Question about Dell E173FP 17" LCD Monitor
Dell E173FP I have a problem with my flat screen E173FP and I was wondering if you could help. The screen switches on fine but the screens main menu keeps poping on and of. I can control the menu from the monitors buttons but as soon as I switch it off it switches back on. This has been happening for about a week and yesterdey a white padlock with a lilac background kept on popping up as well as the menu. İt is an open padlock then a closed one. I have no idea what to do. I have read through my manual and tried everything I thought would help but with no luck. Could you please help me. yours sincerely F.B.
    Problem Solver:
  • 9 Answers
I have a Dell E171FPB monitor that had the same problem with the Main Menu coming up and I thought I would tell you what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back cover.
At the bottom of the monitor case, there is a small circuit board the holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence while holding the switch with a pair of needle nose pliers. I had to rotate this process from one prong to the other while all the time applying slight pulling pressure on the switch pulling it away from the circuit board.
8. Once the switch was removed, I put the cover back on and tightened up the five screws.
9. Then I slid the base back in the slot it came from and tightened the four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so very happy.
Posted on May 30, 2008
On this monitor you can unplug the buttons completely and the default for it is to be on so if it is the button controller the problem should stop. you will however need to switch it off and on at the wall. all you simply need to do to get rid of the buttons is take the back off and just unplug them, they are the one serial plug on the opposite side of the unit to the either 2 or 4 smaller plugs which are for the display backlight.
Posted on Aug 27, 2007
  • 30 Answers
Please try to check your menu micro switch, the connection and lastly is the mainboard problem. If you have enough tech experience and tools to repair this type of mainboard, then i will show you what's the problem. If you try the above method also can solve this problem, then the mainboard is defected. You can check the crystal, eeprom ic (or the data may be need to reprogram), MCU Chip(Micro Controller Unit). The above component may be defected, dry joint and the program inside eeprom or mcu need to reprogram. If you need more info you can try to this website: http://www.fastrepairguide.com
Posted on Jul 06, 2007
SOURCE:
Monitor switches on then goes into stanby
No input from Video card, try to connect second video cards head to your monitor.
Apr 19, 2010 | Dell E173FP 17" LCD Monitor
DELL E173FP 17 IN. FLAT PANEL
try to find on ebay base that you can fix at the back of the screen where there is the wall fix
Jan 17, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
White screen on monitor
o cant suggest anything appart from buying a new one sorry.
please rate my help to you.
thank you
Apr 22, 2009 | Dell E173FP 17" LCD Monitor
LCD Main MEnu
hi,
It is possible that menu button on the monitor is stuck. I suggest to call your computer manufacturer where you purchased the monitor, check for the warranty and request for a replacement.
Keep me posted.
Thanks
Dec 03, 2008 | Dell E173FP 17" LCD Monitor
Dell E173FP
there is a programing conflict with the moniter there is not realy anything that you can do but bring it back to the store unles you have skills in programing hardware.
Sep 13, 2008 | Computers & Internet
E173FP 17" LCD Monitor Problem
I have the same problem. It seems like a virus to me, but my anti-virus doesn't find anything. I went to the main menu on the moniter and changed the display time to five seconds and locked the OSD display. Now all the appears is a smaller box showing a lock which goes out in five seconds. It is still annoying, but less intrusive then before. Hopefully, some one will determine a permanent fix for this problem.
Oct 26, 2007 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Monitor
i had a similar issue with my dell E172FPB, I have never seen a E173FP but this link might help you
http://syscon.wordpress.com/2007/07/13/dell-dell-e172fpb-lcd-backlight-repair/
Oct 21, 2007 | Dell E173FP 17" LCD Monitor
E173FP flat monitor
Try pressing and holding the menu button for 15 seconds! That should unlock the controls! Regards, babb
May 08, 2007 | Dell E173FP 17" LCD Monitor
Picture doesnt fit whole screen
There should be a right and left alighnment on the OSD menu or an auto button to centre the desktop. Also check your screen resolution as 1280x1024 or 1024x768 should be fine.
Mar 06, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP - After sometime the screen switches off
Sorry not a solution - but I have started experiencing the exact same problem over the last month although sometimes, on switching on again, it will run for 10-15 minutes before the problem re-emerges. Initially I put it down to the v. hot weather in July but it still continues. So I would also appreciate any solutions!
Aug 06, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP 17" LCD Monitor Logo
588 people viewed this question
Clive
Clive
Alun Cox
