Toshiba 32AF44 32" TV
Problem for Toshiba 32AF44 32" TV
Picture too dark
By Robyn on Oct 31, 2006
My tv pictures are really really dark on most tv shows but the commercials seem to be fine - we have tried using the menu to brighten the picture but nothing seem to work - this tv is less than 2 years old - any suggestions?
Same Problem
Dec 12, 2008
-   We just bought a TV today and it has the same problem.
-   Guest
Oct 11, 2008
-   the exact same problem and our tv is less than a year old-   lindagamet
Jan 22, 2008
-   I wasn't sure of the type television Robyn had but I have a 4 month old sanyo lcd 19" flat screen which is the same way, It is hooked up to cable and it has a very dark picture and at times the shadows make the picture disappear if I play the dvd player the picture is brighter but not by much the brightness adjustment makes little difference-   Guest
Jan 02, 2008
-   I have been having the exact same problem. I was curious whether or not the suggestion worked and the approximate cost of the repair. Thanks.-   littlegomez1
Best Solution
posted on Oct 31, 2006
Helpful)
rix20601
Rank: Master
Rating: 85%, 42 votes
You didn't say if you are receiving an off air picture or cable or satellite. The reason the commercials look good is because the local station (or source) transmits them "in the clear", that is, without any enhancements to the video signal. Network programing or local newscasts are sent through a device which inserts a reference signal in what's called the "vertical interval". You may have seen this as a series of flashing dots or pulses at the very top of the picture. There's a lot of information packed into the VITS (Vertcal Interval Test Signal). One of the lines contains a reference pulse for video which is set at a certain level. Your TV sees that level and automatically adjusts its circuitry accordingly. What I suspect is that your set is out of calibration and is pushing down the video signal because it is not "seeing" the level properly. A video alignment should correct this and can be done by a good repair facility. Hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Toshiba 32AF44 32" TV
Questions and Unsolved Problems for Toshiba 32AF44 32" TV
Do you recommend Toshiba 32AF44 32" TV?
Answer
Answer
Volume goes to zero will not turn off the only buttons that work are channell buttons
Answer
How do I get my Toshiba 14af41 to play dvd's without remote to put tv in video mode????
Answer
My Toshiba tv does not have a remote and now the power will not turn on. I have cable univeral... (More)
Answer
I have the toshiba model 32AF44 manufactured in 2005 AC120 V GOHZ 2.1A 106W Average power (I'm... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
in , CA
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
