Question about GE Profile JGBP79 Gas Kitchen Range
Oven doesn't work
The oven quit working. there is no code on the stove top - once the bake has been started, it sits there w/ no flame on the burner. i tried flipping the gas valve switch with no luck. i would appreciate any troubleshooting that you can provide. kj
  • 375 Answers
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Posted on Jul 15, 2010
Whirlpool gas oven will not heat
most likely you have a bad ignitor,pull out the racks and remove the floor to the stove,turn on the bake,if the ignitor glows but it takes more than 40 seconds for the flame to light you have a bad ignitor even though it glows and if it doesn't glow at all the ignitor is bad,also if the broil lights on top and the bake doesn't change out the ignitor.next time send the model number and i can look up your machine to help you better.
Nov 15, 2011 | Whirlpool Ovens
Top oven not heating up on BAKE, broiler gas and flames come on. Stove top burners work, Bottom oven heats for BAKE and BROIL.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 08, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
The stove does not heat up
Check the flame of the gas jet and make sure they are unobstructed and the flame is a steady blue. See if changing the temp affects the flame. It sounds liKe your temperature sensors might not be working. They are not that usually very expensive but trouble shoot the little things. If you have a knob control pull it and make sure that the inside is not broken just to be safe. The sensor is s usually at the left rear panel of the oven. Make sure it is intact. The other regulators would be under the floor of the oven where the gas jets are. good luck.
Nov 15, 2009 | Amana AGR5835QDS Gas Kitchen Range
Frigidaire gas oven not heating
replace the bake ignitor its getting weak
Jul 01, 2009 | Frigidaire FGB24T3A Gas Single Oven
My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Jan 15, 2009 | GE Profile JGSP44 Dual Fuel (Electric and...
Oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Dec 20, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Maytag Gemini gas top oven does not work.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}I had the same problem, same symptoms...
You probably need to replace the baking igniter, (Igniter,bake burner
Part Number: AP4102011 made by MAYTAG).
I tested the igniter function by (CAREFULLY) jerry rigging a bridge to wire the BAKE igniter to the BROILER controls. (Push/click plugs accessible by opening up the stove back) Testing the broiler controls this way the bake element remained cold. I then did the same test but connected the BROILER igniter to the BAKE controls and got a good glow. This indicates that the controls work but the Bake igniter's faulty!
You can access the bake igniter by removal of 2 screws at the front at the platform just inside the top oven. The broil and bake igniters appear to be identical but the push/click plugs are reversed at the back of the stove. (hence the CAREFUL jerry rigged wiring bridge.) The parts and wiring are pretty simple and visual once you get the covers off. Opening up the stove back is just a matter of removing several screws. UNPLUG the stove before you work. If you test as I described, make all connections while UNPLUGGED and then plug it in only for the brief test. Unplug again while disconnecting/reconnecting. Hope this helps.
Jul 17, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Oven not working
Gas Burner valves use a flame proving circuit to verify that a flame exist before releasing gas to the burners in the oven as a safety precaution, this sensor being exposed to temperature extremes, fails over time.
Aug 27, 2007 | Kitchen Ranges
GE Profile JGBP79 Gas Kitchen Range Logo
168 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
