryer Logo
190 people viewed this question
Top Candy Washing Machines Experts
Marvin
Marvin
shaun taylor
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
