My ASUS motherboard has been running for 4 years. I have not make any recent changes to either hw or bios or settings.
The board will no longer come alive.
Button works correctly. I the computer was on and when I came back to it about 30min later it was off.
The board does have power as the green PWR led is on, but the Red AGP Warn LED is also on. This LED is to indicate to the motherboard that a non 1.5V AGP card is present and the board will not power up. The video card was never touched or changed. Even with the card pulled out, this LED stays on.
The power supply is able to power another computer fine. Also, when I measure the 5V rail (the one wire from the supply that is on all the time) it drops down to below 4.7V when plugged into the mother board. I am assuming the all the wire wires and voltages do not turn on because it never receives the power_on signal). When the power supply is powering the other computers, the voltage rails are normal. My computer does not have alot of devices on them, so I don't think the power supply is overloaded.
I suspect there is a short on the motherboard butI cannot find any component that gets hot.
I disconnected everything except the processor and the voltage still drops to 4.7V. On the rare occasion, I had to turn it on and off to get the voltage to drop that low. (it still did not power up when the voltage read above 5V)
I really would like to confirm that its the motherboard. Should the AGP_Warn led stay on even if there is no video card plugged in?
Any other sugggestions to look at. I don't want to just to do part $wapping to isolate the problem.
Comments:
Nov 01, 2006
- Hi Swobovike,
Thanks for the reply. Your response is appreciated.
As for your questions: I have not tried the AGP card in another computer. I'm going from memory here but I think the card is a MX440. I'm sorry, I don't recall the manufacturer. From reading the ASUS manual, its a 1.5V card as the MB will only power up when if it detects a 1.5V card. The AGP connector on the MB does not have the keyed slot to accept 1.5V AGP only. The only only other computer I have readily available is a P3 Dell Gx110. How can I confirm that this AGP will safely work in the Dell?
I don't have an aux fan, other than the fan over the CPU. The whole unit was bought assembled from a small local shop, but considering they gave me all the extra unused cables, I doubt they would have left a second fan out. I will have to check if the AGP manual was included.
The computer is normally shut off when not in use. At the time of failure, it had been on for about an hour.
I though there might be a short, but I tried feeling around for a hot component, but no luck.
Thanks for the microscope tip. I will look for something obvious (I have access to a scope). At the same time I'll give it a more thorough dusting with compressed air.
I response to upgrading, I would hate to have to replace several components as well as the MB. I am not a gamer or use the unit for intensive computing, so the unit is fine for what I was using it for. If I were to look for another MB that accepted the Socket 478 CPU (as well as similar speed rating), I'm assuming I'll need to reinstall Windows XP (home)? I hope the "OEMPLUS" disk the shop gave me has WindowsXP on it. I do have the license key label.
Sounds like you have done a lot of the footwork yourself and that helps. Have you tried the AGP card in another computer? Do you have an auxiliary fan in your CPU box? Do you normally leave the computer on all the time or shut it off when not in use? Seeing all you did I will assume the MB is clean of dust/dirt.
The voltage drop is rather minor but may indicate a short. There normally is a sag when the MB is drawing current. 4.7V should still be sufficient for proper operation of TTL parts. I would suggest checking closely, with a microscope or some other type of magnifier, for a bent pin in the AGP slot. It is possible that it has been bent all along but slowly caused a short due to excessive current draw. Since the MB is 4 years old it might be time for an upgrade anyway. To diagnose further, w/o the aid if a schematic, would be costly and would liekly exceed the cost of buyng a replacement. Good luck.
I have a computer manufactured from ibuypower in california.It is a Fatality Version, Viper Model. I...
(More)
I have a computer manufactured from ibuypower in california.It is a Fatality Version, Viper Model. I was attempting to install a new network card but some wires were in the way of installing the new network card. I tried to stretch them a little but the wires came unplugged. Now I don't know what wires go where.
I have an ASUS P5n-d nForce 7501 SLI chipset w Gb LAN, S-ATA Raid, USB 2.0, IEEE-1394, Dual PCI-EPU Technology motherboard. I need help in re-installing these wires to their connectors. I know I can't guess and if I get the wires in the wrong place, I could burn up the computer. Can you assist please? I have the pin numbers/letter description and the possible wire numbers/lettering and ready to submit this data.
Please help. I tried to call my manufacturer but they will be closed till Monday.
Sincerely,
Allen Williams
