Question about Canon D320 imageCLASS Digital Copier
Need more detailed answer to problem of finding stripes on copies.
Someone suggested cleaning something called a "transfer charger." I would be happy to clean it if I knew what it was and where it is located. I can open two ends of my Canon ImageClass D320 copier. I can remove the toner cartridge from one side, but I need more details. Can you please help? THANK YOU! Brookston
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
  • 69 Answers
Hi im jules_09,the transfercharge is located at the lower part of the drum process unit youll need patience cleaning it.
Posted on Oct 04, 2007
I have a problem with a bizhub C203 what can i do?
Verify the problem is in the imaging units or the transfer belt units.Remove the transfer unit and clean on vacuum cleaner the transfer belt cleaning blade.If you see the stripes on transfer belt after cleaning is work normally.If not observ stripes on transfer belt the problem is located in imaging unit.Enter in service mode :Press Utility key-Meter count- Details-Stop 00-Stop01 Select Test mode-select Gradation test pattern and select the Cyan press Start,after select Magenta Press Start,Yellow +Start,Black4+Start.If any color test pattern is not graduate the problem located to image unit when is not graduaTE.
Jul 28, 2014 | Konica Minolta bizhub Office Equipment &...
Our copier were printing fine and then all of a sudden the copies started coming out very light. It isn't a toner issue because we replaced it with a new one and even tested it with another new one....
It sounds like you need to do preventive maintenance ( cleaning of laser unit, copy optics, replace transfer and everything that is in HP PM KIT )
Call service!
Sep 09, 2011 | HP LaserJet 8000n Printer
I have a white stripe on the copies. I just installed a new toner cartridge, and cleaned the transfer charger. I have a Sharp AR-162S copier that is 3 - 5 years old. Thanks.
Hi check the developer unit make sure it is coated end to end some times the blade on the developer gets foreig matter stuck and prevents the developer/toner to go onto areas of the developer mag roller also check and make sure the transfer corona wires are in good condition no black marks on the corona wire if there is replace the wires
Feb 15, 2011 | Office Equipment & Supplies
I am getting a one-inch gray stripe at the top of each copy, and a half-inch stripe at the bottom of each. I think I've cleaned everything ... platen, narrow glass, rollers, etc. ... and it's lightened,...
there is no corona wire but a primary charging roller pls clean it if both ends of the roller looks rough or cracky try replacing it and clean transfer roller as well.
Jan 01, 2011 | Canon imageRUNNER 2200
My ir 400 gives a white spot
something could be blocking the primary chargeing corona wires/roller. i see it a lot on the ir 5000 when the primary corona assmbly cleaning pads get stuck half way through the cleaning cycle.
Jun 16, 2010 | Canon imageRUNNER 400S Copier
Why does minolta copier print white stripes?
TRY TO CLEAN AND CHECK MAIN CHARGER AND TRANSFER CORONA FOR VOLTAGE LEAKAGE,AND CHECK DEVELOPER GEAR AND DEVELOPER DRIVE GEAR
Dec 03, 2008 | Minolta EP1030/1030F CS/PRO Copier
White stripes on pages copied from ARM 205
If you changed your developer? Or did you change the Toner Cartridge?
White stripe? Check the charge on the drum, it might have a piece of dust on it.
take the charge out, (dont take it apart) hold it up to some light, you might see some dust particles hanging in the grid. If so, rub very lightly with finger, do not use a cloth to clean. Blow it with a can of air.
Clean the transfer charge as well
Usually replace those as it is such a pain to clean on the smaller machines.
if you need any further help let me know
Thanks
Nov 05, 2008 | Sharp AR-M205 Copier
When I fax docs, it is received with stripes and stains
first check the printer by copying something,here u can see the problem that u r telling me,or check it by scanning something in ur computer,if u can see that problem,all u have to do is,open the top glass cover, under the top cover thers a scanning unit(lamp unit),in that scanning unit ther are some mirrors clean that mirrors with cotton bud,clean the top glass,n fix everything again,problem will be solved
thnx N
Jan 29, 2008 | Samsung SCX-4216F All-In-One Laser Printer
AL1631 Striped copies.
clean the scanner lens UNDER COrNER OF AUTO DOCUMENT FEEDER
Jan 24, 2008 | Sharp AL 1631 Copier
Black stripe on copies
Please be more specific.
Are the lines appearing in the direction the paper exits the machine, or from the front of the paper to the rear?
Jan 09, 2008 | Office Equipment & Supplies
138 people viewed this question
Clive
Clive
old marine
old marine
