Question about Miele 36 in. KM342 Gas Cooktop
Gas cook top
I have a 5-burner cook top. I turned one of the burners on this morning and the gas flame was extremely high. The other 4 burners have normal flames. Please help!!
  • Anonymous Mar 17, 2014
    element does not work
  • 175 Answers
Most of the time when I come out for a service call with this problem, it is usually because the burner cap is not seated properly on the base. Look at the burner and make sure there are no uneven gaps. Most of the time you will have to rotate the burner cap till a notch or pin "seats" into place. Most burner caps just sit on the bases, and so they get knocked off or moved when the cooktop is cleaned or installed. Hope this helps!
Posted on Oct 31, 2006
SOURCE:
Flame flares up sporadically while cooking
Due this test, turn on all burners on high, as you turn them on, does the problem burner change in volume or size of flame? If all burners are on and you only have issues with that single burner you need to replace that burner valve only. If you have issues with all burners when the all are on, replace the regulator.
I hope this helps and leads you in the right direction.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Mar 23, 2014 | Jenn-Air 36 in. CCG2523 Gas Cooktop
LP gas stove top . burners want turn down to low. Only medium and high flame work on burners.
Has this just recently happened? Check the knobs aren't cracked sometimes the brass spindle inside the knob is not gripping to turn it right down, also check your l p gas pressure it should be 2.75 kpa.
if the flames are big and yellow it's getting too much gas, not enough air.
Mar 13, 2014 | Whirlpool WFG231LVB Freestanding Gas Range...
I have a gas glass cook top (JGC9536) with a problem at the right front surface burner (12,500 btu). I used to be able to just turn the switch on high and the burner would light. Now, there is spark and...
Make sure there is no blockage of the burner near where the spark jumps. All it takes is a drop of water to stop the gas flow near the spark. Most likely you can use a knife or some other thin blade to clear the slots where the flame comes out of the burner.
Feb 20, 2014 | Jenn-Air 35 in. JGC9536 Gas Cooktop
1 burner of 4 does not get enough gas to work properly
The burner probably hes plugged holes for the gas to get through.
You can clean them out with a tooth pick or paper clip.
Feb 17, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Front right burner has high flame on left and low on right had a service call and GE tech said this is normal so you don't get pot handle hot, sounds absurd to me. Any input
Are the burners uniform around top? Pictures show that there is a slot on one side. The tech is probably right.. You are not the only person complaining about this. Call back and see if there is a different burner that will fit you stove.
Dec 20, 2017 | GE PGS968SEPSS Profile 30" Slide In Gas...
My Neff T67S76NO hob has a Wok burner problem, I think. The inner ring flames are fine but the outer ring can't be turned above half on before the flames start to go ragged. The more it's turned up th
it sounds to me that u need to reduce pressure although u say pressure is correct try reducing pressure and see what happens i presume u use bottle gas L P G?............in any case the flame shud not ever lift of burner and flame doesn't need to touch pan to cook hope this helps
Jan 07, 2014 | Cooktops
My ignitor on my ge cooktop keeps clicking slowly in off mode
As it relates to 5 burner gas cooktop Model Number JGP 963SEJ1SS
First - Ignite the flame then reduce the flame to between low and medium.  If the igniter continues to click, you most likely have a contact switch issue related to the problem burner.
Unplug the cook top and turn off the gas.  After the gas is turned off, disconnect the gas line.
Remove the cook top.
Unscrew and Remove ALL of the burner bases by lifting them up.  The ceramic igniters may be difficult to remove but they will come loose if worked out slowly.
Pull of the wire connected to the igniter.
Remove to cook top top plate from the base, exposing the internal gas valves and wiring.
All of the burners are wired in parallel.   Lift off and unsnap the casing of the problem igniter switch.  The repair may require something as simple as, 1- cleaning the contact strips, or 2- slightly bending the non stationary contact strip to keep it from coming in contact with the stationary contact when in the off position, or 3- replacing the switch.
Unless you comfortable and understand how electric systems and switches work, this is a job for a qualified repair person.
Apr 02, 2009 | GE Cooktops
Spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
Mar 09, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Miele 36 in. KM342 Gas Cooktop Logo
1,215 people viewed this question
Top Miele Cooktops Experts
Marvin
Marvin
mpservices
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
