Hi Lynne:
Sounds like you're into some interior customizing right?
So you're going to install some rad new seats and they have new bolts and instructions so that they will be installed safely, right?
So the only problem you have is that there were old bolts sticking up from the floor, and you want to get rid of them. They will be either welded on, or the bolts will be coming through from the underside. Sometimes they will get stuck with rust or undercoating. You'll just need to find out if they can be removed, or if you need to use a zip cutter to get rid of them. I'd be tempted to find a way to temporarily secure them until I was absolutely sure the new seats are working the way you want, and that you will never need the old bolts again.
You need a new fog light as you one is cracked some where you can remove the light by taking the inner wing off then remove the light by the torques bolt at the top
Go to a farm and home store or website. They offer stakes that go in your yard. The stakes have barely audible clicking device that goes off randomly. The clicking from the stakes will run the moles from your yard and into all your neighbors yards
vehicles on longlife service intervals need to go on diagnostic equipment. on fixed service intervals reset as follows... press and hold button A ( middle button on right of steering column ) switch ignition on release button A the words service will appear on trip recorder press button B ( right hand button ) until the display clears and is replaced with new service interval switch ignition off
if you can follow that lol
if you need any more assistance dont hesitate to ask
Sir,
your rid need to get it all plugs and plug wires changed which must not be passing current properly then must have gotton to much carbon on to them. you are also suggested to change air filter and fuel filter. your rid then would be working gr8.
