Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
IXUS 700 zoom problem
Hi, One year before I brought canon IXUS700 digital camera. It was working fine till last week. Last week I suddently found that the zoom button is not working. I do not remember any dropping of the camera. I can not use zoom button in any of the mode. All other functions are working fine. Can anyone guide what should do to rectify this zoom button problem? Thanks & Regards Suresh
    Genius:
  • 2,985 Answers
Contact customer support If has been dropped a repair price maybe well on the way to replacing the camera
Posted on Aug 01, 2007
Canon PowerShot G2 buttons don't work
You have a bad button board . This is a single board with a series of small button switches that control all these functions. Most repair shop will charge around 75.00 to fix.
Jul 01, 2009 | Canon PowerShot G2 Digital Camera
Power Zoom Lever Doesn't Work
Hello, please try to use the memory stick. If there is a message MS error, please look at this picture. Best regards, Arpi If you need more info please advice.
Jul 11, 2007 | Sony Handycam DCR-PC105 Mini DV Digital...
Digital Zoom not working and screen is blurry
Your zoom probably does not come out all the way and therefore you get some blurry shots. Had the same problem on a Panasonic camera. Solution: replace zoom motor and gears. Results=expensive. Goes beyond the value of the camera. You might want to buy another used A85 or newer digital camera.
Oct 21, 2008 | Canon PowerShot A85 Digital Camera
Zoom button of canon elura minin dv
I had a similar problem. Searching Google for a solution, I came across the old -- "if it doesn't work, smack it" trick:
Remove any tape in the camera.
Remove the battery.
With your hand holding the top of camera, hit it firmly with a book on the bottom. I used about a 200 page paperback.
I suspect it is a electro-mechanical switch that gets stuck in the "On" position, and a little jolt frees it up again.
I have done this twice in the last month, and it works great.
Aug 29, 2008 | Canon Elura 60 Mini DV Digital Camcorder
ZOOMING PROBLEMS W/PowerShot SD850 IS
Hi
Make sure you are pressing the button half way and getting the 'beep' that the camera is ready to take the picture before pressing the button all the way down.
Also make sure you have good lighting conditions and use the flash if needed.
Last, make sure you are still in optical zoom and not digital... I would suggest turning off digital zoom, I don't recommend using it at all.
Hopefully this helps..
Thomas
Apr 13, 2008 | Canon PowerShot SD850 IS Digital Camera
Does it need regular cleaning?
Sand generally has no effect on the electronic side of the camera, however it will definitely can cause problems with the mechanical aspect of the camera such as the zoom lens. this can be removed with a can of compressed air.
Suntan lotion likewise should not be any problem except for smudges on the housing/casing and especially bad for the lens. Additionally, the lotion would help the sand adhere to crevices and nooks of the camera. Wiping should get you just fine.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 17, 2008 | Canon PowerShot SD600 Digital Camera
Zoom not working at all
You have a one year warranty with Canon, you should have all the information about shipping it to them in your original box.
Dec 17, 2007 | Canon PowerShot S3 IS Digital Camera
Canon Elura 60 zooms by itself
Listen, I know it's a couple of years after this post but, try this: Remove cassette, push to close, close camera as if to use it, hold firmly in left hand, open hand slap it with your right hand once or twice, (I'm not joking) it worked the two times I had this problem. Problems with the zoom? Almost same process, push firmly on zoom button (to un-zoom) try doing this as your tapping it. These are last ditch efforts on an aging camera, it really has been a good one. I've put this poor thing through years of abuse, and it's held up pretty well. Good luck, Jeff S.
Oct 16, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Canon Powershot S1 IS - Both in LCD and View finder - only blank is coming
Sorry this aint a solution. I too have the same problem as Mr.Gandhi is facing. I too bought this camera approximately 2 years ago.Since last cupla weeks, im facing this problem on a random note...I cud take a few snaps in between and upload without any problem but again the camera could not capture new images even with a set of 4 new batteries. Whenever i switch the mode to take snaps from preview mode (which is still working fine), the LCD or the view finder becomes dark with some blue colored horizontal lines appearing as if its because of some kinda interference!
Dec 27, 2006 | Canon PowerShot S1 IS Digital Camera
Canon Elura 60 - Zoom is on maximum and won't restore. I own Canon Elura 60 since last two years and now i'm facing problems with zoom. Zoom button does go to and fro but actual zoom doesn't take...
Hi There, did you find any resolution for this problem? If you could share any info about the problem, it will be really great. Even I have the same issue with my Elura 70. Thanks.. Pradeep
Nov 08, 2006 | Canon Elura 60 Mini DV Digital Camcorder
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
164 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
