Question about Jensen MP5610 CD Player
Time change!! Ahhhhh! Ever since day light savings time, I can't figure out how to change the time on my clock! I remember, when I changed the time last, to keep the instructions handy because I knew I wouldn't be able to figue it out. Usually I'm pretty good at proper storage of manuals, etc. Please help me and let my mind be put to rest! Thank you, Heather
If you hold the D button in for 3 seconds then a menu appears. Press the button until the clock setting comes up. Now you use the dial button to set the time. Turn one direction to set the minute and turn the dial in the other direction to set the hour. Hope this helps!
Posted on Jan 28, 2007
A2638 manual to change time to day light saving time
Most cheap clock radios don't adjust to daylight savings time, you just have to change the clock twice a year.
Now if you'd give us the BRAND, MODEL, NUMBER, PLEASE!!!
Maybe we'd be able to help you more!
(WE'RE NOT THE PSYCHIC HOTLINE!!!)
Nov 07, 2016 | Audio Players & Recorders
The date displayed in 2006-how do I reset it?
to change the date and time you will press F2/F4 at same time, enter password 1 alpha alpha ( key located above 2 key) 66831 enter, then select the purple key to the far left, until you see clock, press the F key corresponding with clock update the date and time and press restart, this will change the time in terminal. remember to use military time.
also you will have to change for day light savings each time it changes.
Oct 20, 2014 | VeriFone Omni 3730 Aka Vx510 Credit Card...
Change day light savings setting on old t311t
It won't understand. It was mfg before the new change
Feb 28, 2010 | Timex T311T Clock Radio
Time change
(http://www.emersonradio.com/dst.htm) Copy this web link and paste it into the address bar of the browser. It will take you to the Emerson customer support web page. On this page is the update for setting the day light saving time function on your clock/radio. You may also have to replace the internal battery in the clock/radios to keep it working up to date. The battery usually has a three year life span. This may be shorten by power outages and leaving the radios unplugged for long periods of time. I hope this information helps you with your problem.
Apr 06, 2009 | Emerson Smartset Clock Radio
Model 1739 answering machine
Set the clock
You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
1. Press and hold CLOCK until the message window displays C and the default day is announced.
2. To change the day setting, press
MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
4. To change the hour setting, press
MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
6. To change the minute setting, press
MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
8. To change the year setting, press
MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
To check the clock, press CLOCK.
Jan 08, 2009 | AT&T 1717 Digital Answering Machine
Day Light Savings Time
If you tip your clock over you will see three little buttons under. They are each labeled. Press/hold the one that says "clock" until your display blinks. Use the forward/back buttons on face of clock to re-set time, then press the little "clock" button underneath it again to keep the time you just set. It probably will beep.
When Congress's ideal day comes, re-set it the same way. Sorry, but all this will do is keep you from having to look at the wrong time for a few weeks straight.
Oct 28, 2008 | Zenith Z166S Clock Radio
Day-Light-Savings Time
I have the same problem exactly and am in the Easter time zone too, so have not other solution.
Mar 12, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
How do I change the clock?
fROM EXTENSION 300: Press #TD + Enter time in 24-hour clock using hours (2 digits), minutes (2 digits) and seconds (2 digits) + HOLD + Enter date using month (2 digits), day (2 digits) and year (4 digits) + HOLD + SPK to exit. This will change the time on all the phones and voice mail.
Mar 26, 2007 | NEC 80573 Corded Phone
Daylight saving time issues
I picked this up from the Emerson Website Read below before going to the link. Try thi link: and poke around the website http://www.fox-international.com/emerson/ Important Notice About Daylight Saving Time (DST) and Emerson SmartSet® Clocks and Clock Radios Congress recently passed a new Energy Bill which includes a provision to extend Daylight Savings Time. At the beginning of 2007, Daylight Savings time will begin on the second Sunday in March and end on the first Sunday in November. Because of this change your SmartSet® Clock or Clock Radio will need to be updated. In order to set your unit we will need the following information from you: 1. Model Number You can find your model number on the back or bottom of your unit. (Click here for an example) 2. Serial Number You can find your serial number on the back or bottom of your unit. (Click here for an example) Based on this information we can identify which setting is necessary to adjust your unit for compliance with day light savings. There are three possible groups your SmartSet® Clock or Clock Radio could fall into: Group One changes the time zone to a previous time zone. Group Two adjusts for the spring and fall settings. Group Three is already set for 2007 daylight savings compliance. Group identification begins with your serial number. The first three to four digits of the serial number represent the year and month of manufacture. (If your serial number begins with 0607, that would indicate July 2006, 506 would indicate June 2005.) Models manufactured before January 2006 (serial number 506, 512, etc.) will follow Group One settings. Models manufactured between January 2006 and July 2006 (serial number 0601, 0603, etc.) will follow Group Two settings. Models manufactured after July 2006 (serial numbers beginning with 0608) are Group Three and do not require any changes. If you believe you have a Group One model, please click here. If you believe you have a Group Two model, please click here. If you cannot determine which Group your model may be in, please call us at 1-800-526-7521.
Mar 11, 2007 | Emerson SmartSet CKS1850 Clock Radio
Jensen MP5610 CD Player Logo
75 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
