Question about Nortel I2002 IP Phone w/Text Keycaps, No P/S
Communication problems over IP phone
Hi, Off late we have been facing problems using our IP phones. It was working absolutely fone all these days. The setup is such that we have few branch office locations spread across different cities which are connected through a secure IPsec VPN tunnel over the internet. The problem we've been facing now is, whenever we call the branch office or they call the main office, we hear the ring tone and when we pickup either end of the people are unable to hear anything. Immediately if you disconnect and call again it works fine. This happens quite often for different different extensions at different different locations. We use static IP addressing. The Meridian option 11c our Epabx is setup in the main office. Any clues why this could happen??
  • 131 Answers
I have found many possible causes. Firmware Levels Outdated firmware in routers, VOIP phones, Firewalls, etc. can cause one-way audio. Ensure you have the latest updates for all the devices in the call path. Configuration Particularly if NAT is involved in the call path, configuration of the various devices may be a problem. Check to see if all devices are configured appropiately for your envioronment. Has anything changed, carriers harware, quos settings on router ? packet loss to these locations should be tested @ time it happens most, don't use it as gospel retur, ttl and re-xmits' do same.. Bob Finding the Cause The basic troubleshooting technique is to use a tool like Ethereal to capture SIP and RTP packets at each point in the call path where packets could be lost. Interperting the resulting captured packets requires some familarity with how networking and VOIP work. For example if the call path is: VOIP phone/device ---- firewall ---- sip proxy ---- firewall ---- asterisk Troubleshooting Steps Start capturing at point Make a VOIP call that will have one-way audio Analyze capture If problem found, fix and retest Otherwise move capture point to the next point (a, b, c, d, etc) and start over If the problem is intermittent, then a long term simultanous capture at multiple points can be used to attempt to capture a comple call with the problem. Most capture tools will let you capture only traffic from selected devices, so the volume of captured information can be kept to a reasonable size. If a back-to-back SIP user agent (for example a Session Border Controller ) is part of of the call path, then it may be necessary to capture all VOIP traffic at some points to ensure catching the wanted call since the IP addresses can change when traversing this device. Resources How To Debug and Troubleshoot VOIP
Posted on Oct 10, 2007
Network problem using airtel sim in Iphone 3g
My problem is quite similar... My iphone works in some parts of delhi and it shows no service for other parts of delhi... If i use idea sim on my iphone, it works absolutely fine... and if i use my airtel sim on any other phone then also things appear ok..
any ideas?
Jan 30, 2010 | Cell Phones
Tip
Losing quality for the 3211s fone
I and 2 of my colleagues were losing quality for this fone during use. I then downloaded the driver again from the Philips website and....voiala......sorted. All 3 fones now operational and great quality reception. Seems there is a problem with Vista and the CD issued with the fone.
Dave B
on Dec 30, 2008 | Philips VOIP3211S/05 IP Wireless Phone
Urgent
heyy guys... do this... even i faced lot of problems with ma fone.. solution is simple.. wat i got to hear is we cannot format this fone coz its of java base.. so, u need to simply restore ur fone's fact. settings... *#7780# type this simply and confirm ur security code wherein da default is 12345.. and there u go... ur nokia 6300 is all brand new again... jus try and see hope it works wid ur case too... and ur missin calc wud be found.. ;)
Jan 15, 2010 | Nokia 6300 Cellular Phone
Nokia 6500 slide. Device Not Recognized
If you go to Control Panel -> System -> HardWare and check USB controllers which shud give you a list of all USB ports. Below that you will find Wireless Communication Devices. In this you shud find all the modes your phone is installed as. Check if all these settings are present. Secondly, install PC Suite now that you have restores the system to an earlier date. Connect the phone and connect.
Jul 28, 2009 | Nokia 6500 Slide Cellular Phone
I dont get the dial tone when connected to the phone line. I connect a normal phone there is dial tone. Do I need to contact to my service provider to make work the IP phone?
I have been using Avaya for the past 6 months. I have faced similar problems. May be you can try connecting the phone in place of another IP phone and check if the problem persists. This can isolate the problem whether it is with the phone or the network.
For your reference I shall provide with the online manual.
http://support.avaya.com/elmodocs2/2410/16_300133_1a.pdf
And if you arn't able to find the solution in there, the probably you need to contact tech support.
Good luck !!!
Jun 30, 2009 | Avaya 2410 Corded Phone
Hi, We are using VOIP321 and have suddenly gotten an onscreen message (from the VOIP321 program) that "Access to Skype is Denied". Do you have any recommendation?
Hello there.
Just go into your Skype main window and use the tools, options, advanced then connections menu and permit Skype to use the fone. It should do this auromatically but..............
Dave B
Dec 06, 2008 | Philips VOIP3212 IP Wireless Phone
Data transfering problem
try to check your pc first maybe it has a virus..once the memory card or the fone is affected by virus your fone will not working properly
Nov 05, 2008 | Sony Ericsson K790i Cellular Phone
NOKIA N73 problem
try updating the fones firmware from nokia's website or else u can try *#7370# this the hard reset of the fone but dont forget to back up the data thats on ur fone like CONTACTS,THEMES THAT U INSTALLED ON FONE MEMORY,MESSAGES ETC by using PC suite thru cable.Hope this would solve ur problem
GOOD LUCK
Jun 11, 2008 | Nokia N73 Cellular Phone
Sony Ericssin Z550i Picture corrupted & MP3 failed to play.
There could be a problem with your memory card. Back up everything and reformat the card.
May 21, 2008 | Sony Ericsson Z550i Cellular Phone
Ethernet Disconnected message in POE 7941G IP Phones
the first problem will be to check or replace the cable that you use to connect the phone or check the jack that you use
Jul 12, 2007 | Cisco 7941G-GE IP Phone
Computers & Internet Logo
379 people viewed this question
Top Nortel Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
J John
Jax Planet
Jax Planet
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
