Question about Kogi L7CH Monitor
Signal out of range
I hooked my k7 monitor to my computer but when I turned the computer on the screen shows that I have windows but the the screen goes balck with a message saying signal out of range can you please tell what this means out of range
  • 45 Answers
1: Signal out of range meas the monitor can't handle the input refresh rate. lcd and Tft monitors usually supports 60 and 75Hz refresh rates.
2: The Resolution you are using to view the desktop is too high, this number is depending on the size of the lcd monitor.
a 15" lcd usually runs with: 1024x768 with 60hz
a 17" lcd usually runs with: 1280x1024 with 60hz some of them supports 75hz.
a 19" lcd usually runs with 1600x1200 or higher.
I recommend reading the user manual if you have it, or checking the information on the manufacturer's website.
3: As a solution turn on your computer and after it passes the bios screen press F8 and select VGA mode.
This will enable 640x480 (standard vga) resolution and 60Hz refresh rate, after windows boots up you can change thease nmbers , and windows automatically asks for turning to 800x600 60Hz.
If you want to change the resolution go to: Right click on your desktop, select properties , select settings tab, and adjust the resolution on the bottom of the window.
Hope this helps, good luck.
Posted on Mar 20, 2009
After turning on the computer (Apple CUBE MacOS 9.1) the vision of the monitor is normal but after a few seconds a screen with a window countdown will start automatically and reads "signal ing"...
you may try this came from manual.
Power Management" "countdown 20 sec
INPUT SIGNAL OUT OF RANGE
This OSD may appear to inform you that the signal being sent to the display is not within its frequency range. In this case, you would need to check the resolution and refresh rate you have your video card set to, and adjust to be within the range of the display
Sep 09, 2011 | LG Flatron L1510S 15" LCD Monitor
I HAVE BEEN GIVEN A LT 456s MONITOR AND AM TRYING TO HOOK UP TO A GATEWAY COMPUTOR WITH WINDOWS XP- WHEN I TURN IT ON THE GATEWAY WINDOW SHOWS UP AND THE THE WINDOWS XP AFTER THAT IT IS BLANK UNTIL A NO...
I think you are experiencing something that happens a lot when you change monitors, possibly 'downsizing'? Your graphics settings on your actual PC were set too high for the new, smaller flat-screen, so what you'll have to do is hook it back up to another monitor, even an older CRT-style one, and then do the following steps before hooking it back up to your new 14" LCD:
  1. boot into Windows as usual, but on an older, perhaps larger monitor
  2. right-click on any empty area on your desktop, then left-click on 'Properties' at the bottom of the little pull-down menu that pops up
  3. when 'Display Properties' window comes up, click on the very last tab to the right, labelled ''Settings'
  4. find the 'Screen Resolution' slider bar about two-thirds the way down that window, and adjust the slider control to a more standardized, universal setting, like '800x600', or even '1024x786'. Either of those should work with your new LCD flatscreen.
  5. make sure you click 'OK' on that window, then 'Shut Down' Windows properly (using the Start button, and all that)
  6. disconnect your old monitor, and hook your new one back up. It should work!
This happens a lot. I build HTPCs, so it's even worse the more 'options' you have, believe me.
Hope this helps!
Mar 10, 2011 | Mag Innovision lt456s 14" Flat Panel LCD...
DELL E153FPf doesn't show the image
OSD Warning Messages A warning message may appear on the screen indicating that the monitor is out of sync range.
Cannot Display This Video Mode
This means that the monitor cannot synchronize with the signal that it is receiving from the computer. Either the signal is too high or too low for the monitor to use. See Specifications for the Horizontal and Vertical frequency ranges addressable by this monitor. Recommended mode is 1024x768 @ 60Hz.
Occasionally, no warning message appears, but the screen is blank. This could also indicate that the monitor is not synchronizing with the computer or the monitor is in a power save mode.
Jan 18, 2010 | Dell E153FPf 15" TFT LCD Flat Panel...
Monitor says: "Out of range"
This means that a video signal has been detected but it is beyond the range for display. As an example, if the monitor can only display 1024x768 and you send it a signal at 1280x1024, you will get that message. Try to downsize the display settings on your computer system until the monotor works.
Dan
Nov 06, 2009 | BenQ FP767 17" LCD Monitor
I have a problem with my monitor not coming back on after a power interruption or after a auto update and restart of the computer. I was having some small success with turning off computer and monitor and...
It could be a cable problem but more likely to be in the power saving settings on either the monitor setup or the computer. Remember when you plug in a different monitor windows knows about it and adjusts the settings to suit. It may be that windows is using the incorrect wakeup signal for that monitor. check you have the correct driver installed.
Oct 24, 2009 | Westinghouse L2046NV Monitor
I was adjusting picture on monitor and now picture completely messed up
  • Signal out of Range.
  • Out Of Scan Range
  • Horizontal frequency is out of range.
  • Cannot Display This Video Mode Out of Sync
This issue may occur if the signal from the video adapter exceeds the scan range of the monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor.
you should reinstall your video drivers in safe mode.
To restart in safe mode repeatedly press the F8 key during the computer startup. This will bring a menu where you'll be able to choose safe mode.
LCD monitor 60 - 75 Hz
Jan 25, 2008 | IBM E74 17" CRT Monitor
Monitor out of range
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
Pc connection doesnt work with computer
The TV you are hooking it to is not able to show the resolution you have the computer set to. Start by setting your computer resolution to 800 x 600. If that works than try 1024 x 768. If you go too high you will get that "out of range" message. The instruction book that came with your TV has a listing of the available resolutions the TV will show.
Aug 30, 2007 | Wanlida Group LTD-1510 15 in. TV/DVD Combo
Kogi L7CH Monitor Logo
336 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Computer Links
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
