Question about Brother MFC-990CW COLOR INK-JET MFC Ink Jet Printer
New Cartridges are printing dull
I Changed the Colour settings to Greyscale because I ran out of Yellow and It wouldn't print anything, Now since changing the Cartridges, (and changing the settings back to color) everything is coming out Dull, the Black is grey and the colors are very dull. I've changed the settings to vibrant and back again and I've done a clean and the black and color tests come out fine.
    New Friend:
Make sure inck is in wright
Posted on Apr 03, 2012
SOURCE:
  • 3 Answers
SOURCE: print quality is lousy
Something has become clogged. It's unlikely to be a driver problem etc... I would make the following suggestion. 1. You can buy ink refill kits (they'll also save you a lot of money). This kit usually includes a flushing fluid. Now with many printers if you change the cartridge, most printing problems go away... however it sounds like the part that hooks into the cartridge has become clogged. Try cleaning this out with the flushing fluid. YOu may be able to buy this fluid without the ink refill that normally comes with it. Not sure. It really does sound like the part that connects the cartridge and feeds the ink has become clogged. So cleaning this out should fix the problem. Some ink jet cartridges have the printer head built in and other don't; it's part of the printer hardware. If your's is part of the printer hardware then you'll need to flush this out with an ink flushing fluid as mentioned above. Basicly this type of problem usually occurs when you don't use the printer for an extended period of time and the ink dries causing a clog. This clog can not always be fixed by the cleaning cycle so you have to use ink flushing fluid. 2. Before doing this contact tech support for your printer. All though it is not in warranty many companies continue to give tech support for hardware products such as printers without additional charge. They may know exactly what the problem is and provide a solution that you can perform without sending it in for repair. If your printer's manufacture does not give tech support beyond the warranty period then tell them you need tech support for the ink cartridge you just bought (even if it's not thier brand, just tell them it is) ... and see what suggestions they give to resolve the problem... otherwise try the above solution. Best of luck. Sincerely, Dean Dean Kenneth Robinson [email protected]
Posted on Aug 16, 2006
silly girl
  • 513 Answers
SOURCE: colour printing
Check the following thread, it might apply to your problem. and just as a printer can be fooled to show a low level ink, I guess it can happen the other way around. http://www.fixya.com/problems-solutions/t103191,p342983/Epson-Stylus-Photo-R300-InkJet-Printer.aspx Good luck
Posted on May 24, 2006
SOURCE: My Epson RX620 black cart absolutely will not print
Problem Solved!!!!
I bought the special cleaning cartridge as suggested and it worked very well. My RX620 is working like new!
Thanks!
Posted on Jul 11, 2008
proartya8765
  • 581 Answers
SOURCE: canon mp530 - colors print dull and faded
The ink tanks may be full but sometimes the pins that connect the cartridges to the printer may have dried up ink on them preventing the ink from flowing. You can try to swab these with a bit of rubbing alcohol on a Qtip and letting it dry for moment or two. I would strongly suggest doing a couple of deep cleanings first and try test printing of the individual colours separately in a program such as paint to see which colour is affected.
Posted on Jan 25, 2010
SOURCE: My epson sx205 keeps printing wrong colors: blue
Don, you are a moron, the Red is leaching out? Why don't you take your epson printers and shove them up your ***. I've owned 2 of them...FORTUNATELY one came free with a purchase of a new PC...THATS HOW MUCH GARBAGE YOUR PRINTERS ARE...HP completely blows EPSUCK away.....HE TOLD YOU HE USED FACTORY CARTRIDGES...Funny, I am having the same problem with my black that won't print at all...do you suggest the black has been leached? Your a horrible EpSUCK expert...not go let your dog lick the peanut butter out of your ***...
Posted on Apr 12, 2010
Can i only print in black and white on my pixma mp250?
First you need to check your printer preferences/settings and check "Greyscale" printing box is unchecked (no tick or cross) if so then its a printer problem.
I'm guessing it has 2 cartridges, on colour and one black. As a guess the colour print head has become blocked. You can try clearing it with the printer clean functions, but this invariably just wastes your ink. You need to get a print head cleaning kit. PC shops or ebay.
Sep 01, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I have the PIXMA MP500 & 3 of m ink cartridges #8 blue, magenta & yellow ran out of ink but I have a brand new #8 black & #5 pgbk that I changed. Now I just want to print from the black ink...
Unfortunately, the printer is designed to need all of the ink cartridges in place and no empty ink cartridges. This is designed to protect the ink system from damage.
There is a way to print a color document in black and white but it won't help with your issue. (Enter the Printing Preferences by right clicking on the icon for the Canon MP500 in the Devices and Printers Panel (Win7). (It's Printers for the Vista Classic View and Printers and Faxes for XP) Then put a check mark in the box for Greyscale Printing in the main tab. Then click OK and close the window. There is a similar method for Mac OS versions.)
I wish that I had better news.
Jan 03, 2011 | Canon Pixma MP500 All-In-One InkJet...
My Samsung CLX-3160FN has stopped printing colour. I have changed all the cartridges and it will copy in colour, but prints in black and white.
You need to check your document print settings on your PC. Drill through the printer properties menu until you get to the colour settings. At a guess you currently have it set to "Greyscale" rather than colour or auto.
May 03, 2010 | Samsung CLX 3160fn All-In-One Printer
Canon ip4300 color ink empty but I only want black
No, Canon does not have this facility. Also mostly greyscale is not light black but rather a mixcture of the 3 primary colours. You should have a reset/resume button on the printer - hold this in for a slow 5 seconds to de-activate ink warnings per cartridge that is giving alarms. Proceed carefully and only print text that is black so that the colour printheads do not burn out.
Feb 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
No Printed documents
Have you performed a print head cleaning? If not, follow the instructions below:
1) Press <Menu> on the panel repeatedly until [Maintenance] appears on the display
2) Press left or right arrow buttons until the cleaning setting you want appears, either [Head Cleaning] or [Head Refreshing]
3) Press the <OK> button.
Note: Head cleaning should be attempted first, and may need to be done more than once. Examine the results of the test page.
Head refreshing is more aggressive, uses more ink and should only be performed when necessary (ie. when multiple head cleanings failed to solve your print problem).
Dec 20, 2009 | Canon PIXMA MP780 All-In-One InkJet...
The ''odometer'' shows greyscale as colour
Any machine I'm familiar with has a default colour setting that you can set to either colour or black & White. Check in your printer properties. If the machine is set for colour, even if you are printing all black text for example, it will "make" the black from the colours, thus registering it as a colour document.
Jun 22, 2009 | Canon Office Equipment & Supplies
Installed new yellow print cartridge for HP printer, prompts to install new cartridge but my ink level says full
I have this same problem and some sites said to uninstall the software then download the software from the HP site and reinstall it. So I am giving that a try tonight
I’m happy to assist further over the phone at https://www.6ya.com/expert/barbara_87cfe34e34050f26
May 29, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printer needs all cartridges for black.
Load the empty slots with cleaning cartridges and set the printer to greyscale.
Feb 23, 2009 | HP Business InkJet 2800 Printer
No Colour - everything in greyscale
just go to printing preference set to color and not to grayscale
Apr 20, 2008 | HP Deskjet 2360 InkJet Printer
Brother MFC-990CW COLOR INK-JET MFC Ink Jet Printer Logo
903 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
