Question about Mitsubishi MS12TN Air Conditioner
Heater!!! Unit acts like its heating but there is no hot air. Fan turns on, heat symbol is showing on the remote, but no heat
  • 3 more comments
  • Anonymous Nov 11, 2007
    igniter turns on so dose fan but no flam
  • latif Nov 13, 2007
    Ihave MR slim Mitsibushi ceiliing mounted but there is no heat coming from the unit and sometimes sign like p8 and E0 flashes in the LCD.please help. abi
  • Anonymous Nov 17, 2007
    IT COOLS BUT WILL NOT HEAT
  • usmcs2007 Nov 21, 2007
    hi my name is fernando I work for a hotel in engineering department, my question or my problem is that the heat work sometimes but the next day is not blowing hot air only warm air what is the problem and we use this units with thermostast
  • Anonymous Dec 20, 2007
    on call for heat the fan won't start on auto the heat does not go pass the zone valve
I am experiencing a similar problem with my Mitsubishi slimline MSH09TW unit; about 4 years old; It use to give us very hot air now it is giving some what hot air; northeastern USA current temperature about 15F. You think frigid weather in Cranbury NJ could be responsible or some thing else is going on. Please help me if you have some time and knowledge about Mitsubishi heat pumps. Sincerely, DSS
Posted on Feb 07, 2007
Thinking of purchasing, I browsed the mitsubishi slim web-site, and noticed they tout the A/C features. TV advertisements lead us to believe the units operate as regular ductwork heat exchangers that include a heating unit built into the exchanger. That does not seem to be the case as they suggest hooking the unit to your existing gas or electric heating unit, and also hook you up to purchase heating units.
Posted on Jul 16, 2008
I have the same problem with my Amana PTH153B50AE . It runs with cool air come out but no heat. Can someone suggest anything wrong and what part I need to replace? It is very cold now in my room. Thank you very much.
Posted on Feb 19, 2007
Chances arre it is the high limit sensor L240F
Posted on Feb 15, 2007
I have the same problem. In heat mode air comes out at room temp, not heated. Unit is set to 72 degrees and room temp is 65. I have also tried setting the unit to 90 and still get not heat.
Posted on Jan 28, 2007
Room temperature
Posted on Jan 23, 2007
Compressor is running just cold air now
Posted on Jan 13, 2007
  • loren heinz Jan 13, 2007
    very cold
    warmed room up from 66 to 68 degrees then became cold
Heats for about 10 minutes then becomes cold
    electric heater heats for about 10 minutes then becomes cold
    its cold
Check your fuses in outdoor disconnect or circuit breaker sounds like compressor is not coming on may be bad run capacitor
Posted on Dec 31, 2006
  • 237 Answers
Is the air coming out just room temp or is it "cold" air vice hot air?
Posted on Nov 10, 2006
  • Marc Wilson
    Marc Wilson Dec 31, 2006
    Sure, give a poor rating when more info is needed.... jezz people, we need more descriptions sometimes to offer suggestions on where to look. I guess their username should be a clue not to offer help huh?
I have a neo plasma lg 7kw will not heat LG Air conditioner
Make sure the setting on the remote is correct . Sun symbol for heating. Make sure the filters are clean. On heating, the indoor unit will 1/2 open the flap but the fan shouldn't start. The outdoor unit should start and if working properly, will be blowing cold air. The indoor unit will open the flap fully and the indoor fan will start once it gets hot then you should feel warm air. If the outdoor unit is blowing warmish air, I would say the reversing valve coil has failed or one of the indoor temp or pipe sensors are faulty. If a sensor fails, a "CH" error should appear on the display.
Mar 30, 2016 | LG Heating & Cooling
Hiiiii..... I have samsung Thermostat AC, But i dont know how to use the warmer / heater for the same. I dont know about the model number but its one of the old AC written thermostat. Now help me out how...
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Jan 03, 2011 | Samsung AW1203B Air Conditioner
The problem using the lg 6711a is that i dont know that how to use its heater. Its an a/c+heating system, the remote just shows some symbols. please tell me that how can i use its heating system/how to...
