Question about Olympus Pearlcorder T1000 Desktop Cassette Transcriber / Recorder
Voice playback is extremely slow.
I have not made any changes to the settings on the transcriber. However, when I play tapes I now get very slow playback, regardless of the speed I use. It happened one time and then it went back to normal and now it is back to slow and I cannot fix it. Any help would be appreciated! It's hard to understand the dictation! :o)
  • 106 Answers
Try with some contact spray ,put it on the speed of tape button and that will solve the problem for some time.
Posted on Feb 29, 2008
Plays so slow - how to fix?
dear
i need you to check the rubber belt which is connected on the top of DC motor if it's get wider than the original size you have to change it
Aug 04, 2015 | Sanyo Trc 8800 Full Size Tape Transcriber...
My Panasonic RR-930 transcriber speeds up and slows down as I play back tapes. The problem seems to be with the machine itself and not the foot pedal or the tapes. Where do I start?
Start by cleaning the capstan roller. The rubber roller and small steel rod just above it, control the tape speed. Just a little lint, build up or animal hair wrapped around this can cause the speed to vary. Clean with alcohol and a Q-tip.
Feb 02, 2011 | Panasonic RR-930 Desktop Cassette...
Just put in my first tape for the 2740. Even SLOW is too fast. I don't see an option for changing it. Am I missing something?
Hello this transcriber is only a 4.8 Speed transcriber and the slide speed control is on the front of the unit if the cassette that you are trying is a Normal 4.8 speed and is not responding you need to send your unit for service you can try this place Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Mar 31, 2010 | Dictaphone 2740 Desktop Cassette...
What is the cue/f play/erase button on the top
When in RECORD, pressing the 'Cue' button will put a tone on the tape. This is used on the transcriber's machine to identify different jobs and such.
When in PLAY, pressing the 'F Play' button will change the playback speed to 1.5.
If you hold the 'ERASE' button and hold the portable in REWIND, it'll erase the tape while it's rewinding.
Hope this helps...
Jul 13, 2009 | Dictaphone Audio Players & Recorders
Sanyo Transcribing Machine - model unknow
The motor has gone and would need replacement. Unfortunately, this part was recently discontinued so you will have trouble finding someone who has one.
Nov 07, 2008 | Sanyo TRC-8080 Desktop Cassette Voice...
Won't playback or transcribe
2 things to check:
1. is the speechmike set as default playback device: go to Control Panel--> Sounds and Audio Devices; and in the opening window, go under the Audio tab; in the Sound Playback, the default device should be set to SpeecMike II if you want the sound to come out of the SpeechMike.
2. Playback volumes: still in the same tab, click the Volume button of the default device; it opens a set of volume controls; you need to ensure that for the WAVE, and Speaker (or Volume Control), the Mute box isn't ticked; you also want to set this volume to something not equal to zero (i.e. move the cursor up to at least 1/3 of the level).
I hope this helps.
Sep 01, 2008 | Philips SpeechMike Pro 5274 Handheld Voice...
Tape plays too fast on slowest setting
The tapes may have been recorded at 1/2 speed or 1/4 speed so they are not playable on this model.
May 16, 2008 | Panasonic RR-830 Desktop Cassette...
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Speed
Just had the same problem!!! You have to press FF and Play at the same time to stop the fast play!
This is probably way overdue and you won't even get it, but just in case someone else has this problem...here is the answer!!
Sep 19, 2007 | Dictaphone 2740 Desktop Cassette...
Olympus Pearlcorder T1000 Desktop Cassette Transcriber / Recorder Logo
256 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
