Question about Toshiba 32A33 32" TV
No sound coming off tuner,
There is sound only when useing the rca inputs 1,2.
  • 1 more comment
  • john gollop Oct 31, 2006
    i miss it already.
    rca jacks were disconnected, tv was on tuner input, mute was off.
  • john gollop Nov 02, 2006
    Audio sap setting is on mono, still no sound .what next?
You've got either a bad jungle IC or an audio switching in a input switching IC. You'll need a schematic and a scope to trace that one out.
Posted on Nov 02, 2006
    President:
  • 3,130 Answers
In the audio option, check the audio SAP setting, make sure it is on off.
Posted on Oct 31, 2006
  • 24 Answers
Tongy, When you are trying to use the TV as a receiver, are the RCA jacks disconnected? Sometimes leaving a device connected even though it is not in use will cause the TV to look for the sound from those jacks. Try removing them and if the problem persist, go back through the audio menu settings through the remote control and make sure the source audio is the tuner instead of an external input. Hope this helps.
  • Rick Young
    Rick Young Nov 02, 2006
    Sounds like the problem is before the audio amplifier. The speaker works and external audio is being amplified so the aural portion of the tuner output has an issue. If you crank the volume wide open on the tuner, do you hear a buzz or anything?
    If you tune to a channel with no signal (snow) do you hear that?
    Are you connected to cable TV? Try disconnecting the set and unplugging the power cord for awhile and then plug it back in and try it without the cable connected.
    It still appears to be a menu issue or component failure.
    rix20601
No picture or sound. Is this a tuner problem? any help, please?
A no picture and no sound problem could not be a tuner problem. To test if it is a tuner problem, there must be a sound and picture using the rca input at the back of tv. I would suggest to resolder tuning section not the tuner itself. Thanks for using Fixya.
Oct 14, 2013 | Mitsubishi CS-26201 TV
How do I connect my CD Player, Tape Deck and Tuner to the SU 300 Technics Amplifier
hi,
For connecting these to your amplifier you need 4 Stereo RCA Cable.
1.Connection for cd:
Take one of the RCA cable connect the one end (red/white) jack to the line out of your cd and connect the other end (red/white) to the CD input of Your amplifier.
2. Connecting the tunner:
Take one of the RCA cable and connect the one end (red/white) jack to the line output of you Tuner and connect the other end (red/white) to the TUNER input of your amplifier.
3. Connectiong the tape deck:
Now you have two RCA cable. Take one of the RCA cable and connect the one end (red/white) jacks to the PLAY out of the Tape deck and connect the other end (red/white) to the TAPE 1 play input of your amplifier.
Now connect the last RCA cable. Connect the one end (red/white) jack to the record input of the TAPE deck And connect the other end (red/white) to the TAPE 1 Record input of your amplifier.(this connection will help you to record to tape from cd or tuner. if you are not interested in recording then you can avoid this connection.)
Now you can select these three items from the frond plannel control switch of the amplifier.
ok
Jul 28, 2011 | NAD 218THX 2-Channel Amplifier
How do I connect a dvd player with surround sound?
This depends on how you have it hooked up. You're going to need a Tuner. A simple method is to connect only the Yellow RCA cable (or composite cables) to your T.V. Then connect Red and White RCA cables to the Tuner/Surround sound system you're using on which ever input you're comfortable with. I.E. CD/AUX/TAPE..etc. Change your tuner to that input, and you should get your surround sound through the speakers. Make sure you change the input on your T.V. to what ever video source you got the wires in. If your tuner allows you to hook up a video source to it, you can just hook it up to the tuner and run the DVD player off the tuner only. The first option helps avoid confusion if your tuner isn't set up for any other devices to play video through it.
Jun 24, 2011 | NEC 42VP4 42 in. EDTV-Ready Plasma...
How do I connect my Sansui 6010B VCR with an analog TV and a DTV tuner?
two ways of connecting VCR with Analog TV with DTV tuner.
DTV tuner (RF) output to VCR (RF) input,VCR (RF) output to analog TV (RF) input.
turn DTV tuner on (VCR should have a TV\VCR switch that makes signal coming from tuner BYPASS VHS right into TV) note:: change channel FROM tuner.You should be able to record by placing a blank tape and pressing RECORD.
