Question about HP DeskJet 1220c InkJet Printer
Printer running too slow
My Hp Deskjet 1220c is taking hours to print even black and white documents. The print quality is good and it has new cartridges. A while back it seized when i tried to print 100 pages and inspite of re-installing soft ware it hasnt performed to speed since. I have tried trouble shounting but no luck . it is hard wired to a USB port on my Toshiba A30 laptop and I should have enough spare memory to perform the printing
  • 2 more comments
  • nerd4rent Nov 26, 2007
    Same printer, Parallel interface to desktop. One day its fast, next day and every day since it has been painfully slow but prints correctly.
  • Zeggy Jan 23, 2008
    Just took 34 minutes to print a test page, after changing both cartridges. Yellow light flashes continually.
  • Anonymous Apr 10, 2008
    my printer prints very slowly, the printer heads sweeping the page about 2 - 3 times a minute. whilst it is printing the green light flashes continuously as though the printer is still accepting data into its memory. will try cleaning white band as suggested, if this fails any other ideas?
  • melodeon Apr 11, 2008
    Same as 'guest' -"my printer prints very slowly, the printer heads sweeping the page
    its memory. My white band isn't dirty and it's been slow since new.
    Bought in a package with a G4 mac in 2002 my dealer suggested it might be a sofware problem.
    A friend of mine thinks they're wonderful but still uses '90's software and operating systems.
    I once tried the HP website and gave up after too long. Driver update?
This worked for me, open the lid of the printer, there is a "white band" attached to the 2 printer cartridges, this was "smudgy" with ink, got kitchen paper and cleaned it and used q tips (I normally clean my ears with them) and got rid of the sludge and dust located on the floor underneath the printer cartridges. After that printer is working fine, hope this helps!
Posted on Jan 24, 2008
Hp dj 1220c printer driver refused to install on my windows 7
Try to reset the factory settings: Go to Settings tab and press the Resets option. This will change all the settings to default factory settings. Try to print using another OS and check if there is a difference in the print quality. Try to print in draft mode and in FastRes 1200 mode. Tip and tricks for all deskjet setup
https://123hp.co/hp-deskjet-printer-models
Oct 28, 2013 | HP DeskJet 1220c InkJet Printer
My HP DeskJet 1220C printer prints only 1 page at a time. I must push the print button each time! How can I get it to just print the entire document without pushing the button?
You may have it set to manual feed. Check printer setting on desktop. You will have to do a little searching. Printer options vary quite a bit. Start by right clicking printer and choosing Printer Preferences > Paper/Quality > Paper Source. This is my route, but again yours may vary.
Aug 28, 2012 | HP DeskJet 1220c InkJet Printer
My HP 1280 printer does print black and white text
Could it just be that the black cartridge has run out? If not, try and clean the print heads. You should be able to do this in the printer options in Windows. It is more than likle that the black nozzle is blocked.
Dec 13, 2009 | HP DeskJet 1280 InkJet Printer
Not a colour printing
Please make sure that you are using the correct driver for this printer.
HP releases a monochrome (Black only) driver and a full driver.
May 09, 2009 | HP DeskJet 1220c InkJet Printer
Printing is very, very slow
Issue The printer is printing slow. Solution Follow the instructions below to manually select the paper type and print speed.
  1. In the application you are printing from, click File , Print , and then Properties . The Printer Properties screen opens.
  2. Click the Paper/Quality tab.
  3. Change the Print Quality from Automatic to the desired setting.
  4. Change the Type is selection from Automatic to the appropriate paper type that you are printing on.
  5. Click OK .
Mar 03, 2009 | HP - HP Photosmart 8250 printer
My HP 1220C cant print in colour
check printing preference on color tab.
Feb 27, 2009 | HP DeskJet 1220c InkJet Printer
Slow printing of hp 3940 deskjet printer
You might be printing in a different mode...you can see it in the printing preferences tab(fastdraft, fastnormal, normal and best quality )... or are you directly connected to the printer? or in a LAN? try using a different usb port...
Aug 27, 2008 | Microsoft Windows XP Professional With...
Wont print
some printers share the ink from color to black but you can select if you wants to use only black just go to printer than properies than select to use only black but you probably have to remove the empty color one
Dec 18, 2007 | HP DeskJet 3940 InkJet Photo Printer
HP Deskjet 1220C cartridge recognition problem
This happens when the connections on the cartridge get old. Especially when you refill or buy non HP Cartridges, try buying brand new hp cartridges and you might be able to get a couple refill out of them before this happens again.
Feb 09, 2007 | HP DeskJet 1220c InkJet Printer
HP DeskJet 1220c InkJet Printer Logo
275 people viewed this question
Clive
Clive
