Saeco Vienna Espresso Machine
Problem for Saeco Vienna Espresso Machine
Power to the machine
By boffgirl on Oct 30, 2006
Help, I unplugged my machine before turning it off and now when I try to plug it in and turn it on the power does not come on. There is no red light and the machine does not do anything
Same Problem
Mar 06, 2009
-   Italia will not turn on. No visible problem with the cord and the outlet works fine for other appliances. The lights do not turn on and the top does not warm. I can not find a fuse to replace. Help Please!!!! Gotta have my Java!-   DrCass
Mar 05, 2009
-   Mine has never worked-   tmrs
Nov 02, 2008
-   I have had the Saeco Italia for about 2 years now, today I got the empty water light, I refilled the chamber, when I put it back on the machine, the power went off.  I verified that the plug works, tried machine on other plugs, wiggled the cord around, checked for frays or other problems, nothing.  It won't turn on now.  No fuse in the back, wondering if the switch went bad, or is there an internal fuse?-   massls
Sep 30, 2008
-   I turn it on and get no power. Outlet is fine.-   mbluther770
Aug 07, 2008
-   My Bodum Granos will not tun on. Mains power plug and lead ok but machine will not switch on.-   Guest
Best Solution
posted on Jun 08, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
After you have check that the Main Power outlet is active and on, make sure the unit is plugged in and that the on / off switch on the back of the unit is switched to the I position.
If the unit still does not power on then the boiler circuit breakers have tripped.
You can get to the circuit breakers by removing the rear panel;
Disconnect the mains plug from the unit, make sure you do this and not just turn off the mains switch, otherwise the switch internally will still be active;
Remove water unit;
Remove two silver screws at the rear top of unit;
Move the rear panel;
DO NOT disconnect any hoses;
The boiler is located on the right hand side of the unit looking from the back;
MAKE 100% sure that power is disconnected before proceeding;
On the bottom right hand corner of the boiler there are 4 wires connected to the unit using spade lugs, two black wires two blue wires;
In the center of the each colour there is a small tiny tab;
Lightly press the first one you should hear a small click;
Lightly press the second one you should hear a small click;
if either or the two doesn't click it means that particular breaker has not tripped, don't try and push harder.
Assemble the unit and power back up.
Hope this helps.
Robert.
Solution #2
posted on Dec 13, 2006
Somewhat Helpful)
Mukilteo
Rank: Apprentice
Rating: 78%, 23 votes
mukil... indicated that his solution for
Caffe Parma Espresso... Problem
is valid for all Coffee and Espresso...
Also, check to make sure that you didn't trip a GFI (ground fault interrupter), the kitchen and bathroom mini-circuit breakers.
Was this helpful?
Yes
No
Solution #3
posted on Oct 30, 2006
Somewhat Helpful)
archief
Rank: Apprentice
Rating: 72%, 27 votes
Verify that there is power at the outlet. check power cord for breaks or scuffs. Check to see if there is a fuse in the back of the machine. I fall else fails...buy american.
Was this helpful?
Yes
No
Solution #4
posted on Oct 11, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Called Cuisinart at 800-726-0190 6:10PM on 10/10/08.  Zero wait, person asked me model # and Serial #, said they would ship me a new one in 7 - 10 days if I would cover the $10 shipping and ship the old one back.  Done Deal!!
Solution #5
posted on Apr 12, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The element has burnt out. There is an insulator that can become dislodged during transit or over time, and the element can short out. I advise you to return the failed unit to the supplier.
Popular Solutions for Saeco Vienna Espresso Machine
Questions and Unsolved Problems for Saeco Vienna Espresso Machine
Do you recommend Saeco Vienna Espresso Machine?
Answer
Answer
when i push the button, a little bit of coffee commes. i can't solve it with the buttom up for a... (More)
Answer
Saeco Vienna Deluxe pump loose pressure. no water for coffee.
Answer
my saeco vienna doesn't turn on. it had already this morning but I came back in my kitchen and it... (More)
Answer
Saeco magic combi You need to push it VERY hard... if not the water will not flow thru the grinds... (More)
21 Other Users Have The Same Problem - Continued
Comment by vanderwark, posted on Aug 05, 2008
When I plug in the Granos, nothing lights up, no activity whatsoever.
Comment by halfprice, posted on Aug 03, 2008
the clock on my coffeemaker DCC-1200W keeps going off and this shuts the maker down. Then I have to unplug it from the outlet and wait awhile and have it on program to get it to come back on when I pulg it into the outlet and then turn it to brew to brew the coffeemaker. This started suddenly before that I had no problems with it. Alot of timesw when I wait awhile to plug it back into the outlet nothing happens. Can you help me please?
Comment by marboo87, posted on Jun 13, 2008
Lights come on no perc.
Comment by bookielisa, posted on May 20, 2008
No power on Saeco Vienna Automatica. I've done all of the suggested maintenece but when I turn it on nothing happens. No lights, or warm-up sounds. etc. Is there a fuse that can be replaced if that's the problem?
Thyanks for any feedback
Lisa
Comment by Guest, posted on Mar 28, 2008
maker worked great yesterday and now today there is no power!!!
Comment by Dancingfeat, posted on Mar 21, 2008
The machine simply does not turn on when I press the power button. Very frustrating to an espresso drinker...
Comment by CHEVYGIRL07, posted on Feb 07, 2008
MY COFFEE MAKER WILL NOT COME ON AT ALL AFTER THE GFI OUTLET POPPED NOW IT WONT COME ON AT ALL
Comment by jslepoi, posted on Jan 27, 2008
Suddenly no power, no red light, nothing happens.
Comment by Guest, posted on Jan 05, 2008
Water will not warm up in my Keurig.
I failed to turn my coffee maker off and I believe all the water burned out of the warming bin. Now it won't start at all.
Comment by cwgrlk8, posted on Jan 04, 2008
Did the same thing, unpplugged before finished brewing because it was spewing water and grounds everywhere. Cleaned it up carefully, did not get bottom wet. Now I plug it in, red light comes on, no display and then it clicks off. Any ideas? DCM485
Comment by Guest, posted on Dec 28, 2007
My one year old machine seemed to start brewing more slowly and would beep indicating it was done brewing when it was only half done. Now, today it brewed it's last cup of coffee and has lost all power. RIP
Comment by kkhlopov, posted on Dec 23, 2007
Yeh, same problem. Leds dont turn on and machine doesn't do anything.
Comment by rockfest08, posted on Nov 26, 2007
Yes, My coffee machine automatically stops brewing in the middle of a batch when there is still coffee/water yet to run threw and brew. Then I press brew again and after a minute stops and have to press it again until it is finally done. Usually I press brew, jump in the shower get dressed pour a full cup of coffee and go. Now I have to run by a few times and press brew which is a pain in the butt. Could you help me??
Comment by Guest, posted on Nov 20, 2007
The only power that I have appears to be the clock. I've plugged/unplugged, pressed the GFI, and tried a different outlet. Is it time to throw away or is there a part that I can replace?
Comment by digdug425, posted on Nov 06, 2007
Cuisinart DCC-2000 no power
This machine is driving me crazy. We spent nearly $100 for it a year ago and a couple months back, it started to just power off. Not auto shut off, bot zero power. WHen i try and plug it in in the morning sometimes it will work, sometimes it doesn't. There is power to the outlet. The clock will sometimes blink on really quickly then go off. I have to plug it in and out about 25 times before it comes on (sometimes). It has come on, started to brew then shut off in the middle also. I am about to toss it in the trash.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Saeco Vienna Espresso Machine:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
