Question about Sylvania 6319CE 19 in. TV/VCR Combo
My Television won't turn on
A couple of days ago, I had some repairs done in my apartment. I did not think to cover the television - I was rushing off to work and when I came home saw dust was everwhere and the television no longer turns on. Should I throw it away?
    Sergeant:
  • 337 Answers
The dust had to be wayyyy excessive to any damage to the tv,it does not help but it wont hurt onless there was also water involved,if you have no indication of power (no lights ,no clicks)it might only be a fuse,if a drill or something similar was plugged in the same outlet as the tv that might have created the problem,if you are familiar with tv service or someone you know can safely remove the back and check the fuse is might be worth the effort.Just to make sure plug a lamp in the same outlet as the tv just to see if you have power coming out of it,the people working might have killed the circuit.Let Us know how it goes or if you need more information.
Posted on Oct 31, 2006
  • Omar Urrutia
    Omar Urrutia Oct 31, 2006
    your rating response is also important.
Dell W2607C LCD TV won't turn on
Check and replace its main power regulator board. It might be faulty. Normally there is no repair to these boards. Card base replacement should be done.
Feb 07, 2013 | Dell W2607C Television
I have had my samsung hl-r4266w for about 4 years now and no problems until a couple days ago. I heard a loud pop, the picture color got all messed up and there was a loud buzzing sound from the time you...
IT SOUNDS LIKE THE COLR WHEEL HAS FALLEN APART AND WILL HAVE TO BE REPLACED. I RECOMMEND CALLING AN AUTHORIZED TECHNICIAN TO DO THE REPAIR. YOU CAN CALL 1-800-SAMSUNG TO FIND THE CLOSEST SERVICE CENTER
Aug 26, 2011 | Samsung HL-R4266W 42" HDTV-Ready...
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
TV turns off by its self
U might have sleep timer on?Push the menu to see it have 30,60,90,120.If u don't ur tv have problems.Call for warenty repair,or return it were u purchase for an exchange.
Feb 07, 2010 | Insignia IS-LCDTV32 32 in. Television
RCA 50" - Convergence problem and now "Popping" + no picture
The high pitch popping that you are hearing is arcing in the high voltage circuit. I would not suggest a repair on a set that is this old. Convergence repair plus a high voltage problem could run around $500-$600. But it is your call on the repair, I can only advise.
I hope this helps you.
Thanks for using FixYa
asnowman
Sep 23, 2009 | RCA P50830BL 50" Rear Projection...
TV won't turn on
have a repairman check this the tech infor for repair is:
In rush Limiting Resistor location R8010 its comen for this model to open the resistor
its on the power supply module value is 6.8ohms at 7 watt standup cement Style resistor.
I think this will do it.
thanks,
daniel.
Jan 13, 2009 | Samsung HCL4715W 47" Rear Projection...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Sylvania 6319CE 19 in. TV/VCR Combo Logo
67 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
