Tv power light comes on, and the little green light one the pwer supply comes on but no sound or video what should i replace to get this working and help would be appreciated
SOURCE: Have a Sanyo Plasma TV
Yep. The power supply in Sanyo Plasmas are generally prone to failures. It could be a failure in the panel not priming, but I doubt it. Turn the lights off in the room, then try to turn it on. If you see the screen faintly flash, the panel is priming, but it is not coming on. If the screen is lit, but is still "black," then it is a control or digital board. If it is totally black with no light at all, then it doesn't entirely rule out the first two, but makes a power supply failure more likely.
They usually have a lot of heat damage to them. If you have tried unplugging it for 15 minutes, then plugging it back in and it still doesn't work, the it is most likely a secondary in the power supply.
I hope this helps you...
SOURCE: Sanyo DP5747 Plasma TV no power
Found 1 of the 2 ac supply ( 8amp) fuses blown on the main pwr. supply. Replaced fuse and good so far. Looked over the ps for damaged components, none found. Checked current with ampmeter with tv on, showing 3amps. Cheers
SOURCE: Sanyo DP50747 Replaced Power Supply still not working
this issue is related to either the y sustainer and z sustainer boards, checking the fuses on the y/b will giving you a good indication, if they are open(bad) then you'll have a easy fix, if not, i would try replacing the y board first.
SOURCE: have a sanyo 50" plasma
This tv problems are related to powering up the tv and sustancening the tv power source to the tv itself.Replaced the tv sub power supply board where the a/c power cord plug into it.Try website like Ebay.com to buy a whole new refurbish sub power supply board for the replacement.
SOURCE: dp50747..had no power..replaced all capacitors..tv
try to change the contrast and colour settings on your tv. this could help you get the right colour settings on your screen
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
