Question about Alpine CDE-7827
Anyone know how to set the clock?
I thought that the Clock setting may have been automatic. However It's stil off be well over half an hour. I tried lots of button combos to no avail. Any help would be appreciated.
Press the clock buton until it starts to flash,( you do not have to hold the clock button) then press the #5 button to change the HOURS, and the #6 button to change the MINUTES The clock will stop flashing in a few seconds if you do not do anything at all.
Posted on Jun 07, 2007
My clock chimes out of secrence quarter past then hour chime is quarter to hour? how can i fix please
Sounds like the minute hand is a quarter hour off. Make the clock strike on an hour. Count the number of times it strikes, then remove the minute (long) hand, and the hour hand. Replace the hour (short) hand to the number that the clock struck, and tighten by pressing hour hand in toward the dial, then replace the minute hand in the position that it's pointing at the twelve. Now it should be showing the time that it struck. To make sure, advance the minute hand to the half hour, and let it strike the half. Advance it to the next hour, and it should strike the correct time that is showing on the clock. For example, if the clock strikes four, and is showing three, then move the hour hand to the four while the minute hand is pointed at the twelve, then press the hour hand on each side of the center shaft towards the dial to tighten it. Now advance to half hour, and let strike, then advance to the next hour. It should strike the correct hour. I hope this helps more than confuses. Good Luck
Feb 08, 2015 | Home
I can not set the clock on my i river reader it keeps going back an hour after i set it help please
Do you have your PC set to automatically adjust for daylight savings? If so, try turning that off and setting your clock forward one hour manually. Although it seems that this would cause your clock to be one hour behind if the setting software isn't adjusting the clock setting for savings time.
May 03, 2011 | Computers & Internet
I don't know how to set my clock on my 2006 uplander
Hello, here is the instructions for setting your clock on this vehicle.
Press the H or the M button to enter the clock mode. Press and hold H until the correct hour appears on the display. Press and hold M until the correct minute appears on the display.
To change the time default setting from 12 hour to 24 hour, press either the H or the M button to enter the clock mode. Press the tune knob to select between the 12 or 24 hour display format. The clock mode automatically times out with the changed display format set as the current default setting.
Dec 09, 2010 | 2008 Chevrolet Uplander
How do i synchronize chimes with clock on westminister whittington clock .
The Westminster/ Whittington clock means that it has 2 or 3 settings.
1. Silent
2. Westminster Based on the music My redeemer liveth by Handel
3. Whittington
Set the clock onto the westminster setting, this is the easiest. At quarter past the hour it should sound 4 notes. The half past should be 8 notes. Quarter to the hour should be 12 notes and the hour should be 16 notes then the striking of the hour. For example on 8 'O clock you should hear 16 notes then the clock should chime 8 times. Sometimes if the hour is out just gently stop the pendulum, check what hour the clock is striking then without taking the hands off move only the hour hand to the hour. Do not do this with the minute hand.
I hope this helps you! If you are not sure please email me yvonne.finch@gmail.com I fix these clocks.
Apr 30, 2010 | Seiko Mantel Clock
No numbered touch pad for use setting clock
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
Mar 05, 2009 | Sharp Microwave Ovens
How do I set the time on my Pioneer RT500?
Hi!
Please follow the instructions given below... =)
Setting the clock
The clock is set to the correct time automatically, but it
can also be set manually. The clock can be set for
daylight saving time and time zone.
Preparation:
• Turn ON the TV and set it to the video input mode.
• Select “CLOCK” from “SYSTEM SETUP”. For the
procedure, see steps 1 to 3 in “Using the SETUP
MENU”
1 Press SETUP while the DVD and video tape is
stopped.
The SETUP MENU screen will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
SETUP MENU
ENTER/
SELECT ENTER RETURN BACK SETUP END
SELECT
2 Press  or  to select the desired menu and
press ENTER.
The submenu screen of the selected menu will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
LANGUAGE
PARENTAL
CLOCK
DISC SETUP
OTHER
SETUP MENU
3 Press  or  to select the desired submenu and
press ENTER.
The screen for the selected submenu will appear.
CLOCK (manually)
You can manually set the date, year and present time
with the remote control.
Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
1 Select “CLOCK” and press ENTER.
01/01/04 12:00AM
2 Select the desired items using  or  (month,
date, year, hour, minute and AM/PM) then press
ENTER.
3 Press  or  to set the value of the selected
item.
• For the minutes, press  or  once to set the time
minute by minute, or hold down either of buttons
for several seconds to set the time in 10-minute
intervals.
