Question about LXE MX6 Portable Terminal
Auto Login I cannot get out of Auto Login for RFTerm session. Tried several times (Ctrl Shift M) not working. I want to change network settings of the device. Fatih.
THE SYSTEM IS CONNECTED DIRECTLY INTO THE RECEIVER THAN INTO THE MONITOR. AS FAR AS I KNOW IT IS NOT CONNECTED TO MY INTERNET.
one thing that you can do is turn on the auto login feature if the screen goes blank or the login session times out. I am not aware of any reason why the system would time out. The auto login setting will log you in in the event your screen goes blank.
Jan 08, 2017 | The Audio Players & Recorders
Tip
WORD 2003 Shortcuts
All Caps Ctrl+Shift+A
Annotation Alt+Ctrl+M
App Maximize Alt+F10
App Restore Alt+F5
Apply Heading1 Alt+Ctrl+1
Apply Heading2 Alt+Ctrl+2
Apply Heading3 Alt+Ctrl+3
Apply List Bullet Ctrl+Shift+L
Auto Format Alt+Ctrl+K
Auto Text F3
Auto Text Alt+Ctrl+V
Bold Ctrl+B
Bold Ctrl+Shift+B
Bookmark Ctrl+Shift+F5
Browse Next Ctrl+Page Down
Browse Prev Ctrl+Page Up
Browse Sel Alt+Ctrl+Home
Cancel Esc
Center Para Ctrl+E
Change Case Shift+F3
Char Left Left
Char Left Extend Shift+Left
Char Right Right
Char Right Extend Shift+Right
Clear Del
Close or Exit Alt+F4
Close Pane Alt+Shift+C
Column Break Ctrl+Shift+Return
Column Select Ctrl+Shift+F8
Copy Ctrl+C
Copy Ctrl+Insert
Copy Format Ctrl+Shift+C
Copy Text Shift+F2
Create Auto Text Alt+F3
Customize Add Menu Shortcut Alt+Ctrl+=
Customize Keyboard Shortcut Alt+Ctrl+Num +
Customize Remove Menu Shortcut Alt+Ctrl+-
Cut Ctrl+X
Cut Shift+Del
Date Field Alt+Shift+D
Delete Back Word Ctrl+Backspace
Delete Word Ctrl+Del
Distribute Para Ctrl+Shift+J
Do Field Click Alt+Shift+F9
Doc Close Ctrl+W
Doc Close Ctrl+F4
Doc Maximize Ctrl+F10
Doc Move Ctrl+F7
Doc Restore Ctrl+F5
Doc Size Ctrl+F8
Doc Split Alt+Ctrl+S
Double Underline Ctrl+Shift+D
End of Column Alt+Page Down
End of Column Alt+Shift+Page Down
End of Doc Extend Ctrl+Shift+End
End of Document Ctrl+End
End of Line End
End of Line Extend Shift+End
End of Row Alt+End
End of Row Alt+Shift+End
End of Window Alt+Ctrl+Page Down
End of Window Extend Alt+Ctrl+Shift+Page Down
Endnote Now Alt+Ctrl+D
Extend Selection F8
Field Chars Ctrl+F9
Field Codes Alt+F9
Find Ctrl+F
Font Ctrl+D
Font Ctrl+Shift+F
Font Size Select Ctrl+Shift+P
Footnote Now Alt+Ctrl+F
Formatting Properties Shift+F1
Go Back Shift+F5
Go Back Alt+Ctrl+Z
Go To Ctrl+G
Go To F5
Grow Font Ctrl+Shift+.
