My machine quit running at full power and sometimes not at all. I took it in and the technician said it was bad power. It worked fine at the repair shop. At home, it would not. I tried it at another house and it didn't run. Suggestions!
SOURCE: thread bunching underneath fabric as I sew.
You may need to take off the housing that covers the whole dog mechanism. You will need a screwdriver to do this. Blow out the area around the tension gears and dogs, check for loose or disconnedted parts, and re-oil the gears. Fleece fuzz usually collects where you can't see it. This was the problem with my machine that had the same symptom.
SOURCE: Squealing noise from the right side of the machine when begin sewing
sounds like it needs to be cleaned. check the belt first.
SOURCE: the foot control for our
if the first guy did not replace it with a pfaff foot it will not work right the pfaff machines will work backwards of normal power feet and they have to be replaced with pfaff feet
SOURCE: I have an Elna free arm SP sewing machine. The
it need to be serviced,,if the reverse lever appears to be disconnected then the tech needs to find out why it disconnected
Testimonial: "Thank you!!!"
SOURCE: While sewing on my Pfaff
Without the proper tools and some knowledge of how to disassemble this machine it is best to let a Pfaff service tech handle this problem.
