Question about Midland G-227C2VPC (22 Channels) 2-Way Radio
Battery replacement? I have the Midland G-227 walkie talkie set. We have had them off for the past 3 or 4 months. We had just purchased new batteries and a new charger for them as the same problem had occured previously. The problem being, we charged the batteries as directed in the owners manual. After being stored for a while we put them on the charger for about 24 hours and we are unable to turn them on. Both lights come on on the charger but niether one of them will turn on. What are we doing wrong?????? Please let me know as this has been quite an investment for us to use only a few times. When they worked they worked very well. I would love to beable to have them work again. Thanks so much for your time and hope to have a solution soon. Respectfuly, Kris
  • 123 Answers
Kris, are you sure that the radio es working properly with other batteries, I mean if you use with 4 AAA batteries does the radio turn on? If the radio turn on, is your battery lasting as ussual? check if the battery contacts are ok, may be one of them could be damaged or rusted. I hope this can help Neto
Posted on Oct 31, 2006
SOURCE:
I have k7gfv700 Motorola walkie talkies w/ charger. The charge seems to work, but the lighs one the charge are red and the talkie do not charge. Do I need new batteries and where can I purchase the
You might try http://wirelesspro.com, we have found them to carry most TalkAbout accessories and batteries. Before ordering battery packs, you might try switching your existing good battery to the other radio and see if it solves the problem. This would assure you that it is indeed a battery problem.
Sep 28, 2014 | Motorola Walkie Talkies 2-Way Radio
My Midland walkie talkie quits transmitting about 3 seconds after I start transmitting
It is more likely a power issue. PTT switches do not normally cause a short circuit. Check the batteries, swap the batteries and see if that helps. Radios take a great deal more power to transmit than turn on or receive. If not the battery, try a low voltage battery, such as a cordless phone battery. If it still occurs, check your warrany and send it back to the factory.
Nov 10, 2013 | Midland Radio Midland X-tra Talk Frs/grms...
I bought 6 sets of Midland LXT 345 walkie-talkies for the teachers to use when they go out on the playground. Less than 1 year later several of them don't work. They keep them in their charges when...
The batteries have likely been damaged from being on the chargers too long. Try trading a known good battery into the non-working radios and see if it/they will work with a good battery. If so, replace your batteries, and then only put the radios on the charge when they need a charge, such as after the radios have been used 8-10 hours. Longterm charging can quickly age batteries. Life expectancy of a battery is 18-24 months with good care.
Best regards.
Sep 23, 2011 | Midland LXT385VP3 Two Way Radio
Midland LXT320/420 WALKIE-TALKIE . My battery are fully charged but radio does not get much of range.
My dear,
Do you want to replace your battery ? If so, please specify
May 04, 2011 | Cell Phones
The battery is fully charged on the walkie talkies and all are on the same channel, however out of 12 walkie talkies only 2 will work. When ever you push the push to talk button the walkie talkie shuts...
Your batteries are either no good, or not charged. When you press the PTT button it takes more energy than being in standby mode. If you have a battery problem it will fail quickly when the PTT is pressed.
Rechargeable batteries last approx. 18-24 months. Check your battery for a 3-digit date code. It is usually a 3 digit number followed by a couple of letters. The numbers tell the date of manufacture. The first number is the year, followed by the week of the year. 025 would be 2010 the 25th week. (or if very old it could be 2000 the 25th week.)
If you feel age is not a problem, you might check your charger(s) to see they are fully powered, and clear of debris on the contacts (and the radio contacts as well). Clean with a pencil eraser if needed.
A few tips: Be certain when placing your radios on the charge they are turned off. Check your wall outlet to be certain it doesn't get shut off with a light switch. Expect to replace your batteries every 2-3 years.
Best regards.
Nov 09, 2010 | Motorola Walkie Talkie 2-Way Radio
Opening battery compartment on Midland LXT80 2-way radios
First take the clip off by pulling the tab while sliding it down. Then once the clip is off, push in and down on the top of the battery compartment and it should come off.
Jul 07, 2010 | Midland LXT80 Two Way Radio
One of my midland lxt 420 walkie talkies wont charge!!!!!
If it has rechargable batteries in it like mine does, the batteries have probably lost all of its life.. you can replace them.. if you dont have batteries, you could have a loose wire inside the walkie talkie that wont let it charge..
Jul 29, 2009 | Radio Communications
Low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
Jan 01, 2008 | Radio Communications
Midland G-227C2VPC (22 Channels) 2-Way Radio Logo
139 people viewed this question
Top Midland Radio Communications Experts
eradiostore
eradiostore
freddyfox
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