Grow Font One Point Ctrl+]
Hanging Indent Ctrl+T
Header Footer Link Alt+Shift+R
Help F1
HHC Alt+Ctrl+F7
Hidden Ctrl+Shift+H
Hyperlink Ctrl+K
Indent Ctrl+M
Italic Ctrl+I
Italic Ctrl+Shift+I
Justify Para Ctrl+J
Left Para Ctrl+L
Line Down Down
Line Down Extend Shift+Down
Line Up Up
Line Up Extend Shift+Up
List Num Field Alt+Ctrl+L
Lock Fields Ctrl+3
Lock Fields Ctrl+F11
Macro Alt+F8
Mail Merge Check Alt+Shift+K
Mail Merge Edit Data Source Alt+Shift+E
Mail Merge to Doc Alt+Shift+N
Mail Merge to Printer Alt+Shift+M
Mark Citation Alt+Shift+I
Mark Index Entry Alt+Shift+X
Mark Table of Contents Entry Alt+Shift+O
Menu Mode F10
Merge Field Alt+Shift+F
Microsoft Script Editor Alt+Shift+F11
Microsoft System Info Alt+Ctrl+F1
Move Text F2
New Default Ctrl+N
Next Field F11
Next Field Alt+F1
Next Misspelling Alt+F7
Next Object Alt+Down
Next Window Ctrl+F6
Next Window Alt+F6
Normal Alt+Ctrl+N
Normal Style Ctrl+Shift+N
Normal Style Alt+Shift+Clear (Num 5)
Open Ctrl+O
Open Ctrl+F12
Open Alt+Ctrl+F2
Open or Close Up Para Ctrl+0
Other Pane F6
Other Pane Shift+F6
Outline Alt+Ctrl+O
Outline Collapse Alt+Shift+-
Outline Collapse Alt+Shift+Num -
Outline Demote Alt+Shift+Right
Outline Expand Alt+Shift+=
Outline Expand Alt+Shift+Num +
Outline Move Down Alt+Shift+Down
Outline Move Up Alt+Shift+Up
Outline Promote Alt+Shift+Left
Outline Show First Line Alt+Shift+L
Page Alt+Ctrl+P
Page Break Ctrl+Return
Page Down Page Down
Page Down Extend Shift+Page Down
Page Field Alt+Shift+P
Page Up Page Up
Page Up Extend Shift+Page Up
Para Down Ctrl+Down
Para Down Extend Ctrl+Shift+Down
Para Up Ctrl+Up
Para Up Extend Ctrl+Shift+Up
Paste Ctrl+V
Paste Insert
Paste Format Ctrl+Shift+V
Prev Field Shift+F11
Prev Field Alt+Shift+F1
Prev Object Alt+Up
Prev Window Ctrl+Shift+F6
Prev Window Alt+Shift+F6
Print Ctrl+P
Print Ctrl+Shift+F12
Print Preview Ctrl+F2
Print Preview Alt+Ctrl+I
Proofing F7
Redo Alt+Shift+Backspace
Redo or Repeat Ctrl+Y
Redo or Repeat F4
Redo or Repeat Alt+Return
Repeat Find Shift+F4
Repeat Find Alt+Ctrl+Y
Replace Ctrl+H
Research Lookup Ctrl+Shift+O
Reset Char Ctrl+Space
Reset Char Ctrl+Shift+Z
Reset Para Ctrl+Q
Revision Marks Toggle Ctrl+Shift+E
Right Para Ctrl+R
Save Ctrl+S
Save Shift+F12
Save Alt+Shift+F2
Save As F12
Select All Ctrl+A
Select All Ctrl+Clear (Num 5)
Select All Ctrl+Num 5
Select Table Alt+Clear (Num 5)
Show All Ctrl+Shift+8
Show All Headings Alt+Shift+A
Show Heading1 Alt+Shift+1
Show Heading2 Alt+Shift+2
Show Heading3 Alt+Shift+3
Show Heading4 Alt+Shift+4
Show Heading5 Alt+Shift+5
Show Heading6 Alt+Shift+6
Show Heading7 Alt+Shift+7
Show Heading8 Alt+Shift+8
Show Heading9 Alt+Shift+9
Shrink Font Ctrl+Shift+,
Shrink Font One Point Ctrl+[
Shrink Selection Shift+F8
Small Caps Ctrl+Shift+K
Space Para1 (single spacing) Ctrl+1
Space Para15 (one-and-a-half line spacing) Ctrl+5
Space Para2 (double spacing) Ctrl+2
Spike Ctrl+Shift+F3
Spike Ctrl+F3
Start of Column Alt+Page Up
Start of Column Alt+Shift+Page Up
Start of Doc Extend Ctrl+Shift+Home
Start of Document Ctrl+Home
Start of Line Home
Start of Line Extend Shift+Home
Start of Row Alt+Home
Start of Row Alt+Shift+Home
Start of Window Alt+Ctrl+Page Up
Start of Window Extend Alt+Ctrl+Shift+Page Up
Style Ctrl+Shift+S
Style Separator Alt+Ctrl+Return
Subscript Ctrl+=
Superscript Ctrl+Shift+=
Symbol Font Ctrl+Shift+Q
Task Pane Ctrl+F1
Thesaurus RR Shift+F7
Time Field Alt+Shift+T
Toggle Character Code Alt+X
Toggle Field Display Shift+F9
Toggle Master Subdocs Ctrl+\
Toggle XMLTag View Ctrl+Shift+X
Translate Pane Alt+Shift+F7
Un Hang Ctrl+Shift+T
Un Indent Ctrl+Shift+M
Underline Ctrl+U
Underline Ctrl+Shift+U
Undo Ctrl+Z
Undo Alt+Backspace
Unlink Fields Ctrl+6
Unlink Fields Ctrl+Shift+F9
Unlock Fields Ctrl+4
Unlock Fields Ctrl+Shift+F11
Update Auto Format Alt+Ctrl+U
Update Fields F9
Update Fields Alt+Shift+U
Update Source Ctrl+Shift+F7
VBCode Alt+F11
Web Go Back Alt+Left
Web Go Forward Alt+Right
Word Count List Ctrl+Shift+G
Word Count Recount Ctrl+Shift+R
Word Left Ctrl+Left
Word Left Extend Ctrl+Shift+Left
Word Right Ctrl+Right
Word Right Extend Ctrl+Shift+Right
Word Underline Ctrl+Shift+W
on Dec 03, 2009 | Computers & Internet
Facebook login problems
Hello... try this...
