Question about Sony STR-DE197 Receiver
Audible cracking from amp.
I'm experiencing audible cracks and pops from my receiver. They are independent from the volume control (remain at a consistant volume) and are extremely annoying. I have my receiver clustered in together with a cd player, dvd/vcr combo, cable box, and tv. Is this just a case of too much static electricity building up or is it a problem with the receiver.
I have the same exact problem. The static is present even when in a different component input. I fixed the problem by wrapping the end of my antenna wire around a metal coat hanger and hung the coat hanger on the wall above my receiver. I noticed that the most static came when I moved my cell phone around the room. Somehow the coat hanger fixed my static hopefully it will work for you.
Posted on Aug 20, 2009
I had the same problem. After going through the task of testing every last connection to the speakers, the components and... well everything. It still crackled like crazy. I read on another site that the FM antenna was the culprit. I simply unplugged the antenna and all crackling stopped. I don't use the FM tuner at all so that was no problem for me. But if you want FM I suggest getting a better product.
Posted on Mar 23, 2007
    President:
  • 3,130 Answers
There is a problem with the reciver my freind. Its only of the driver transistors or IC depending on what componet this amp uses. It can be found by using a heat blower and a can of freeze spry. it most likly will run you 150 or so depending on the exact problem. good Luck
Posted on Oct 30, 2006
My 2005 equinox has a NEW delco radio but the front speakers still dont work when you set the fader to the front
Do you still hear warning chimes ?
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings. The BCM receives audible warning requests via the class 2 serial data line or the controller area network (CAN) data line. If the BCM receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Do you have base or uplevel system ? Who put in the NEW delco radio ? I suggest you watch this video . GMC Acadia Diagnose Radio Volume Stuck On HIGH Part II A GM radio is the same for chevy , gmc , buick etc... an could need programming , just watch eric .He had radio fixed same problem .Some times you can't get away from going to the dealer.
Nov 11, 2016 | 2005 Chevrolet Equinox
How can i connect my denon 5805ci with my new tv 4k & 3D sony 65"
Are you sure that model is HDMI v1.4 compliant? I know my Denon 8508 is not so I use optical outs to get 5.1 surround sound.
Sep 08, 2014 | Denon AVR-5805CI A/V Receiver Dolby...
Cracking & popping radio
The volume control pod needs to be flushed with electronic control cleaner, unplug and remove back, attach supplied straw and give the pod two or three good blasts in the tiny hole and rotate volume back and forth rapidly to reach desired results.
May 20, 2012 | Vintage 1930's Replica Cathedral Radio and...
All of a sudden our receiver stopped working. The display looks fine, but there is no sound.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Source Selection, Mute, Tape Monitor control or Multichannel Analog Input selected.
If you have an aha moment turn the volume to something reasonable and see if that helped.
Jun 26, 2011 | Harman Kardon AVR 320 Receiver
I HAVE A ONKYO TX-910 RECEIVER THAT I PURCHASED IN 1993. IT PRESENTLY HAS NO SOUND. SHOWS POWERED UP & REMOTE CONTROL WORKS. HAVE CHECKED ALL THE SPEAKER WIRE CONNECTIONS & THEY ARE FINE. CAN THIS...
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead
Apr 09, 2011 | Onkyo TX-910 Receiver
Yamaha v-r701 reciever It has sound but it is very faint. You have to turn the volume way up for it to play at a wisper.
Mar 27, 2011 | Yamaha R-V701 Receiver
Because my rear speakers are popping and crackling during DTS output, I believe my settings of bass or treble might be overloading my speakers... should I set the rear speakers to "flat"? should...
Cracks and pops are dangerous. Can you tell if they might be circuit overloads or maybe digital decoding errors?
Are you routing bass to small speakers. THAT would definitely have audible problems. Define all of your speakers Large vs Small based on their bass-handling capacity.
ONLY DTS? Probably NOT the speakers or amps. How many sources are involved? Could be with the source or cabling.
Does it happen at low volumes, too? Then it would probably be digital in origin.
Do the indicators various digital surround mode indicators flicker or turn off when the pops appear?
As for the rest of your questions, I'd set everything at flat and start all over. If you're maxxing out any settings, something is wrong.
Jan 03, 2011 | JVC RX-7000V Receiver
Audible pops through my speakers every 30 seconds
Your computer may be overloading the speakers, in volume control turn the master volume down a bit and see if that is helping.
May 20, 2010 | Sony VAIO PCV-RS411 PC Desktop
My Tomtom xl 325se is experiencing audio volume problems. The volume suddenly dropped to where it is barely audible. I see no volume control on the unit. Can you help?
Hello :
This must be a software problem . You need to reset your device to fix the problem . .
Tomtom has a tiny hard to see reset button near the docking base . Press that for 15 sec .
Try it for resetting .
NOTE : Hard reset could delete the saved data on your GPS device .
Apr 17, 2010 | Tomtom One XL GPS Receiver
Instructions for super nintendo games on the intrenet
Here is the controller instructions for "John Madden Football"
CONTROLS KICK OFF Y Button call onside kick formation B Button kickoff, activate closest defender A Button call audible RECEIVING ONSIDE KICK Y Button attempt to receive kick on the left side of the field B Button attempt to receive kick in the center of the field A Button call audible, attempt to receive kick on the right side of the field OFFENSE BEFORE THE SNAP X Button fake snap B Button hike ball A Button call audible OFFENSIVE AUDIBLES X Button cancel audible Y Button running play B Button anti-blitz play A Button trick play OFFENSE AFTER THE SNAP Y Button dive B Button break tackles A Button spin PASSING X Button pass to receiver in window x Y Button pass to receiver in window y B Button show passing windows, pass to receiver in window x A Button pass to receiver in window a RECEIVING, RUNNING X Button reach for catch Y Button dive B Button break tackle A Button spin DEFENSE BEFORE THE SNAP B Button activate defender A Button call audible L or R Button line surge DEFENSIVE AUDIBLES X Button cancel audible Y Button stunt B Button blitz A Button defend against run DEFENSE AFTER SNAP X Button reach Y Button dive B Button activate defender nearest the ball A Button power tacklehttp://www.allgame.com/game.php?id=2510&tab=controls
Nov 23, 2008 | Video Game Consoles & Games
Sony STR-DE197 Receiver Logo
254 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
