Question about GE 24 in. GLD5860LSS Stainless Steel Free-Standing Dishwasher
Dishwasher Drying Problems
My GE GLD5860LS dishwasher, less than 6 months old, does not dry dishes properly. It worked great up until this month. I know it is in warranty, but I need to know if it is a problem with the dishwasher or something else.
  • 126 Answers
SOURCE: Dishwasher knob is stuck
dont turn the knob counter clockwise it could damage timer try prying the knob off it could be shoved in to tight
Posted on Dec 13, 2007
SOURCE: GE Profile Dishwasher Not Cleaning
I removed the outer metal door cover by removing most of the phillips roundhead screws. The two screws closest to the latch should not be removed (they hold plastic pieces that help hold the outer door cover in place during reassembly), and the two flathead screws on the side of the door near the hinge should not be removed yet (they attach the pump). The door cover also has two small hex bolts on the bottom - these should be removed, too (or at least loosened). I removed them.
The outer door cover has two flat flexible wire bundles (for the buttons) that attach to the door using "quick-connect" push-pull connectors. One has a small tab which must be slightly depressed. Gently but firmly pull these out. Set the door cover aside.
I removed the pump by (one) gently but firmly removing the short (2" or so) gray rubber tube from the bottom of the detergent reservoir (NOTE: any detergent remaining in the reservoir will immediately drain on the floor at this time -- I let it drain most of the detergent into a cup, but then I taped a tapered wood screw into the opening to serve as a plug); (two) removing the 90 degree rubber fitting that attaches to the door; (three) disconnecting the motor wire electrical quick-connect; and (four) removing the two flathead screws that attach the pump to the door.
My (rotary peristaltic) pump has a black flexible tube that was clogged with solidified detergent. I verified the pump worked by first connecting the pump to power from the wall outlet. I used an old extension cord, cut the ends, crimped some small connectors that did not fit well to the pump connector, then taped the whole thing to help prevent a shock (I did not feel comfortable with this, but I did it anyway. Use caution. If I have to do it again, I would have used a pipe cleaner or wire instead of operating the pump as described below.). The pump motor is rated 110 volts ac., and the pump was operating fine. I think I got lucky (the pump spun the correct direction). It may be that if I reversed the wires, the pump might have operated backwards.
I then held the pump inlet hose under hot water in the sink for about 10-15 minutes, occasionally squeezing the hose, until the thick detergent had dissolved. During this time, the pump was pumping the water out the outlet.
I put everything back together, and the dishwasher cleans again.
Posted on May 20, 2008
We just hooked up our dishwasher. We used the cascade pillow packs. It worked great.
Then I thought I should use the smart dispense. I did the dishes are dirty and filmy!!!
I think the solution is once you get the dispense clear ONLY use the cascade pillow packs and for go the smart dispense.
Posted on Oct 21, 2008
  • 8 Answers
SOURCE: ge dishwasher gld4160looss
Where's the vent on top/or the end of the door under the cabinet? Some steam is normal.
Posted on Nov 21, 2008
SOURCE: GE Profile Dishwasher (5 years old); Leaving residue on dishes
In my case the counter mounted breather for the drain tube was being restricted ... finally to the point it would not drain the tub at all. I disassembled the above counter drain assembly and cleaned it out as it wass completely blocked and things work very well again. I would suggest this foirst as it is an easy task and is done 'above the counter'.
I then ran 2 cups of CLR with wash cycle ... no dishes to clean out the rest of the washer as on dissaembly of the internals to diagnose they were and very scummed up with a hard white crusty substance that was completely blocking some of the drain sump performations.
Posted on Dec 19, 2008
  • 677 Answers
There is a new product out that actually filters the water going into your dishwasher. My dishes came out amazing after the first load. No more cloudy glasses. I was very impressed. Who knows whats in the water cleaning your dishes so i thought this filter was great. It is very affordable and you can get it at Hope this helps some people.
Posted on Jan 06, 2009
0 characters
1 Points
Water not heating up and not drying
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
I have a new stainless steel Samsung dishwasher. It doesn't seem to be drying properly. Dishes and dishwasher still very wet after cycle is completed.
Your dishwasher has been designed to use a liquid rinse aid. Pouring a liquid rinse aid into the proper recepticle in your dishwasher when you add dish detergent greatly improves drying performance. You can further improve drying performance by selecting the Sanitize option, in addition to the other options you've selected, and increasing the water temperature.For Best Results, use Jet-Dry Turbo
Spots and film form in your dishwasher's rinse cycle, when detergents are already down the drain. FINISH® JET-DRY® Rinse Agent works in the rinse cycle, lowering the surface tension of water and causing it to sheet. Better rinsing results in less spots and film.
If these recommendations do not improve drying time, please contact Samsung Customer Care
Sep 07, 2011 | Samsung 24 in. DB5710DT Stainless Steel...
My kitchenaid dishwasher leaves a white residue on clean dishes. 4 year old appliance, worked great until 6 months ago. under warranty, service repairman said i was using too much soap( am not). he cleaned...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
Mar 10, 2011 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher is not drying. At end of cycle, dishes are still wet and damp, as well as the inside. Buttons are all pushed. Also, it seems to wash for more than one cycle. Did a light wash and after 1-1/2...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 27, 2010 | Whirlpool MDBH969AWB Builtin Dishwasher
I get a film on the inside of dishwasher as well as dishes at the end of a cycle. You can really see the cloudy film on glasses. Dishwasher is only 18 months old.
Cloudy film is usually from hard water. Or it means the dishes arn't drying properly. you wanna make sure your using jet dry and that your not using liquid soap. Liquid soap is a killer of dishwashers and creates mineral deposits. If you have hard water getting a water softener helps too. Theres a cleaning agent called dishwasher magic that works to clean the dishwasher . You wanna make sure your heater is coming on too.
Jun 15, 2010 | Kenmore Dishwashers
I have a BOSCH model 53L06UC dishwasher and was
every bosch dishwasher unit is different. you can get odor from different source. #1 solution to fight odor is the proper maintenance. every month run the cycle with just a cup of vinegar on a hot wash. i am a old bosch tech and alot of people dont add the jet dry properly. this is for drying,spots and-cleaning you must add the jet dry or rinse agent (same thing)into the compartment. close compartment,then lower and raise door 3 times,then fill again repeat until you cant add anymore then it is filled.if this help please send me a 4 thumbs up post. thanks
Feb 28, 2010 | Dishwashers
Residue left on dishes
Make sure you use a drying agent as well a good brand name dishwasher soap.
Aug 30, 2009 | Bosch Evolution 500 SHE45M05UC Stainless...
Bosch dishwasher she45m
Just bought a Bosch dishwasher and we were told that they have no heating mechanism to dry the dishes, which is why they are more energy efficient.  You are supposed to leave the door closed for at least one hour after the cycle is complete.  The heat that has built up inside during the wash cycle will dry the dishes.  It is also recommended to always use JetDry. If you follow this advice, the dishes will come out fine.
Mar 20, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Open Questions:
GE 24 in. GLD5860LSS Stainless Steel Free-Standing Dishwasher Logo
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Michael Thomas
Michael Thomas
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
