Question about Panasonic CT-32D12D 32" TV
Help on value of surge R801 Panasonic CT27SX11E Please
Please help Value of surge R801 on Panasonic CT-27SX11E also a tip of what other compononents that can go bad the household power suden came in and off about 3 times and set went dead i tested the big cap it reeds 80 some volts. the surge resistor can't reed value though i get 17.6 k on my meter some tell me if it's right thanks in advance.
    President:
  • 3,130 Answers
Check this out. http://www.pasc.panasonic.com/Epartr/PartsList.asp
Posted on Oct 31, 2006
SOURCE:
Value of resistor R801 on sony model KV-1420A
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand TVs and other devices are given.
Sep 10, 2016 | Sony Televison & Video
My Panasonic CT-27SC14 tv won't turn on. worked fine last night. The cable box does but nothing happens with the tv..whether I use the remote or the power button. Unplugged it from the power source and...
hi,disconated from AC main. if you know bit of repairing tv and soldering? this what to look for main power board. 1 x dry joints 2 x leaky capacitors just remember when changing cap's make sure to use the 105' and same value.
Feb 04, 2010 | Panasonic CT-27SC14 27" TV
Aspect is wacky.
the capasitor of the vertical section had change value, most common value is 100 micro farad 50 volts
Feb 24, 2008 | Panasonic CT-36HL43 36" TV
Fried resistor, need value for R801
Brown/ Black/ Brown/ Gold It is a 100 ohm +/- 5%
Nov 08, 2007 | Sylvania 6413TG 13" TV
Picture fuzzy
hi dear
sound like to me it's screen voltage too hi check some cap on CRT base value 1mf 200v or above.at the same time u can check the cap on horrizantel 2.2mf 250/300/450vot some wear .have good luk
Nov 26, 2006 | Panasonic CT-32D12D 32" TV
CT-27SX11E Fixed but need advice on R value
I have already responded to your first question in relation to the Ohms and wattage,It worries me that maybe you can not see an answer to that question.The wattage rating should be the same or highier.
Nov 01, 2006 | Panasonic CT-32D12D 32" TV
i would not recomend replacing the 7w with the 5w, beacuse the resistor will allways run hot, hotter then the resistor should be. the resistor could possible melt anything that touches it & will not last as long as the original before it goes bad. find a 7w, if just for safty reasons.
CT-27SX11E Panasonic
The Ohms are ok but the wattage should have been the same or higher.A 1.5 with only 5 watts is not sufficient.
Oct 31, 2006 | Panasonic CT2722H TV
Panasonic CT-32D12D 32" TV Logo
189 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