Check your browser Zoom settings--usually in the 'View' or 'Tools' menu on your browser toolbar. Standard setting is 100%--you can reset to 100% by pressing and
holding the CTRL key and press 0 (zero).
OR
Most computers support quick change keys: press and hold CTRL key and press - (minus) to reduce or CTRL + (plus) (SHIFT = ) to expand. [CMD instead of CTRL on MACs].
OR
Press and hold CTRL key and turn the scroll wheel on your mouse. One direction to enlarge, other direction to reduce.
Drawback is you may 'lose' the outside edges of your page if you enlarge over 100%
Aug 10, 2014 | Facebook Apps
Google hangouts
you can start an incognito/private browsing session by pressing ctrl+shift+n (in chrome) or ctrl+shift+p (in explorer) then head to gmail.com and login into your account.
Jan 31, 2014 | Computers & Internet
Where can i find a printable page to print all the controls and functions on lock on moder air combat please help
Scroll Lock Key nearest air target Alt + Scroll Lock Key center-of-view air target Shift + Insert Key next air target Shift + Home Key previous air target Shift + Scroll Lock Key nearest ground target Ctrl + Num Lock Key center-of-view surface target Shift + End Key next surface target Shift + Delete Key previous surface target
MISSION EDITOR Ctrl + N Key create a new mission Ctrl + O Key open an existing mission Ctrl + S Key save the active mission to disk Ctrl + Shift + S Key save the mission under another name Esc Key delete the current selection on the map Delete Key delete the current selection on the map Ctrl + Shift + C Key assign the active mission to a class and protect it with a password Ctrl + Shift + D Key declassify the active mission Ctrl + H Key hide or show specific objects on the map Ctrl + 1 Key return the map to the default magnification level around the crimean peninsula Ctrl + + Key magnify the map by a factor of 2 Ctrl + - Key scale the map down by a factor of 2 Ctrl + O Key take the view down to a very close level Ctrl + V Key magnify the map to a regional view centered on the selected object Ctrl + B Key view and edit the mission briefing Ctrl + D Key view a debriefing when a saved mission is loaded Ctrl + F Key start the current mission Ctrl + N Key begin a network multiplayer session Ctrl + M Key chat with other players during a multiplayer session Ctrl + R Key start the mission and record a video sequence Ctrl + P Key play back the last recorded video sequence Ctrl + V Key start the video sequence and enable its editing Ctrl + Shift + F Key specify failures that may happen to your aircraft Ctrl + Shift + W Key specify meteorological conditions Ctrl + Shift + E Key open encyclopedia Ctrl + Shift + O Key open options screen F1 Key help F2 Key keyboard command list
Feb 27, 2011 | Video Game Consoles & Games
Terminals shutting down after minutes of inactivity goes back to user name screen
check screen saver time, also look at Power on the Screen Saver Tab, it may be set to low time, change it to 20 mins for "TunOff Monitor" and other settings like Hybernate etc
Dec 07, 2009 | LXE VX6 64MB 1 ANT 10 Inch INDR QWR ANSI...
Wyse 3125 CE
when the terminal is logging of select ctrl-alt-esc and it will come up with login screen where you can just login as administrator
Nov 14, 2008 | WYSE V90 Network Terminal
Compaq laptop can't get the ? symbol
Looks like the French keyboard mapping is still in effect.
You can try changing the keyboard keys back to where they were by pressing:
Left CTRl + left Shift at the same time. then try typing the ?/ key. You may have to try this a couple of times to get it to work.
If it does work, try the right ctrl/left shift key.
Also found this:
Control Panel, Regional and Language Options, Keyboards and Languages,
Change Keyboards. Select the keyboard you that's causing you grief and
choose Remove.
If you don't remove the keyboard map, when this switch happens, you'll have
to exit the application you're in (Outlook, for example), change keyboards,
and restart the app. Changing keyboards without restarting the app doesn't
seem to change the mapping.
Hope this helps!
Sep 06, 2008 | Computers & Internet
White screen
how do you flash the firmware using pc. can u tell the procedure
Apr 27, 2008 | Nokia 9300 Smartphone
LXE MX6 Portable Terminal Logo
173 people viewed this question
Top LXE Computers & Internet Experts
Alun Cox
k24674
Are you a LXE Computer and Internet Expert? Answer questions, earn points and help others
