Question about Pioneer SD-P50A3Q 50" Rear Projection Television
Turning on SD-P403 Pioneer projection tv
Suudenly, I been having trouble turning on my tv. Do hear the clicking noise when pressing power on switch on remote control or power switch @ the TV front panel. Some time it does start after clicking it for almost all day. When it's warm then no problem turning it on and off again. Wondering if the power to the crt or the tv is thru a relay or directly powered thru transformer. Opened the rear cover and couldn't find where the clicking coming from? in other words looking for the part or relay to resolder the contact if the problem is due to a cold solder. I believe the power mechanism is same on 40in model as it is on 50 in. model. If I can know the physical location of the part making clicking noise then I might be able to measure the voltage when switch pressed. Any assistance is appreciated becaus my tv works just great other than this recent problem with turning it on problem. Thanks!
When i turn the power button on, it will only stay on for two to three seconds and then turn off, if I wait 30 to 40 seconds and repeat to turn on, it does the exact same thing, how can i fix this??
Posted on Jan 03, 2009
There is one philips head screw with access only thru an access hole in the circuit board at the back near the 8A fuse for the power input.  Remove this screw and the whole tray will slide out. Be careful to recover the screw using a magnetic driver...
Posted on Aug 29, 2008
I need to know how to slise the panel out in the bottom to get proper access to all the boards.I have back cover off I have the same convergence problem as most others here. I can find a service manual so I am working blind here.
Posted on Aug 08, 2008
    President:
  • 4,402 Answers
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine.
Posted on Feb 12, 2008
SOURCE:
My SD-P6093-K Pioneer has recently stopped turning on. It makes a click noise as if it was turning on, but about 3 seconds later it makes another click noise and then then nothing. No picture no anything....
STK ICs 2 of them,example STK392-110.also CK hori out put transistor and little blue capacitor 2Kvolts it feeds back to Hori Transistor. Mats has STKs
1-800-628-1118 $10.95 each they retail for $55.00 each in repair shops.
Mar 16, 2010 | Pioneer SD-P62A3-K 62" Rear Projection...
Sd-p55a3-k/kc this tv does not turn on
Th convergance amps have failed you will half to replace them, or have it done parts are around 70 dollars not and easy fix on a pioneer time consuming
Dec 10, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Tv wont turn on
bad connection. if you have some electronics experience, unplug the tv and carefully open the back , remove the main bord and check for soldering using the magnifier. if you check very good , you will see a sort of small line around the soldering . that small line are bad connection , re-solder them .
Sep 15, 2009 | Pioneer PRO-200 60" Rear Projection...
Pioneer SDT50W1 rear projection TV clicks off when switched on.
Hey dudes...even i hav had the same problem that too with the same model specified here..Its a problem actually concerned with the power circuit boards of the tv. Its best to get it checked by an authorized technician. For me I had to replace a transistor on one of the boards. But after that my tv came up with a new problem....the colours appear like rainbows! Could nyone xplain y dis is happening?
Feb 06, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P6091 Projection TV - TV turns off by itself
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jan 20, 2009 | Pioneer SD-P6091K TV
Pioneer 710 hd power/not turning on 10/12/08
When the set goes into protection BANG like that, without any intermittencies, usually the convergence ICs have gone out and need replacing. I recommend using the STK 392-180s, which are the stronger upgrade to the 392-110s used originally. You'll need 2.
Mr Bob
www.imageperfection.com
510-278-4247
bob at imageperfection dot com
Oct 13, 2008 | Pioneer PRO-710HD 64" Rear Projection...
55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
Pioneer projection sd-p403
The screen looks like a bad 3D movie without the glasses. Anyone know how to fix this?
Jan 01, 2008 | Pioneer PRO-200 60" Rear Projection...
SD-P403 PROJECTION MONITER RECEIVER
Most likely the switch is bad. But it could also be the relay that the switch controls... if your mechanically inclined, get back with me.
Jeff
Nov 28, 2007 | Pioneer PRO-200 60" Rear Projection...
Pioneer SD-P50A3Q 50" Rear Projection Television Logo
625 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
