Question about Sony Cyber-Shot DSC-W5 Digital Camera
Manual settings - shutter speed not indicated
Long story short, in manual mode, the left-right arrow indicators for the aperture settings still appear on the LCD, but the up-down arrows for the shutter speed suddenly stopped appearing, and now I can't change that setting.
    Genius:
  • 2,985 Answers
Shut down the camera - remove batteries, leave for an hour- reinsert batteries- Did it recover? If no get onto the Sony Technical Support Team - This indicates a firmware failure which they and only they can sort.
Posted on Jul 21, 2007
How do I change the aperture when my camera is in manual mode
You have to hold down the exposure compensation button at the same time as turning the control dial.
The values appear on the control panel screen.
I found this on page 33 of the manual...
Set the mode dial to M and turn the control dial to set the value.
• To set the shutter speed: Turn the control dial.
To set the aperture value:Turn the control dial while holding down the
[+-](exposure compensation) button.
The exposure level indicator appears on the control panel screen, showing the difference (ranging from -3 EV to +3 EV) between the exposure value calculated by the currently selected aperture
and shutter speed compared to the exposure value considered optimum by the camera.
Oct 13, 2014 | Olympus EVOLT E-410 Digital Camera
Tip
How does aperture setting affect a photograph?
The aperture is the opening in the lens through which light passes to the image sensor. Changing the aperture setting allows you to control the depth of field of a photograph. When the aperture is opened to a widersetting, (indicated by a lower f-stop number) more light is passed to the imagesensor, creating more shallow depth of field. Closing the aperture (indicatedby a higher f-stop number) allows less light to pass to the image sensor,creating wider depth of field.
NOTE: The aperture setting is one of three primary settings usedto control the overall exposure of a photograph. The other two primary settingsare ISO and shutter speed. Because the three settings work together to produce the overall exposure for a photograph, changingthe aperture setting will require complimentary changes to either the ISO or shutter speed to produce a properly exposed photograph. These changes will bemade automatically by the camera in the Auto, Program, Aperture-priority andShutter-priority modes.
There are two ways tocontrol the aperture setting on the camera:
  • Aperture-priority mode (A) - When shooting in Aperture priority mode (A), you set the aperture value and the camera automatically sets the optimum shutter speed for you.
  • Manual mode (M) - When shooting in Manual mode (M), you control both aperture and shutter speed, which gives you maximum creative control to achieve the exact results you want.
on Jan 08, 2011 | Cameras
How doI set up f11 on this camera
Do you mean set the aperture at f/11?
If you want the camera to set the shutter speed for proper exposure, turn the mode dial to the A position for Aperture Priority. Press the +/- button to display the shutter speed and aperture. Press cursor-up/down to change the aperture and the camera will change the shutter speed to give the proper exposure.
If you want to set the shutter speed and aperture yourself, turn the mode dial to M for Manual. Press the +/- button. Press cursor-up/down to set the shutter speed, cursor-left/right to set the aperture.
Full details are in the Shooting Mode section of the manual.
Nov 17, 2013 | Fujifilm FinePix S4250 Black 16MP Digital...
What does the shutter speed set on?
To set the shutter speed, press and hold the mode button and then turn the thumb wheel on the right until M (for fully manual control) or S (for shutter priority auto exposure) appears in the display. Remove your finger from the mode button and the thumb wheel will now adjust just the shutter speed. If you're in manual mode the aperture setting will need a separate adjustment for correct exposure, if you're in shutter priority mode the camera will select the aperture suited to your shutter speed for each exposure.
Please take a moment to rate my answer, or if you wish to know anything else please add a follow-up comment and I shall provide further assistance when I'm next online (I'm in the UK and it's just after midnight right now).
Sep 04, 2010 | Nikon N8008 AF 35mm SLR Camera
Light meter or not on Maxxum 4
Yes, it has program, aperture priority, shutter priority and manual modes.The aperture and shutter settings should be visible on both the right hand top plate LCD panel, and also in an illuminate LED panel below the image in the viewfinder.
