Question about Philips 14PV225 14 in. TV/VCR Combo
TV wont switch on
When i switch my TV to standby the red light comes on, on the front panel but the television wont switch on and it gives off a high pitched 'eeee' sound then when i switch the TV off again the noise slowly fizzles away. this has happened before but has corrected itself. also i try to put a video in the VCR but it wont be accepted. the TV is reletively new i got it around 2 and a half years ago! thanks
2 Suggested Answers
SOURCE: tv not starting up
the vcr mechanism has failed and stacked on the eject position,so the whole system is sensing this.I can also say that there is amisalignment of the mechanism. The mechanism needs to be reset/ aligned by a technician who anderstand the system.
Posted on Apr 03, 2007
  • 47 Answers
SOURCE: no video, no sounds...
power problem . one of the chips on circuit board could be fried call the service centre and it will be fixed under 200 bucks.
Posted on Oct 24, 2008
0 characters
1 Points
I cannot turn TV off from remote. It makes the picture go out but red light is still on. Have to unplug the TV to turn it all the way off.
red light stays on because tv is in standby mode when switched off by the remote, should be an on/off switch on the tv body somewhere
Sep 10, 2011 | Hitachi Combination Televisions
Tv wont stop beeping every time i turn it on. It is a very high pitch beeping that doesn't stop. I have tried plugging the tv in several different plugs by itself but the beeping still didn't stop.
Ur High Voltage is dead.The FBT the flyback transformer is dead.The big block of plastic with a red wire with a cap hook to a CRT(tv tube).Replaced the FBT get power back.
Jan 19, 2010 | Combination Televisions
I have a technika lcd tv/dvd. It is only a few months old but it is stuck in standby with the red light on the front continually flashing and will do nothing else. Any ideas?
I have same unit (which works in my case) but the red light does not flash on 'Standby', only when it is seeking a station after pressing the red button on the remote.
Nov 16, 2009 | Combination Televisions
Tv will not power on. the standby light goes out and the led light comes on but they click back and forth
Ur high voltage is dead,FBT,the flyback transformer is dead.The big block of plastic with a red wire with a cap hook to a CRT(tv tube).
Oct 20, 2009 | Combination Televisions
Tv wont turn on and has a high pitched sound while plugged in
your flyback transformer and driver circuit are operating, but the horiz. output transistor that needs to be in circuit w/horiz output transformer is open and can't amplify the signal needed for the flyback xfmr
Oct 09, 2009 | Combination Televisions
High pitched sound
Sounds like you have a coil or transformer that needs resoldered. Possibly in the hi voltage circuit but sounds more like a transformer in the switch mode power supply...
May 15, 2009 | Emerson EWC13D4 13 in. TV/DVD Combo
Symphonic 32 flat panel ringing problem
that high pitched ringing is usually caused by a power leak in the high voltage section of the set. it needs to be looked at by a proffessional electronic technician before it goes out altogether.
May 09, 2008 | Combination Televisions
Power light comes on, followed by a high pitched whine
Hi, If after trying the TV again later and problem persist, repairs are in order. A high pitched whine is an indication of a fault at the horizontal section of your TV. The horizontal provides the high voltage for the picture tube. Your best bet maybe to seek the services of a qualified professional TV repairman since this involves component level repair, soldering/desoldering, use of soldering iron and VOM (testers) and knowledge of circuitry. Good luck and kind regards.
Aug 20, 2007 | Toshiba MW30G71 30 in. TV/VCR/DVD Combo
Philips 14PV225 14 in. TV/VCR Combo Logo
26 people viewed this question
Top Philips Combination Televisions Experts
matt martin
matt martin
Are you a Philips Combination Television Expert? Answer questions, earn points and help others
