Computers & Internet Logo
Posted on Apr 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Keyboard for lenovo R500 laptop not working
When on the setup screen keys on the keyboard work
General Systems Consulting
Level 3:
Top Expert:
  • Master 5,051 Answers
  • Posted on Apr 04, 2012
Master
Level 3:
Top Expert:
Answers
5051
Questions
0
Helped
1060670
Points
15385
What do you mean not working? Is it that certain keys don't work, or the whole keyboard does not work?
Maybe your keyboard has been hijacked by a virus. Have you tried booting up in Safe Mode to see if it works?
Turn off the computer, then hit the power buttonto turn it back on and immediately start hitting the F8 key repeatedly untilyou see SAFE MODE. Take the Safe Mode option and let it boot up. SafeMode will look different to you, the screen will be darker and the iconsbigger, this is normal
4 Related Answers
benwabnick
Ben Wabnick
  • 2404 Answers
  • Posted on May 14, 2009
SOURCE: keyboard not working at all
Keyboard is definitely bad and will need to be replaced but try one more thing just to be sure.
GO into the BIOS by pressing F2 on your external keyboard. In the BIOS, there is an option in there to reset to factory defaults after you do that save changes and exit but after you completely exit, unhook the external keyboard and see if your laptop keyboard works. If not then you know for sure without a doubt the laptop keyboard needs to be replaced.
shadow
  • 490 Answers
  • Posted on May 30, 2009
SOURCE: acer 5920 keyboard setup
there is a software that launch menager. the program controls the keys you talked bout. you need to remove LAUNCh MENAGER.
Anonymous
  • Posted on Nov 24, 2009
SOURCE: How do you use the green keys on an LG R500 laptop keyboard?
I had a similar problem, kept getting french accented letters such as è, ç,à,é when i pressed keys like ", / , \ .... Anyways to solve the problem i pressed ctrl and then shift.
it switched back after pressing this a couple times.
Anonymous
  • Posted on Feb 28, 2010
SOURCE: Toshiba Potege R500 - neither control key works
I had same problem with CTRL keys not working.
Removed base cover, re seated keyboard connector & all worked OK.
1helpful
On my Lenovo g500 laptop many keys(gh and many) are not working, what should I do?
Connect to external usb keyboard to check. If works ok, your keyboard is defective and you should change it.
See tutorial
How to replace or remove keyboard on Lenovo G500 keyboard replacement
How to replace the keyboard of Lenovo g500 g510 g505
LENOVO G550 Keyboard Installation Replacement Guide Laptop Remove Replace...
Lenovo G580 G570 G500 G510 disassembly replacement keyboard hard disk full...
A warning: might look easy but if you are not really familiar with dismounting a laptop, you might end taking your device to a repair shp in a shoebox.
1helpful
Lenovo Flex 15d windows 8.1 touchscreen unresponsive
Hello
Either you have turn the Touch function off or the problem might be with the connection its might be loose. You can check in the control panel for Touch function. Or your keyboard might have quick function keys. The bottom of the keyboard has (fn) and another key on the keyboard will have the touchscreen icon.
9helpful
3answers
How do i take a screenshot on a lenovo thinkpad r500
1. Set your computer with the screen you wish to capture.
2. Click on the "PrtScr" button, usually located on the top right side of the key board.
3. Click the 'Start' button on the 'Taskbar' and type "Paint" in the search field. Once the Windows find the program, open it, and click on the 'Paste' option on the top left side.
4. On the keyboard, click "CTRL+S", and save the file on the computer, where it will be able to locate it later.
5 Send the file as an attachment.
Lenovo R500 keyboard not working
control panel keyboard driver to rest delay.
Wireless neternet connect, but neternet say it not
make sure your wirless wep key is setup properly. If you do not have this set as you were given it....it will not connect?
1helpful
2answers
I would pop the 2 keys oiff and make sure the rubber boot under the key is still there, did you buy this laptop used?
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Getting the lenovo m500 dlp projector to work
Solved ....when it projects it says to push Fn and F7 simultaneously for Lenovo laptops. The symbol for the F7 on Lenovo is the computer screen and keyboard plus a screen with a line attaching. On the Toshiba it is the F5 key. Pressing the Fn and F5 keys on the Toshiba simultaneously gives 5 box choices, the middle is CRT and the correct one to transfer from computer screen to projector.
19helpful
5answers
Grand Canyon Tech
Grand Canyon Tech
