Question about RCA 27F530T 27" TV
RCA 35" Home Theatre
I am an owner of an 35" color tv and the picture goes fuzzy and buzzes with a loud noise for a few minutes into the show, this continues to happen as long as he tv is on. I can wiggle or hold the antenna connection or the antenna wire in the back and the picture clears right up, once I release either the tv starts to mess up again. I look forward to hearing from you soon. Sincerely, Cassie Lard cassielard@aol.com
    Sergeant:
  • 337 Answers
You have diagnossed the problem by moving the antenna imput,the problem might be a loose conection in the tuner itself,the grounds ussually get loose and need to be resoldered,if you are familiar with tv service you can resolder all the pins and grounds,there is another possibilty and that is the conector itself where the antenna screws is loose and it has broken the solder conection inside the tuner and the will have to be taken apart and resolder,the conector has to be solid .You have an option and is using the aux,1 or 2 and coneting you vcr to either one those imputs then you will need to change the channels thru the vcr,this way you will not have to worry about the tuner.Let Us know how it goes or if you need more information.
Posted on Oct 30, 2006
  • Omar Urrutia
    Omar Urrutia Oct 30, 2006
    Your rating response is also important.
SOURCE:
Loud humming or buzzing noise have picture but flashes all different colors resets and goes off after awhile good pic after that
The tv problems and causes are 100% is the tv colors wheel it is causes and the tv problems.The tv are having humming or loud buzzing noises sounds are the causes of the tv colors wheel going off and out control of it motor mount and spinning in at high RPM speed and different colors showing up or flahes of black and white color in the tv back ground.The tv colors wheel must have to be replace.Best hire a tv tech to do the replacement of the tv colors wheel,because have to take out many mechanicals parts before can even come to the tv colors wheel is self to replace it.
Aug 19, 2011 | Samsung HLP5067W Television
I'm experiencing a loud buzzing (fan?) sound that just started recently while watching my HLP5674W. The picture is fine, but the sound of what may be a fan or something like that is very loud and will...
Loud sound would be coming from defective color wheel that is mounted i light engine, next to lamp housing. Replacement of color wheel is required expertise/ experience and professional will do that for you in correct and in safe manner.
Contact local tv repair shop to get color wheel replaced in tv.
Thanks.
Oct 19, 2010 | Samsung HLP5674W 56" Rear Projection...
Makes buzzing sound and no picture lamp?
Buzzing sound is the Color Wheel # BP96-00250A $83.25 Encompass Parts has them in stock 1-800-638-3328 and for Lamp Call FOX 1-800-227-5369 I got my Lamp off of E-Bay $85.00 I have the Same TV.
Dec 24, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
I have a 35 inch older model.heavier than heck....
this is fixable, normally it is caused by a capacitor or an ic, but it is fixable
Sep 04, 2009 | RCA 32V550T 32" TV
Have to push power repeatedly to get TV to turn on, b&w picture
the CRT is obviously very old and discontinued ,I would recomend investing in a new set
Jun 11, 2009 | Televison & Video
Vizio makes loud static noise, picture goes fuzzy.
You should check your home wiring and grounding. Also be aware of anything that has recently been turned on when this happens. Anyone using a microvwave, cell phone, or other appliance that might be causing the interference.
Mar 02, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
RCA Home Theatre - Tuner problem
you may coldsolder the tuner first before replacing the new one,maybe it can works.
Apr 30, 2008 | RCA TruFlat 27F520T 27" TV
Loud Buzzing Sound
Sounds like the cooling fan blades are hitting something (possible worn bearings).
Apr 21, 2008 | RCA P52926 52" Rear Projection Television
RCA 27F530T 27" TV Logo
90 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
