Question about Minolta Dynax 505 35mm SLR Camera
NO LCD DISPLAY AND BATTERY GETS HOT
I have a 500 modal and tried loading a film and now it wont work at all and the battery just gets really hot
You have a shurtcut on your machine, ma by water or your lent
Posted on Feb 25, 2008
Why does my Galaxy tab 4 get so hot using skype?
Skype puts a huge drain on the battery, when the battery is under this type of load demand it gets hot. Make sure the battery doesn't look swollen, if it is remove it and put it in safe fire proof container and dispose of it as hazardous waste.
Jan 09, 2017 | SKYPE Cell Phones
6530 aspire laptop charger gets really hot and doesn't stay charged for long
sounds like the battery is going bad on you . chargers will get hot when they have to work too hard as when the battery is not taking the juice .
Aug 03, 2015 | Aspire Computers & Internet
Starters getting really hot, why?
In simple terms, the starter gets hot from a high amount of voltage flowing thru it.
The why part is another thing.
Could be a bad connection between the starter and the battery including the ground. Could be a problem with the engine not wanting to turn over. For example, if you broke a timing belt the engine may lock up.
Jul 20, 2012 | 2005 Kia Optima
Camera wont come on battery gets really hot
if it is a digical if so the batteries have to be rechargeable and be over 1000 because the rest just arnt good enough . because of the technolgy in the camara , and because of what it can do do . the batteries have to be the best . their will be more power comeing out of the camara and excceds the battereis. its like a mobile phone , the phone is a 16 volt batteri and you plug a 5 voult charger in the phone . it gets realy hot because their is insufficaint charger for the volt . we wiill have almost blew the charge on the batteris aswell as the connection on the camara or ie [phone]. leave for 24 hours and then try the rechargeable energizer 2000 plus is one of the best .replace the old for new and try the enegizers
Mar 30, 2012 | Sanyo VPC-T1060 Digital Camera
My kodak m863 wont turn on. and when i put the battery in the camera gets hot
There is a short in the primary part of the systems control board, and the battery gets hot because it is been loaded down. This is not cost effective to repair, it is far cheaper to replace the camera with a new one.
Jan 14, 2011 | Kodak EasyShare M863 Digital Camera
My amp cuts out when it gets really hot. any reason why it would cut out or get real hot. is it cuz i have it hooked from the battery that powers the car too should i get a bigger battery or a second...
I had a Pioneer amp that did this too. There is no easy fix to it. Just try to keep it cool.
It shuts itself down when it gets to hot so it doesn't have a catastrophic failure. (melt)
There shouldn't be any issues with being wired to your car battery.
Make sure its got plenty of open space(if possible) add a fan maybe.
Or take some of the load off of it by 1. Adding an amp. 2. Turn it down
I would take option 1 You have the amp so you can turn it up in the first place
Good luck
Dec 09, 2010 | Jl Audio 1000/1 Car Audio Amplifier
When I turn on my netbook, the screen stays black. Nothing appears.
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Aug 21, 2010 | Gateway LT2030u Netbook
The laptop gets very hot very quickly.
This happnes to my one aswell cause of the battery life....my battery life stays up to 2 hours ...after 30 mins it gets hot and i phoned the company (dell)..they gave me a new one which works perfect ....but you have to have insurance on the laptop
Apr 16, 2010 | Acer Aspire 5610-4648 Notebook
Bushnell Tour V2..no display
If the unit gets hot (like in the trunk of a car), the LCD display will go out. Keep it in the house and it should get better when it cools.
Oct 05, 2008 | Bushnell Tour V2 Pinseeker Laser...
PLease help me with my Nokia 6288... Thanks!
hi there i have had that problem once, and i'v solved it.
for the heating of the battery and no lights, no display, no signal its all for the flex(ribbon) problem all i did was remove again the flex and clean the contacts sometimes it shorts i just re-solder the contacts of the flex. because some of parts that we bought is not 100% ok. just try it again maybe you'll make it.
ok
peace!
Mar 28, 2008 | Nokia 6280 Cellular Phone
Minolta Dynax 505 35mm SLR Camera Logo
67 people viewed this question
Top Minolta Photography Experts
Parshiv Luthra
k24674
Are you a Minolta Photography Expert? Answer questions, earn points and help others
