Question about Onkyo TX-SR803 Receiver
Onkyo receiver 803
Sirs, the L/R surround speakers are mute on all play modes execpt for white noise calibration mode. even in speaker calibration mode the reciever doen not pick them up and auto sets them as 'none' when they are as loud as hell. i guess there fuse or reset option for the surround perhpas? also have no switching htmi- but i suspect that culd be due to the TV which is HP thank!!
    President:
  • 3,130 Answers
If the channels work in the set up noise mode, then the input is not on the proper setting for the function, or one or more of the tape monitor switchs are on. goood luck
Posted on Oct 30, 2006
Surround sound
there are 2 channel modes on your reciever, as well as surround modes, and it sounds like you have changed modes by accident. just open the little door on the front, and take it out of 2 channel mode
Mar 05, 2013 | Denon AVR 2808Ci Receiver
Two of my speakers are not working -no sound
If they are the rear surround speakers, they will not produce sound at all times, check this with a surround sound movie that will engage the speakers. Check the settings on the reciever to be sure you are in the correct surround sound mode, and check the movie menu to be sure you are playing in correct format. Also check that wires are correctly installed, observing polarity, under terminals at both the speakers and at the reciever. I hope this is useful, but not being onsite these are just a few troubleshooting tips to narrow the problem.
Feb 07, 2013 | Audio Players & Recorders
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
I've got an HK-595 system (Subwoofer and 2 satelite speakers with controls on one speaker for Center, Bass, Volume, Treble and Surround) for my PC. Everything worked fine for quite a while, but then (it...
I am having the exact same problem with my Harmon kardon PC speakers. It is related directly to the speakers (subwoofer). If you plug head phones into the headphone jack on the satellite speaker you will not hear the noise. I am still searching for a solution, I love these speakers!
Nov 05, 2010 | Harman Kardon HK595 Computer Speakers
Error s10
Did it ever work properly? If not, let's get down to basics and set it up for the simplest configuration it can have: FM source in stereo with front left and right speakers, no Surround Mode, no DSP, no Tape Monitor, no Mute, Volume not turned all the way down. Does that work?
Do you have Surround Speakers defined in System Setup A? If not, only Dolby Surround or Off are valid Surround Modes.
Is T2 Monitor indicator lit? Press the Tape-2 Monitor.
Is there acceptable sound other than during Speaker testing? NO? Is MUTE On?
Apr 29, 2009 | Onkyo TX-DS838 Receiver
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
I had this problem too. Finally, after using the MCACC setup and making sure all the speakers worked, I found I had to set the source to FM, TV or whatever from the remote control and set the mode to advanced surround sound using the front panal button on the upper right. Had to fool with them a lot. Good luck.
Jan 03, 2009 | Pioneer VSX-818V-K Receiver
Nakamichi AV-10 loud thud from subwoofer
I don't know the design of this reciever, and do not have any schematics or engineering information to know the design.
This is a general comment:
In many of these recievers at this level they don't have very good muting designed in to their system. When switching sources, the audio is not being muted.
This is a theory of why the noise is not on the main speakers, but present on the sub woofer. Because the switching noise is of very low frequency, this is why the sub woofer is making noise. The main speakers lack the low frequency sensitivity that the sub woofer has. This is one way of looking at it. It is also possible that there is muting for the main speakers, and none for the sub woofer.
If the reciever does have muting in to its design that is supposed to mute when switching modes, then there is an obvious defect. When a source is switched, or a mode is changed, the output would mute for the duration of the switching interval. This is usually for a period of about 100 ms.
Your best bet is to contact the service rep for nakamichi and ask the question there.
I have serviced many recievers made by other manufactures. The higher end models all had muting in their design. This way, the output was muted when the source was changed, and when the reciever was turned off or on.
Jerry G.
Apr 23, 2008 | Nakamichi AV-10 Receiver
In what mode do hear regular tv through the system
DO NOT PLAY THE TV SPEAKERS AT THE SAME TIME AS THE SoundSpace System!!! Damage will result to the SS if you do. You MUST mute the tv speakers!! This information is in the manual.
Jan 10, 2008 | Nakamichi SoundSpace 8.5 System
Installing speakers jbl
the red and white x indicates that your speaker is in mute mode. you just have to click that speaker icon and uncheck the mute. then you'll hear a music thats for sure.
Sep 18, 2007 | HP JBL Platinum Computer Speakers
Onkyo TX-SR803 Receiver Logo
251 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