Press on/off switch and then press mode button still cool symbol * and then set your temp 23 by pressing < or > And for heat press mode still symbol heat (symbol like sun), and set temp 29.
To switch off again press on/off button. Is it helpful?
Dec 17, 2010 | Heating & Cooling
How do I Turn the heat on ?
It's hard to answer that question because there are so many variables. First I would look at the thermostat and see what manual settings are available. If it's a non programable there should be a switch that goes from heat to cool,one position for fan on , one for off, and one for auto. Set the heat/cool switch to heat. the fan on ,off and auto to auto. Then turn thermostat control up so it's above surrounding temperature.This should cause the heater to come on. If that doesn't work you may have problems with heater or thermostat. If it a programable t-stat I will need more information,such as name brand,model,etc. Hope this helps. Thanks.
Nov 05, 2010 | Heating & Cooling
I have a problem with my Rinnai hot water heater giving me intermitant hot and cold. The water gets hot and I get in the shower. A few minutes later the hot water stops and I have to shut of the hot water...
We had the same problem - the hot water would only be hot for 3 -5 minutes and shut off, then we had to turn the water off, wait a few minutes, and do it again. VERY FRUSTRATING.
Solution: The Rinnai serviceman showed me the heat-exchanger blower/fan: It was clogged with dust and moths.
Another clue: Our Rinnai was extremely noisy when the heat came on. After the fan was cleaned and replaced, it is nearly silent.
If you are reasonably mechanically inclined:
TURN THE BREAKER / POWER OFF to the unit.
The blower-fan is located in the lower central area of the unit (at least on our unit). If you draw imaginary north-south, east-west lines through the center of the unit, the fan is in the lower-left quadrant. There is a spring clamp securing the black rubber accordian-like tube to the fan. There are two screws that secure the fan to the unit. there are two plugs that connect to the fan, as well as a third air-flow sensor that should be removed. then you can look at the fan unit, as well as the grill on the underside of the heat-exchanger that should be cleaned.
My thought was to go out and get a simple bug-screen, and place it over the air-input outlet vent going outside, but the repair guy said that although it may sound good, if that screen ever gets clogged, or reduces airflow to the Rinnai, then the unit will work harder, or even shut off, giving the same problem.
May 24, 2010 | Rinnai Webstone The isolator EXP tankless...
2002 kia sportage temp gauge runs hot while driving
Cheak to see that the coolant fan is operating with the A/C turned on. The fan has to work to help the engine stay cool and help the A/C. When you apply heat on the control it acts to reduce the coolant temp. You will have to get the coolant fan operation checked. This can be :fan motor, fan relay, temp sensor and computer. Good luck
Apr 26, 2009 | 2002 Kia Sportage
I dont know how to get it to heat
hi! there if you have ac running in your house try to see in the contrrol panel the heat logo or the word heater then turn in select heater or warm.then switch on adjust your thermosetting behind that cold and hot control,if you using remote configure on menu.have a warm day thank alot regards
Mar 23, 2009 | Heating & Cooling
I have a Ruud deluxe 80 plus heater. The unit is running, the pilot light is lit, still no heat.
repost with more specific . motor aka fan is running?stat is set to heat and max heat? how old? general progression is as follows. stat says its cold. signal is sent to gas valve to open. gas valve looks to see if pilot is lit via thermocouple. if pilot is lit then main valve opens and burner lights. shortly thereafter sufficient heat builds up to trip heat sensor that turns on fan and blows hot air into house.many times a tripped safty causes a default fan response. aka when you show up the fan is on 24 7 . that equals a failed safety and needs a pro tech to see why saftyfailed.
Oct 18, 2008 | Ruud Heating & Cooling
Mitsubishi MS12TN Air Conditioner Logo
547 people viewed this question
Top Mitsubishi Heating & Cooling Experts
Marvin
Marvin
MightyMikeJr
Vernon Taylor
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
