Question about Konica Minolta DiMAGE Z3 Digital Camera
Lcd/viewfinder THe LCD screen looks as if there is a shutter, for lack of a better description, nearly closed. Only a sliver of view is available. It appears that way with both the picture taking and playback mode. The eyepiece looks different than normal, but at least can be used. Photos come out just fine. The same thing happened last week, and then all of a sudden it was OK. Did I mistakenly change a setting? Any suggestions? Thank you!
    Top Expert:
  • Konica Minolta Master
  • 83,850 Answers
Is the lens cover completely retracted? Look at it.
Posted on Jun 27, 2017
3 Suggested Answers
SOURCE: Black LCD screen and viewfinder in photo take mode
Sony (who bought KM) will fix this for free. http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131
Posted on Jun 01, 2007
SOURCE: LCD Screen dead
I have received a Dimage Z6 as a gift as well and experienced the same problem. The manual page 17 (mine is Danish) says in a callout how to switch off the LCD screen - hold the flash button while pressing the I+ button until the image appears in the viewfinder (the red diode is lit).
How to get the image back to the LCD screen? Hold the flash button while you press the MENU, QV and I+ buttons sequentially. MENU - wait for the beep, then QV - wait for the beep, then press I+ until the image reappears on the LCD-screen (the red diode is lit). If the screen is in playback mode, press MENU briefly to get it on-line.
With MENU > SETUP > power save you may play with the timing. I have found out how to the LCD-screen on at POWER ON. I have to switch from the viewfinder each time.
Best regards
Anders
Copenhagen, Denmark
Posted on Feb 17, 2008
When tKing a picture...should my subject appear in the view screen window...the big screen? Or do you have to look in tiny scdeen to see subject when taking a picture?
Use the largest screen to get a better idea of the focus. Smaller screens lack the resolution to show a slightly unfocused shot - but it will be noticeable later when printed or viewed on a large screen. Of course, these screens eat battery life - so you can use your optical viewfinder whenever possible.
Sep 26, 2015 | Canon EOS Rebel XSi Digital Camera
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
Can't take any photo with my Canon S3IS any more. The view finder and the screen is black when I try to take some photo but I am able to see all photo that is already on my memory card in the view finder...
Look into the lense while setting the shutter speed at a half second or so (slow enough for you to see the shutter open and close) and click the shutter release... you should see the shutter open and close. If you don't see this, then you may have a 'sticky shutter' resulting from lubricant seeping into the shutter/aperature mechanism and preventing the shutter from functioning as it should.(Common problem reported with the S2 and S3 cameras... and probably the S1 as well)
I have gotten my S3IS to take pictures by turning on the power, then opening the battery compartment door and reclosing it repeatedly until the shutter opens (from the power surge) and an image appears on the LCD.
After confirming the sticky shutter was indeed the problem, I pursued a more permanent fix.
Jan 30, 2011 | Canon PowerShot S3 IS Digital Camera
My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
Feb 07, 2010 | Canon PowerShot A620 Digital Camera
Problem with canon a420 digicam
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Sep 21, 2009 | Canon PowerShot A420 Digital Camera
When I turn on my camera the screen is blank
Do the icons show up on the screen or is it totally blank?
Can you view previous pictures?
If the icons show on the screen then have a look into the lens to see if the shutter is closed over the inner lens. you may have to adjust the zoom to bring the inner lens and shutter mechanism up close to the outer lens to get a better look.
If the shutter is covering the inner lens then it is stuck and will need to be freed by opening the camera up.
If the screen is just black then it just may be possible that the ribbon for the screen has partially slipped out of it's socket on the main board.
If it comes out all the way then the camera should not even power up.
Jul 27, 2009 | Fuji FinePix A800 Digital Camera
Why does the scene i'm looking at not show on the lcd screen until i've already snapped the picture?
Because this camera does not have a Live Viewing option like all smaller point and shoot cameras have. To give you a live view on the LCD would require the shutter to be open constantly. Only some DSLR cameras offer this function which requires a second sensor in the camera. You are best using the manual viewfinder anyway as it will result in better pictures and you can determine focus better too.
Jul 02, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Black lcd screen on Ixus 70 shows icons but will not take picture
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Wierd pictures
This is caused by a shutter that is stuck open. Normally the shutter closes right at the moment that you snap the picture and allows the image sensor to record what it saw at that moment. When the shutter does not close as intended the image sensor cannot properly record the image. This is why here are the lines across your images. The shutter can stick either due to an impact knocking the delicate blades off their tracks, or due to dust or moisture contamination sticking them open or closed. If gently tapping does not free them; the camera will require professional repair. David Millier Advance Camera Repair
Feb 15, 2007 | Fuji FinePix A330 Digital Camera
Konica Minolta DiMAGE Z3 Digital Camera Logo
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
