Question about HP Designjet 110plus nr InkJet Printer
HP Designjet 110plus - print heads
We've got a problem with the blue print head flashing and the printer not working. We replaced the print head a month ago and it solved the problem. Last week it started flashing again and we replaced the print head again (with another new print head). It just keeps flashing we've reinstalled the software, cleane dthe head, refittted the parts, turned in on and off a few times.
  • Anonymous Mar 06, 2009
    Same
SOURCE: canon pixma ip4500 print head
Exact same problems with this printer as the previous comments. My iP4500 haven't seen much use but it worked fine until few months ago when it started telling me that printer head was not installed.  It tells me this everytime I started it up to print something.  I wrestle with it for about an hour and somehow I get it to print something.  It has become very annoying to a point where I want to throw it out the window and break things in my room.   Somehow... I don't think replacing the printer head will solve this problem, but I'll try it first.
Posted on Sep 01, 2008
  • 53 Answers
SOURCE: hp designjet 500 does not work
You probably have a problem with dry ink in the service station. This is the "tank"on the right hand side of the plotter which collects all your wasre ink. I would have a guess that because of the long standing period this has dried and is preventing the station from moving and cleaning the heads. You will have to remove the right hand cover of the machine, then looking directly downwards just behind te display panel you will see two torx screws, loosen them. The service station can then be removed and cleaned. Be sure to disconnect the small plug on the service station motor and fan, also remove the motor and fan before cleaning the station with water under a tap. BEWARE this is a really messy job, your hands will be black (use dishwashing gloves) and it takes a really long time to clean it properly, wait for it to dry in the sun and re- assemble.
Good Luck
Dave
Posted on May 04, 2009
ingenito
  • 11 Answers
SOURCE: How do I clean the HP designjet 110plus printhead
You need to go to the hp download site and download the System Maintenance Utility Software. Its free, but you need it before you can clean the print heads. also, for some reason it works best when hooked to the network, not directly to Computer.
Posted on Jun 20, 2009
  • 96 Answers
SOURCE: Magenta print head reseat.
i'm sorry to be the bearer of bad news but it sounds like your carriage assembly is bad. the slot that holds the magenta cartridge is defective.have the carriage assembly and trailing cables replaced. this should resolve your problem. these parts are becoming harder to find because of the age of the printer. carriage assembly part number is C6074-69388. trailing cable is C6074-60418 making the assumption this is a 36" plotter. also you can try cleaning the contacts on the carriage assembly. good luck!
Posted on Oct 01, 2009
  • 75 Answers
SOURCE: Designjet 100 failure of print head
try cleaning the contacts on the back of the head and also the contacts on the printer, it could just be a bad contact between the printer and the head.use a lightly damp cloth and be sure the printer is turned off.
Posted on Mar 09, 2010
Black ink clogg
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
Aug 30, 2012 | HP Designjet 110plus nr InkJet Printer
Designjet 110 plus nr the yellow does not print
Replace yellow print head...Might be print head dried up..
Jan 31, 2012 | HP Designjet 110plus nr InkJet Printer
Why is my designjet 110plus printing too dark
> Check cartridges, any refilled one?> Perform print head alignment> Shoot color wise CMYK print out, check which color in dark > Verify the colors are spreading on media?> Try with another mediaI hope these steps will give you the solution..
Jan 04, 2012 | HP DesignJet 110 Plus InkJet Printer
ON TURN ON, PRINTER PRINTS THREE TEST ALIGNMENT PAGES
Its trying to calibrate the ink heads but cant because of a problem. Try cleaning heads and if no joy then replace. I have good secondhand ones here if you get stuck
Apr 18, 2011 | HP Designjet 110plus nr InkJet Printer
The "!" light is flashing; two of the print heads are flashing; I send a drawing to be printed; and nothing happens.
The flashing lights signal an error. If the printer started printing, please check for jammed paper. If it has not started to print, please remove the ink cartridges and then put them on again. They might just failed to be charged by the printer unit.
Feb 02, 2010 | HP Designjet 110plus nr InkJet Printer
Why won't my designjet 110 print in color? black printing is just fine
the color print-head is dried, need to 'clean head' on the printer, and reinstall printer driver
Dec 29, 2009 | HP Designjet 110plus nr InkJet Printer
Black ink started to print blue/mauve
Many thanks for the suggestions received. Have been told by HP to
change the black printhead - which has solved the problem!
Dec 22, 2009 | HP Designjet 110plus nr InkJet Printer
Clunking noise at power up
Well then it has something to do with that printhead that you just installed yes? Is it in correctly? just stating the obvious.
Jul 14, 2009 | HP Designjet 110plus nr InkJet Printer
Mar 06, 2009 | HP Designjet 110plus nr InkJet Printer
HP Designjet 110plus nr InkJet Printer Logo
719 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