From memory (and I might be wrong) the Dynax 4 (Maxxum 4 in North America, Dynax 3 in Asia Pacific) light meter simply indicated a plus or minus symbol to indicate over or under exposure for the selected combination of shutter and aperture. The viewfinder display would have a steady dot to confirm confirm focus follwed by the chosen shutter speed and aperture setting.
I cannot find a link to anything other than a German manual, but the diagrams and a bit of mental application will go a long way if you don't understand German.
Note that if your camera's electronics have failed then there's nothing you can realistically do other than to replace it. Spares are not available and as a consumer level model it was never really intended to be serviced or repaired.
Feb 24, 2010 | Konica Minolta Maxxum 4 / Dynax 4 QD 35mm...
How do I change the shutter speed setting on my Cannon a570is digital camera
1. Set the mode dial to "M" for Manual.
2. Press +/- button to select Shutter speed or Aperture value.
3. Use Left or Right arrow key to change the value.
Aug 02, 2009 | Canon Cameras
How to KNOW the light is right 4 an Olympus OM20 Manual camera?
OM-20 was basically a upgraded OM-10 with the manual adapter built in and a number of other refinements.
The viewfinder has LED's to show the shutter speed recommended by the camera's lightmeter for the ISO and aperture selected. It also has an exposure compensation indicator (the +/- symbol) and an indicator for flash ready which doubles up as a post-exposure flash confirmation. There is also the indicator lamp to show manual mode has been selected. OM-10 lacks the manual mode lamp and the +/- indicator.
Like the OM-10, the OM-20 is primarily an aperture priority automatic camera. In this mode you set the ISO film speed, choose which aperture you wish to use (with the ability to use the lens depth of field preview button) and then the camera selects the correct shutter speed. The +/- exposure compensation control allows the user to tell the camera to modify the recommended shutter speed by up to two stops either way.
In manual mode, there is no manual metering. The light meter behaves exactly as it does in aperture priority mode and the viewfinder shows the recommended shutter speed and not the manually selected one. Correct metering is therefore a case of adjusting the aperture first, and then choosing the correct shutter speed indicated in the viewfinder. If the user then decides to select a different shutter speed, then the aperture ring must be adjusted to maintain the correct exposure. For example the aperture is set to f8 and the camera recommends 1/60th of a second. The user decides that a faster shutter speed is required and chooses 1/250th, but the viewfinder remains showing 1/60th. In order to keep the same exposure value the user must open the aperture by two full stops to f4. The camera's light meter will detect the new aperture setting and providing the light on the object is unchanged the viewfinder shutter speed display should now show 1/250th as well to confirm the correct adjustment. Alternatively, the user can choose the shutter speed first by looking at what has been set on the control ring (or by turning the ring to the end of its travel and then counting the clicks from there as all experienced OM users do) and then turning the aperture ring until the shutter speed shown in the viewfinder matches what's been manually set.
It all sounds clumsy and complex but is done far more quickly than I've taken to type this and becomes second nature.
Aperture priority metering is selected on the camera by choosing AUTO on the mode selecter. In this mode the shutter speed ring has no effect and the viewfinder always displays the automatically selected shutter speed.
May 09, 2009 | Olympus OM-2000 35mm SLR Camera
Apperture and shutter speed settings
First select AV (Aperture Mode) to select the required aperture then switch to M (Manual Mode) and spin the wheel until you get the right speed.
Spurs34
Dec 19, 2007 | Canon Cameras
Shutter priority mode?
s I understand it from what I have seen on the Web, the 3000Z can operate in several modes: 1. Fully automatic (camera select both 2. Manual (user sets both aperture and shutter speed). 3. Aperture Priority mode - user sets aperture and camera chooses correct shutter speed to get a good exposure Apparently there is no Shutter Priority mode (user cannot set only the shutter er speed and allow the camera to set the aperature to get a good exposure). This option is available on the Epson 850Z camera and this seems like a silly ommision to make on a "high-end" camera like the 3000Z.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Sony Cyber-Shot DSC-W5 Digital Camera Logo
50 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
