Question about Medion MD 7317 17" Flat Panel LCD Monitor
Heard pop sound, then no power
For awhile now the monitor has been having problems when cold. It would come on all fuzzy, picture would black out, come back, do it several times and I would power off monitor, then back on and it cleared up after 45 seconds. Yesterday I heard a pop and it went off, no power. Couldn't get it to come back on.
Any ideas?
  • 57 Answers
Sounds like your monitor just fried itself.
Since monitors are hazardous, tricky to fix, and are quickly outdated within a year, by a monitor with a bigger size and resolution.
To answer your question: Your monitor is bricked, and will need to be replaced with a new monitor.
Posted on Nov 30, 2008
I heard two popping sounds and now my television will not power on.
A popping sound as you describe sounds as if your tv blew a couple capicators on the main control board. More than likely , you are needing to aquire a new main circuit board.
Sep 01, 2014 | Samsung UN55B8000 55 in. LCD HDTV
My Vizio p50hdtv herd spark, and TV went black, no picture no sound
Check and replace the main power regulator board as card basis. It has damaged.
Oct 11, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
The monitor goes black after being on for awhile. We have changed the cable between the computer and the monitor but continue to lose the picture intermittently. We can tap the monitor and sometimes the...
You will need to either send this unit to a service center; or open it up yourself and resolder the video connections as well as the power input section on the Inverter Board. Most of these are cold soldered and they tend to break away with age and movement. I you have the tools you may also want to test (with and ESR Meter) the Capacitors. Use a Fluke DVO meter to test the Transistors and Rectifier. TCC
Feb 02, 2011 | ViewSonic VA1912wb Monitor
LG plasma TV turned off, after the picture very light
I think you have a defective power board. the pop sound in coming from the board and giving you a low output voltage. do it yourself price about two hundred for parts.
Feb 18, 2010 | LG 42PC5D Television
TV went out over time. Sound immediately, but no picture. Loud POP noise when i changed channel. After a while it would "warm up" and would work fine. now doesnt show picture at all. In monitor mode...
Check the power supply first for bac capacitors (learn more here about bad capacitors: http://en.wikipedia.org/wiki/Capacitor_plague)
I had replaced capacitors in my, hopefully it did not cause damages to other circuits such as backlight inverter board.
Nov 02, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
HP Plasma Tv Black picture
This sound likes the Y-board that controls the video was defective. This is quite common problem of plasma as the TV gerenates lot of heat.
Aug 13, 2009 | Televison & Video
Picture started getting fuzzy then it went out
yes,remove the back of the tv,on the power board you will see the problem.replace those capacitors on the power board.this will allow the set to work.the black bars may still be there.this is an indication of a bad panel.
Aug 08, 2009 | Televison & Video
Tv plays sound but no picture or any signs of backlight
This sound is a capcitor pop and this could be in the power supply unit itself. The glass could be a fuse that took the brunt from the capcitor pop.
1. Unplug the unit and do not plug it in.
2. if its under warrenty take it in please!
3. if its not under warrenty and you know eletronics verify what cap popped and replace that and the fuse.
4. if you do not know about eletronics this work would cost you around $150 for the wrok done.
Good luck I hope this information helps you!!
Jul 17, 2009 | Vizio L32 32 in. LCD HDTV
LCD TV screen goes black but sound remains.
i have the same exact tv and the same exact problem my problem started about 3 months after i bought it and since i didnt have the receipt couldnt do anything about it. i wish i could find a solution to this problem as well its so annoying.
Mar 28, 2009 | Rosewill R900J 19" Flat Panel LCD Monitor
Medion MD 7317 17" Flat Panel LCD Monitor Logo
143 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
