Question about Packard Bell iMedia SL 9553 (P660401806) PC Desktop
No singn light or sound
My pc was just working ,i switched it off . the next day i could`nt switch it on, i checked the power, it good(in an other systeem) please can you help me
    President:
  • 2,961 Answers
Did you check the power lead or the power supply in another pc. if you checked the power supply unit in another pc and it's fine, there is a faulty switch on your pc or faulty motherboard. Check that the 21 pin connector from the power supply unit to the motherboard is in properly as the psu will not work if disconnected from the board.
Posted on Oct 31, 2006
I have a dell inspiron 560 with 6 wires from the front panel power switch. which wire is yhe positive for each set? the color for each set are as follows power switch colors are 1) blue and brown 2)power...
Led's only work one way, so it does'nt matter what colours they are. The led's that they connect to will only work when the plug is the correct way. You wont do any harm if they are wrong, you just turn them round. Plug them in one way and if the led for the hard drive does'nt come on then it's the other way. Same with the power light. The power switch when pressed just makes a momentary connection across 2 pins, so it does'nt matter which way, it's just like touching the pins quickly with a piece of metal.
Feb 11, 2012 | Dell Inspiron 560 PC Desktop
I have a 1990 ck 1500. a couple of weeks ago I was headed out the driveway, it was a rainy day, I hit my headlights and my radio went out.I immediatly turned off my lights and my clock was re-set at...
On the components, you might try a separate ground. See if that helps? Check the battery negative connections. I've seen this even on newer vehicle where instrument cluster or whatever would dim a little when you turn on headlamps. I think it's a ground issue? Just my opinion.
On any component that doesn't work, check voltage and ground, you could try a redundant ground.
Mar 13, 2017 | Cars & Trucks
Brake Lights all of a sudden not working on my 1995 Tahoe. Checked fuses and lights. Neither burnt out.
The turn signal switch and the hazard switch are likly places to look. To checjk the fuses is'nt to take them out and look at them but to test to see if power will go though them, I use a test light ( a tool that looks like an ice pick with a wire coming out of the handle and the handle is clear with a light bulb inside). with the clip connected to a good ground as you touch the back sides of the fuses the light will light if it only lights on one side, the fuse is blown ( does'nt matter what it looks like ) a bad fuse can look good. the turn signal switch is involved as is the Hazard switch. If you pusth the hazard switch and the lights light good then you know that the lights and the sockets are good. You also know that the wires are good . With the key on the turn signals should work front and back ( thier different cicruits) If only working in the front the turn signal switch is bad provided the hazards worked all the way around. Does the high mount stop light work? It works off of it's own circuit on the brake light switch and if no lights work your back to the fuses only after you checked to see if the high mount bulbs are good. Your car is plenty old enough to have them be burnt out. If the high mount doesn't work with the bulbs known to be good and then you check with the test light to see if the power isd getting to the brake light switch. One wire is hot with the key off and another comes hot with the key on ( the cruze control switch in the brake light).
Aug 30, 2011 | 1995 Chevrolet C1500
1998 chevey malibu 6 cyl---none of the brake lights work. i have changed stop lamp fuse in dash fuse box and the long brake light switch in front of brake pedal. any suggestions what to try next
have you checked the bulbs?. my next step would be to test for power at the brake light switch and then step on the pedal and see if power flows through on to the other side of connector, if it does then we know theres power and switch is working good, my next move would be to step on the pedal and have someone watch the brake lights and then with pedal pushed turn 4way flasher on and off and see if the lights lite up for brakes and then wiggle the signal light lever and see if the lights come on, if the brake lights come on when any of these steps are done then you have a bad signal switch, if this does nothing then i would look under the dash and locate the harness wiring from signal switch to it junction, this will be a block of wires held together with a center bolt, wiggle wires while on the brake, i have seen the power wire for the brake lights burn inside connecter, and last would be to check the wiring going to lights inside the truck, good day, hope this helps.
Aug 27, 2011 | 1998 Chevrolet Malibu
Compaq presario desktop will not turn on
Check the power cables if it is working properly.
See if your AVR didn't blow a fuse or the switch is working and the led light are lighted or is powered on.
Test your pc's switch if it is still established contact and not unpluged from *********** board and is working properly.
Test your power supply by unpluging all plugs that is connected to your motherboard and try to short out, the green and black wire from pin 4 and 5 see picture below. Just put a small length wire at pin 4 and five and you'll be able to know if it is working just fine.
Connect it to your computer again if it is working properly.
Press the power switch.
If it still is not working, try to disassemble your processor, then press the power switch.
If it still did'nt work or still doesent turn on, then your motherboard is the broblem and needs to be replaced. Have a nice day friend, and hope this could help you analyze.
Aug 19, 2011 | Compaq Presario 5000 PC Desktop
I have a 2000 LHS, i was at a stop light the other day and got run into, from the back[just a scratch or two]. later i checked my brake lights and discovered they no longer worked[i had checked them about...
Have you checked for power at the sockets? How about power out of the turn signal switch? Is the third brake light also not working? If that bulb is good and there is no power at the socket than you have a bad break light switch. Check for power in and out of the switch with the brake pedal depressed. You can also unplug the brake light switch and jump it to confirm the lights work.
I can get you the wire colors if you need them.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
May 08, 2011 | 2000 Chrysler LHS
No rear brake lights, but 3rd one works. Fuses good, relays good, pedal area good, bulbs new, and new circuit board. What now
Im not sure the make ,year or model of your car but , the next thing to check as you already checked the fuses and brake light switch would be to check the wires going into the socket, the sockets go bad often so using a test light the next thing is to check the power and ground right before the socket, check the wires at the end before they enter the socket, if you have power and ground then the sockets are bad. you also know that the brake lights and the third light use diffrent power sorces, so just because the third light works doesnt mean the fuse is good for the other brake lights,good day,
Mar 29, 2011 | Chevrolet Silverado 1500 Cars & Trucks
My mini max NT 400 shows it is not getting power. Nothing on the display is lit. Not sure where to start, any help is appreciated. Thanks
Start at the begining, make sure you have power going to the heater and check to see if it is 110 or 220v. If you have power and it is correct the next stop is your transformer and how it it wired. You should have a diagram inside the main power junction box for the heater. If you have good power in to the transformer and 24v coming out it will be in your safty circut. Roll out switch and pressure switch are good places to start. The main power or transformer are probally where you should look.
May 09, 2010 | Pentair Minimax NT Heater
Brake lights don't work, fuse is good, middle brake light works
Very popular problem for this vehicle. Check for power at the brakelight switch. If you have power, depress the pedal and make sure the power is transfered to the next terminal. The switch is very affordabl and quite simple to exchange. Good luck, Dana
Aug 26, 2009 | 1998 Dodge Stratus
Packard Bell iMedia SL 9553 (P660401806) PC Desktop Logo
110 people viewed this question
Top Packard Bell Computers & Internet Experts
Steve Allison
Steve Allison
Alun Cox
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
