Question about Vtech VT 2461 Cordless Phone
Handset stopped working properly
I was talking on the main handset earlier and then the phone got quiet like it was dead. I looked on the LCD screen and it showed up VTECH B451 like it does before it searches for the base. I noticed the message light is staying on and I never saw it come on before. I thpught it might be the battery pack and I switched the one from Handset 2 and it still does the same thing when I changed the battery. The other Handset works like it always does, just the main Handset one now only shows b451 on the screen and the message light at the top of the phone is on. I even tried to reset the phone by unplugging it, taking the battery out, then wait a few mins, then plug it back in and put the battery in, but Handset 1 still does the same thing. Anyone have any solutions for this? Why would the message light be on if I don't have voice mail through the phone company?
Mine is doing the same thing. I did hook the phone directly up to a power supply and all was well.
Posted on Aug 26, 2007
Handset on main machine goes quiet after a few seconds It is a new machine
Check the handset phone cord make sure its properly plugged in at both ends, if still not working, try replacing it with one from another phone to check if that is the problem.
Mar 24, 2015 | Office Equipment & Supplies
I have a Panasonic KX-TGA652 dual handset no answering machine. The problem I have is the 1st handset "the base set", doesn't seem to work properly, the 2nd handset works 100% fine. The problem is this,...
Id try the following in this order:
  1. Try swapping batteries with another set and see if the problem follows the battery
  2. Try re-registering the handset, they could of missed one at the factory. that is done by selecting menu->initial settings->register handset
If this doesn't work, then return for warranty/exchange. Mine seem to work great right out of the box.
the poodle guy!
Sep 29, 2010 | Panasonic Lands Phones
No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Apr 16, 2009 | Clarity C4230 Cordless Phone
Can't talk on both phone at same time. second on is always dead.
The DXI4286-2 is an Analog phone, it does not allow for both handset to be used at the same time. You can transfer a call from one handset to another, but cannot talk on both at the same time.
The following is from the user's manual for your phone:
Unavailable message is displayed
on the LCD screen of the
handset.
• Make sure the other handset is not already in use. Both handsets cannot be in talk mode at the
same time.
• Place the handset in the main base for at least 5 seconds to re-register to the main base.
• Make sure the handset is not too far from the main base when trying to use.
You might want to try one of the DECT or a Digital 2.4 or 5.8 GHz phones, they allow you to use multiple handsets at the same time.
Apr 04, 2009 | Uniden Cordless Phone
Handset for ATT 5.8 GHz Cordless Telephone Model 5870
i have at & t 5870 cordless phone it is no t working. handset is dead i change the battery but still not working .please give some advice.
Mar 16, 2008 | Lands Phones
Handset does not work
Your handset is no longer communicating with your base. Depending on your model, the solutions can be a couple of different options. If I could view pdf files on this computer I would look it up for you. But here is the link to the manual on Unidens website- http://www.uniden.com/pdf/TRU8865-2om.pdf
Nonetheless, give this a try. Power down your base, and pull the battery out of your handset. Plug the battery back in the handset and set the bad handset in the base cradle, and then power up the base. Wait about 30 seconds, then give the phone a try. If it still does not work, then you need to try to "re-register" the bad handset back to the base. Look in the manual under "registration" procedures. Hope my help fixes it for you. Good Luck, CG
Feb 17, 2008 | Uniden TRU8865-2 Expandable System...
Out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Jan 13, 2008 | Uniden 5.8GHz Cordless Phone
Handset
Presume you are talking about the extra handset. Try placing the extra handset in the "main" base for 5 seconds.
Aug 27, 2007 | Sony SPP N1025 Cordless Phone (spp-n1025)
Not Registered Problem
I had the same problem and I JUST fixed it! First, unplug the power to the main base (answering machine) for 20 seconds. Plus it back in. Put the phone that says "not registered" in the main answering machine. It will say "press the find handset for 4 seconds". Do that. It will run thru a series of stuff and will find the handset. It works! Rich (jambones.com)
Dec 25, 2006 | Vtech IP5825 Cordless Phone
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Jun 26, 2006 | Uniden TRU8885-2 Cordless Phone
Vtech VT 2461 Cordless Phone Logo
272 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