2ND. DTV tuner, VCR, should have a RCA in\out connections...Audio & video.You need a RF\RCA bypass switch. It has a INput with RCA connections to a RF signal out that goes to the RF Input of analog TV
Jun 21, 2011 | Sansui VHF6010 VHS VCR
Got a 19" LG LCD
To convert a LCD Monitor into a TV
Instructions
    • 1
      Compare internal and external TV tuners that are designed for use with computers. See if the tuner supports HD, DVI, component video, S-video, stereo, surround sound or other features you might like to use. Ensure that any internal devices will work with the expansion slots in your computer.
    • 2
      Purchase a regular TV tuner if your monitor has S-video, coaxial or RCA inputs. These can be seen at the back of the monitor. S-video should be clearly marked; coaxial is a large round port, and RCA inputs are typically smaller and brightly colored. If your monitor does not have these inputs, purchase a special TV tuner designed just for computer monitors. If you would like to use the tuner with your computer and monitor, choose an internal TV tuner. If you're using your computer monitor as a television on its own, select a stand-alone external tuner. Install the internal TV in your computer, if applicable.
    • 3
      Connect the TV tuner to the monitor with the proper cable. Select S-video as the connection option if both your tuner and monitor support it. Choose RCA component video as your next option. Use coaxial only if your monitor and tuner do not have the aforementioned connections. If your monitor has none of these connections, use a standard VGA cable to connect the tuner and monitor.
    • 4
      Connect the tuner's audio outputs to your monitor's speakers. If your monitor has no speakers directly attached, connect external speakers to the TV tuner. This can usually be achieved using regular audio or RCA cable.
    • 5
      Install an HD antenna high on a wall if you will be picking up free over-the-air television signals with your monitor. If you will be using satellite or cable TV with your monitor, simply plug the satellite or cable set top box into the tuner using RCA or coaxial cables. Then connect the tuner directly to the monitor.
    • 6
      Set your tuner to the channel you use to pick up television stations. If you receive free over-the-air television, this channel will be 3 or 4. If you have satellite or cable TV, this station is determined by your television service provider. Check the documentation that came with your system to determine which channel to set the tuner on. You will probably need to change channels using the satellite or cable box rather than the TV tuner.
May 09, 2011 | Televison & Video
What are the classification of simple machune
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
GoodLuck
Feb 02, 2011 | Sanyo 42 in. LCD TV
How do I use my front RCA audio/video input ports on my gatewayLX6200-01?
Sounds like it came with a TV Tuner. The PC should have come with software pre-installed on it. If not, find out who made the TV Tuner and they usually offer paid (or free) software for their TV Tuners.
Apr 03, 2010 | Gateway LX6200-01 Phenom X4 9500 8GB DDR2...
I have a Pioneer SG-540 stereo Graphic Equalizer that only works in the right channel, but more importantly puts out a large amount of excess humming moise and other unwanted sounds when the controls are...
I use the sg 540 equalizer for cd and tuner. (I have two of them) I also use the sa 940 to power my sound. On the tuner input of the amp, i used standerd rca cables and connected it to the output of the equalizer. then i connected rca cables from the input of the equalizer to the output of the tuner. this only works when the top equalizer button is pushed on. hope it works for you.
Jul 18, 2008 | Audio Players & Recorders
Sound
Three (3) possible ways:
1. use the audio out of the TV (if available) which would normally be red/white RCA and connect to any of the free INputs of your DVD surround sound system;
2. remove the cable INput of your TV and feed it to a tuner such as those in a VCR or any other device (some DVDs have TV tuners also). The VCR's Video OUTput would go to your TV while the Audio OUTput would go to any of the free INputs of your DVD surround sound system;
3. if your cable uses a box/decoder and has the yellow, red & white RCA, its a matter of splitting the red/white signal to feed both your TV and DVD surround sound system or simply remove them from the TV and feed them to the DVD surround sound system.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Televison & Video
Connect TV to cable
Hi, if I understand you right, your TV has only one (1) input method and that is an S-Video and you would like to view regular TV or cable channels. Two possible ways of getting to watch: 1) Get yourself a TV Tuner that will accept antenna or cable input and whose Video output will be fed in to your S-Video. Normally (but not always) output is a yellow RCA jack but of course some would have S-Video output also. Then you would need a cable to conect the output of the tuner to the input of your TV. Cables also can be S-Video to S-Video or RCA to S-Video. Of course, you would need another RCA pair (stereo) to feed the audio to your amp for the sound. 2) Another is to use the built-in TV tuner of an old VCR. Same procedures follow. Hope this works out for your. Please let me know how it turns out. Cheers.
Apr 12, 2007 | Samsung TXK2567 TV
Toshiba 32A33 32" TV Logo
56 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