10/30/04 10:200AM
4 Repeat steps 2 and 3 to set the date, year and
present time, and press ENTER. The SETUP MENU
will close.
This completes clock time setting.
AUTO CLOCK
You can automatically set the clock by turning “ON” the
AUTO CLOCK function.
When you want to set the auto clock function to “OFF”,
select “AUTO CLOCK”, press ENTER and select “OFF”
from the list.
Auto clock setting
Preparation:
You must connect the antenna or cable before connecting
the AC cord to the power source.
Wait 30 minutes with the power turned off, after the
antenna or cable is connected, for the auto clock
feature to activate.
After the clock is set automatically, you may have to set
the time zone and daylight saving time. (See page 26.)
Press STANDBY/ON to turn on the DVD/VCR after the
auto clock operation completed.
• When shipped from the factory, the “AUTO CLOCK”
option is set to “ON” position.
• If you turn the DVD/VCR on during auto clock
setting, the clock is not set.
• After a power failure or disconnection of the power
plug, the clock setting will be lost. In this case, wait
30 minutes before turning the DVD/VCR on.
• With cable box connection, if the auto clock setting
is unsuccessful, select the PBS channel carrying
the XDS information, then turn the DVD/VCR off.
After 30 minutes, turn the DVD/VCR on.
• If the clock is not set automatically, set the clock
manually.
STANDARD TIME (Time zone)
In the rare event that you live within the broadcast range
of two stations in two different time zones, the DVD/VCR
may recognize the wrong station for the auto clock set.
To correct the situation:
Select “STANDARD TIME” and select the time zone from
the list below.
Selectable time zones and correction times
ATLANTIC: GMT – 4 hours
(GMT: Greenwich Mean Time)
EASTERN: GMT – 5 hours
CENTRAL: GMT – 6 hours
MOUNTAIN: GMT – 7 hours
PACIFIC: GMT – 8 hours
ALASKA: GMT – 9 hours
HAWAII: GMT – 10 hours
AUTOMATIC: AUTO SET
Note
• When shipped from the factory, the “TIME ZONE” is
set to “AUTOMATIC”.
• After making the auto clock setting, in some cases
the clock may display another time zone. You can
correct the clock by selecting your time zone
setting above.
• When the clock is not set or you set the clock
manually, the time zone setting is not available.
DAYLIGHT SAVING TIME
You can set the clock to daylight saving time automatically
or manually.
To select daylight saving time, select “DAYLIGHT
SAVING TIME” and select “ON”, while to cancel the
daylight saving time, select “OFF”.
ON: For manual setting (forward 1 hour)
OFF: For manual setting (back 1 hour)
AUTOMATIC: For automatic setting (read XDS in
the signal)
Note
• When you want to set daylight saving time, on the
first Sunday in April you set it to “ON”, and on the
last Sunday in October you set it to “OFF”.
• When shipped from the factory, the “DAYLIGHT
SAVING TIME” option is set to “AUTOMATIC”.
• When the clock is not set, the daylight saving time
• When there is no daylight saving time in your area,
always select “OFF”.
Jan 03, 2009 | Pioneer DVR-RT500 DVD Recorder/VCR
Set Clock for a Clarion DB336MP
You can find the instructions at: http://akamaipix.crutchfield.com/Manuals/020/020DB336MP.PDF
Page 11 give you info on clock setting.
Or try this:
1) Press and hold the [BND] button, and then
press the [DISP] button to display the clock
display.
2) Press and hold the [BND] button, and then
press the [DISP] button for 2 seconds or
longer.
3) Press the [d] button, then set the current
minute.
4) Press the [a] button, then set the current
hour.
5) Press the [BND] button, then the clock is set.
Nov 25, 2008 | Clarion DRB2475
Sharper Image Weatherproof Atomic Clock Model OQ007
Press and hold the "Mode" button for a few seconds until the display flashes. The briefly press the Mode button to cycle through each setting. When you get to the "Zone" setting, press the up button to advance the time zone. Press the mode button repeatedly to finish cycling through the settings.
Done.
Nov 03, 2008 | Audio Players & Recorders
How to set a RCA RP3720A model
First, move the slide switch at the left rear of the top of the unit all the way to the right. You'll see the colon blinking, indicating that you are in 'set' mode. Now turn the dial that surrounds the ON/OFF button on the top of the unit. You can move it clockwise or counterclockwise, to change the time forward or backward. When done, move the slide switch back to the far left. Done.
Dec 16, 2007 | RCA Radio Alarm Clock
Car Audio & Video Logo
116 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
