Question about Toshiba 34HF83 34" TV
Ghosting and popping noises
The picture on our toshiba model 34HF83 (less than 3 years old),has ghosts or shadows, seems to be too dark, and makes a popping noise now and then. had the cable signal checked and it was fine.
  • 24 Answers
Slag, Has the cable signal been branched off to another TV (or more) from the same feed? Ghosting and shadows are usually the result of bad impedance matches on those lines. Try connecting the prime TV directly to the cable box (or cable jack) output and note if there is any improvement. Make sure the cable itself is of the RG-6 type (not RG-59) and has no sharp bends or kinks. The center pin of the cable should be clean without corrosion. The RF IN jack on the TV should be checked to make sure the threads for the connector are clean and the plug should be attached firmly but not too tight. These steps should help solve this at least assuming the cable signal is good. [Checking it shows the "level" coming off the pole, not necessarily the quality of that level.] Hope this helps.
Posted on Oct 31, 2006
Ghosting or a 3D image. A yellow and blue ghosting or shadowing image. Looks much like the top picture in the "picture ghosting image" entry. Is this a convergence problem?
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 09, 2011 | Toshiba 50HX70 50" Rear Projection...
Akai PT5598HDI Rear Screen Projection TV With Blue Shadowing
If the ghosting is like a 3D effect its your convergence ICs , but if its like a blue Halo around objects that usually means your CRT coolant has congealed and will need replacement. The blue is the first tube to congeal for some reason, followed by green. Red seems to be not quite as prone to this. It is a normal occurrence n sets about 4 years old to need the coolant changed.
Jan 25, 2008 | Televison & Video
My 2 year old Toshiba 42hl57 has developed what I can best describe as a ghosting problem, small white lettering appears with a clear shadow to the left of the lettering and some lettering seems to flare,...
LOOKS LIKE U HAVE RECEPTION PROBLEM WHERE U LIVE......IF U USE A INDOOR ANTENNA MOVE IT AROUND UNTIL U GET A CLEAR OR BETTER PICTURE OR BETTER CONNECT TO A OUTDOOR AERIAL///////
IF PROBLEM PERSIST GO IN CONTACT WITH TOSHIBA SERVICE CENTER
Nov 19, 2009 | Toshiba 42HL167 42 in. LCD Television
Hey, i have a samsung ln32b360, just 2 months old. worked beautifully when i got it, but recently it started ghosting a little in very specific situations. then it started ghosting a lot, but only in dark...
First,If there are double images or "ghost" images on the TV's picture, check the cable connections and make sure they are secure.Because the loose cable connection would be a chance for the ghost picture
But if the cable is perfect and if you still get ghost picture then here is the solution:
The LCD Panel is defective. The problem is the T-con board that is used to decode the signal from the main board to the LCD Panel. The only way to fix it is to replace the whole LCD Panel or T-con board if possible. The T-con will cost about 1/10 of the price as the LCD panel but except for a few new models, the T-con is not available. The LCD Panel is very expensive (usually from $600-700 for a 32" Sony).
The reason is that Sony makes the T-cons for each individual TV with different specs to match that of the LCD panel because of the low threshold for error between the LCD Panel and the T-con.
Its best to avil warranty and change the panel...
Please leave me comment, if you need furher assitance
Rnj VINODKUMAR
Oct 27, 2009 | Sony Bravia KDL-32ML130 32 in. LCD TV
Shadows/ghosting is present on screen at all times
What kind of shadowing are you seeing? Doe the picture look like a 3D movire (colors separated)? What is the make and model?
Please update this with the above info and I'll provide possible solutions.
Thanks,
Dan
Mar 20, 2009 | Televison & Video
Hp 4260 plasma tv
It's a common problem, but not the only one, it could also the the z-board
Feb 13, 2009 | HP PL4260N 42 in. Plasma HDTV
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Blue shadows/ghosts
how old is the tv ??
if this tv is older than 5 years it may need to refill the liquid on the proyection bulbs and/or could have contaminats in the fluid causing the ghost and to fix that you will need a professional person to do it
Apr 03, 2008 | Toshiba TP55H60 55" Rear Projection...
Ghost images
Sounds like a light engine issue to me. Is there anyway you can post a picture of the issue itself?
Mar 28, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Toshiba 34HF83 34" TV Logo
103 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
