Question about Bose Lifestyle-28EW System
Volume changes on its own.
I have not had any problems with this system up until recently. The problem started out with the volume changing by itself. No matter what the source is. During movies/radio/etc.. the volume will go up and down randomly. The volume change display is shown as well. This has now progressed to it muting itself, changing modes, and powering on/off by itself. I thought that the remote could be going bad. But even after putting the remote in a different part of the house the problem still exists. I am very friendly with technology, but am not sure where to start with this one. Any ideas would be greatly appreciated.
4 Suggested Answers
SOURCE:
SOURCE: Disappearing sound, Low sound, no sound
Unplug the system from the wall and plug in again...It worked for me...hope it works for you too.
Posted on Oct 05, 2007
zaids
  • 456 Answers
SOURCE: volume
Heyya first check out the speaker wires and then try
Posted on Dec 03, 2007
  • 7 Answers
SOURCE: volume
I had this problem and checked the main wire going from console to bass unit, it was loose from where I had moved the unit to insert another device (RCA Jacks). Apparently if the wire from the unit is loose, it over - rides the volume and by default adjusts it to 30. Additionally, I reset the system console and bass unit console, during this process. Try this, it might fix your problem.
Posted on Jan 02, 2010
Coby 938 theater system volume
bagaimana caranya buka sandi hp expressmusic
Nov 23, 2013 | Coby DVD938 Theater System
Volume decreases during use
Very simple. It is not a defective unit. Simply a matter of volume attenuation, hold the "function" and "grove"keys for aprox 5 seconds until a message saying vac off appears. Problem solved. Resets itself eveytime the unit is turned off .
enjoy!!!
Nov 16, 2013 | Sony RDH-GTK1i Hi-Fi Music System
I just recently got directv installed and ever since my volume on my sansui tv turn down by itself any idea why
Hi:
Most cable or satelite boxs have their own volume controls try using the boxs remote to change vol levels to see it this solves your problem.
May 22, 2011 | Televison & Video
Toshiba 32AF44. While watching a baseball game yesterday, the volume bar appeared by itself and scrolled down to zero. The bar will not disappear. It's like someone is holding the down button. Tried...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Mar 04, 2017 | Toshiba 32AF44 32" TV
The handset lights up and the incoming number is shown but you dont hear it ringing
Many times there is a volume switch on the actual handset itself. Most commonly on the left side of vtech devices. there are three different volume levels. By pressing up on the button you should be able to turn the volume up until it has an audible tone confirming volume change. Handset should ring with incoming call when audible tone is heard by pressing up on volume button.
Oct 13, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
I recently returned my Nano. The volume could
Have you checked whether there is a volume limit on the nano. Go to settings then playback and then volume limit. From there you can adjust the maximum volume you can have. Hope this helps.
Nov 13, 2009 | Apple iPod nano 3rd Generation
Volume Does what It wants
My Yahoo YHT-400 does something similar, only it won't do it right away, it has to start getting hot first, then if I have the volume set at 25 or higher, it will slowly start turning itself up louder until it either maxes out, or I intervene. Either way, it's really annoying, even though I'm only using it as an amplifier for my computer. I just figured it was doing it where it's second-hand and had tons of dust inside caked in and around the fans until I cleaned it out. But when on AUX/TV, one would think the Bit Rate Transfer gauge would remain at 00, but it jumps up and down constantly, whether there's any audio being put through it or not.
Aug 18, 2007 | Yahoo YHT-630 System
Kenwood VR615 turns itself off at medium volumes
I also have the same problem, it is really annoying... anyone have any ideas.... please help!!
May 21, 2007 | Kenwood VR615 Receiver
Volume is uncontrolable
Hi sounds like you have the audio out from the cd changer connected to the RCA/Phono out of the radio. double check that the output from the CD changer is going into the correct phono/rca connector regards Mark www.carradiospares.co.uk
Apr 04, 2007 | Panasonic CX-DP88 8-Disc CD Changer
Bose Lifestyle-28EW System Logo
101 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Steve Allison
Steve Allison
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
