Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
SONY KP46WT510 blinking 8 times
My Sony isn't working and is blinking 8 times. I have found that this is an Audio problem. Well, I live way back in the boonies and to pay someone.......well, I may be able to fix it if I could get further info on where this IC406 Audio Amp is located inside the gaggle of boards. As you can tell, I don't want to spend my money on a $200 service call plus parts and labor. Any help would be greatly appreciated.
If you don't know what you're doing, you may end up further damaging your TV. For a more information, go to www.aestelevision.com
Posted on Aug 20, 2007
SOURCE:
Sony lcd tv 8 times blinking
the interpretation of the 8 blink is as follows:
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
Check IC406 audio amp, PS401 and 402.
Regards.
Jan 05, 2012 | Televison & Video
After turning my t.v. on it shuts off and the led blinks 8 times
I found this on the web about this model...
"8 blinks is likely to be an audio power amplifier IC failure". I hope this helps!
Oct 12, 2010 | Sony KP-51WS500 51" Rear Projection...
Sony rear projection tv
How many blinks are you getting. This is an error code that pinpoints the problem.
The downloadable repair manual for kp-46wt510 can be found Here!
If you need assistance with the repair, go Here!. These guys are great.
Nov 14, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
6 bliks on sony kp-46wt510
KP46WT510 Shutdown 6 Blinks. 6 Blinks = Low B+ OCP/OVP
SOLUTION: Replaced Flyback transformer. It had no rings on the ringer test.
HQ
Comments: Any load on the B+ line can cause 6 Blinks.
Example: If the 200v line is loaded down will cause a drop in B+ due to bright picture current demand.
Click Here! to download the Sony Kp-46wt510 full service manual.
Nov 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
8 blinks
8 blinks on your model number means High Voltage error. Which means TD8005 is faulty on the D board.If you need any additional info please let me know
Mar 03, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony kp46wt510 with 6 blinks can anyone help
• +5 line is overloaded. (A, B Boards)
• +5 line is shorted. (A, B Boards)
turn off for about about 4 hours
Feb 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Turns on, blinks 8 times, turns off
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Feb 11, 2008 | Sony KP-53V90 53" Rear Projection...
Sony KP57WS510 Blinking 8 times
You have a strt up problem. I found, in a similiar Sony Big Screen a couple of fixes. First thing to try is unplug the set from the wall for about 15 minutes and then plug it back in and retry the set. If this corrects the problem, I suggest you purchase a good ( Not a 5 dollar piece of junk) surge protector. ( One rated at 500-1500 joules. A good surge protector may prevent future processor lock ups. If this doesn't correct the problem, the problem lies in the circuit boards of the set. I found one problem in a Sony like you describe had a bad convergence chip and a burned resistor in the same board. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Televison & Video
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
61 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
