Question about Casio Marine Gear AMW320D9EV Wrist Watch
Digital works but analog works part time
I just purchased this watch on eBay and discovered it was refurbished. the digital portion of this watch works perfectly however the analog portion only works half the time... could this be the battery ?
2 Suggested Answers
SOURCE: Casio G-Shock G-7400 Watch
Thought this would happen when I sent you a request to help me simply change the analog time on my watch.
Your repsone to free suppor tis asking me to enter into a arrangement that requires payment.
I've solved the problem from another site free of charge.
I'm very disillusioned with the way you promote your site and will definitley recommending to others to stay clear of it.
COmes across as we can help you free of charge but bottomline is that this won't happen.
Onlty wanted to know how I change the analog time on my watch - could go to the Jewler to do this free of charge - thought the internet would help but your company has prolonged the support immensely.
Paul Stirling
Posted on Apr 11, 2008
  • 2334 Answers
SOURCE: i purchased wr50m watched i donot lnow how to set time both digit
Check out my tips and tricks here in FixYa and you will get manual for your watch.
Posted on Jan 21, 2010
0 characters
1 Points
Analog on digital watch not working
when a watch has analog hands and has digital portion, 9 times out of 10 it will have 2 batteries inside. A lithium battery and a normal battery. It is possible one died before the other. Usually the lithium (digital portion) lasts longer. Have the battery changed.
Dec 06, 2013 | Watches
The digital will not sync with the analog hands on my g shock
same problem here.. everytime i adjust the analog clock it moved but the digital clock dont so it means i can correct the analog but i cant correct the digital clock please help us..
Dec 30, 2012 | Watches
I can't set my watch. The hands will not move to set the analog time; all digital information appears to work fine. The alarm works (it does ring but I just can't seem to set the analog watch time. The...
I would consider taking the watch to a professional jeweler, it probably needs a good cleaning and possibly a part replacement, given the fact the watch is 22 years old.
Mar 13, 2011 | Le Chateau Watches
I have a Timex Ironman T563719J. The digital clock is working, but the analog portion has stopped. Any ideas?
There are two batteries in the watch. One for the digital watch and the other for the analog watch. The battery for the analog side probably needs changing but when the back is opened, you might as well change both batteries.
Jan 18, 2011 | Timex Ironman T56371 Wrist Watch
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
    Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Aug 21, 2010 | Casio Watches
Ul 1008 analog portion does not work
Are the hands moving but out of step with the digital display?
If so then try pressing the "mode" button to reach a mode that allows you to set the hands (on my Casio it is "HS"), I would expect something similar on yours.
You can then alter the hands by pressing one of the other buttons. I would expect one button to advance the hands and another to ****** them.
Happy experimenting!
Feb 22, 2010 | Kenneth Cole Watches
The digital portion of my watch is completely blank.. the analog works fine. Any idea what the problem is
You may have two batteries in your watch - one for analog and another for digital. Check that out and if this is the case - replace the battery for digital part. If there is only one battery - your watch's digital part has electronic failure and you will need professional watchmakers help to fix it.
Rate me, plz.
Jan 08, 2010 | Pulsar Watches
Analog hands not moving but digital part works fine.
A Benrus advance is not a Casio PRG-60T Tough Solar Protrek watch. You posted your query in the wrong place.
Jun 20, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Casio Marine Gear AMW320D9EV Wrist Watch Logo
46 people viewed this question
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
Jimmy Accardi
Are you a Casio Watch Expert? Answer questions, earn points and help others
