Question about Durabrand DUR-1500 Portable DVD Player
Screen of portable dvd player not working
We have a Trutech dual portable dvd player. The main screen with the controls is not working. It is obviously playing the movie becaue the other screen hooks up to it and is working fine. Is there a way to fix this?
  • Cochis Mar 31, 2009
    I'm looking for the second screen to replace mine trutech LMD-5702RT, if you are interested email me @ enriquepajueloc@yahoo.com. thx
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Battery Charger for Trutech Portabel DVD player
As have been posted in a post of similar concern...
You can try calling Target Customer Service 1.800.440.0680 and inquire cost & availability of the charger for the TruTech PVS12701.
Additionally, you may want to contact the manufacturer direct.
ALCO Electronics, Inc.
8392 Six Forks Rd., Suite 104, Raleigh, NC 27615,
(800) 252-6123)
Should you need direct Customer Support, please try here.
Alternately, you can just look for an AC adapter/charger that has the following specs:
Input Voltage - your country's standard AC mains;
Output Voltage - 12VDC
Output Current - at least 1.5 Amp (the higher the better)
Connector - one that will fit and match the polarity of the TruTech PVS12701. (am guessing crown type center positive, pls confirm with the store. It may also help to bring along the unit when doing the purchase over the counter).
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 13, 2008
RLD1951
  • 22 Answers
SOURCE: Dual portable dvd player second screen not working
Sounds like it may be a bad linking cable or connection. Make sure you have cables inserted firmly and correctly. If possible, hook main unit to TV to be sure you are getting proper Video/Audio output.
Posted on Dec 29, 2008
  • 4 Answers
SOURCE: INeed av cable for Trutech 7? Dual-Screen Portable DVD Player
Okay, I just had to replace both the DC power and a/v cable for this Trutech DVD player and here is the solution. The a/v cable is a 4 pole 3.5mm cable, which I found here: http://www.techcables.com/6-ft-3-5mm-4-pole-mini-av-to-mini-av-camcorder-a-v-cable-p-36.html I went to Radio Shack and bought the coax style DC power plug ends which were size B and soldered new ends onto the old power cable, tip to tip, sleeve to sleeve: http://www.radioshack.com/product/index.jsp?productId=2102598
Posted on Dec 14, 2009
SOURCE: I need a replacement cord that connects the dual
You can order from www.shopaxion.com
Posted on Mar 23, 2010
SOURCE: can't find power cord
http://www.google.com/products?hl=en&rls=com.microsoft:en-us:IE-SearchBox&q=trutech+portable+dvd+player+power+supply&um=1&ie=UTF-8&ei=FdjSS_jyOJGy9gTM_8GsDw&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CB8QrQQwAg
you can get them here ranging from 9.66$up to 28.88 depending on which one you need
Posted on Apr 24, 2010
Testimonial: "fantistic advice, was exactly what I was looking for til 2am. Could never have found the item on my own. Thanks so much!"
Low/No contrast on main screen
There should be a setup menu for "video" where the brightness and contrast can be adjusted.
Feb 10, 2010 | TruTech LMD-5702RT Portable DVD Player
I have a trutech LMD5702RT portable duel screen dvd player the cable is broke that goes in 2nd screen we get sound but no picture. Can I buy just that cable
If its the red white and blue AV cable on both ends yes you can. If its a red white and blue AV on one end and a audio looking jack on the other end you can too. They sell all those cords at Radio shack or most electronic stores.
Jan 09, 2010 | TruTech LMD-5702RT Portable DVD Player
Blank screen no picture
connection between the dvd output and screen has broke link somewere. pull it apart and check it out
Jun 05, 2009 | Philips Magnavox DVD/VCR Dual Player
Won't play movie...only loading screen
The cause of this is a dirty pickup laser, a DVDcleaning disk might be of help.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
May 24, 2009 | TruTech PVS12701 Portable DVD Player
Trutech dual dvd portable - second monitor does not show picture
i think it's corroded,rusted ,i mean rusted.clean it or replace the terminal or plug.
May 08, 2009 | TruTech PVS12701 Portable DVD Player
All plugs are plugged in no power
have you cheak your socket power switch on wall if okey make sure your cable is okey if not replace machine power supply thanks
Apr 19, 2009 | TruTech PVS12701 Portable DVD Player
Lost the cord
i SAW THEM ON EBAY. also there are broken systems or parts or replacement.
Feb 25, 2009 | TruTech PVS12701 Portable DVD Player
Dec 23, 2008 | Durabrand PDV-705 Portable DVD Player
Change screen on portable dvd
you should have received a warranty with it take it back to the store you received it from and work things out
Jan 24, 2008 | TruTech PVS12701 Portable DVD Player
Durabrand DUR-1500 Portable DVD Player Logo
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
