Question about Nautica N07574 Wrist Watch
Nautica Watch Stopped
Hi, My Nautica Watch stopped. I tried swinging the watch from side to side but it still not working. What should I do?
2 Suggested Answers
  • 2334 Answers
SOURCE: discolored white nautica watch band
If your watch band have UV sensitive pigmentation in it, there is nothing you can do, but buy the new band.
Find your nearest jeweller and ask to clean watch band in ultrasonic cleaner for 1 hour. If this kind of cleaning doesn't help, that means your watch band is UV sensitive and is and will be discolouring more and more by the time.
Alternatively you can try to clean it with the lighter fluid (ZIPPO). Soak a soft cloth in to lighter fluid and clean the band. Start with a small area inside band to make sure the fluid is not reacting as dissolver, as some resins react quite vigorously and tend to transform into chewing gum sort of state.
And again- if this cleaning doesn't help, the band is UV sensitive and discolouring is taking place.
That discolouring is happening becouse some of the colour pigments used in resin manufacture are sensitive to ultraviolet light and when exposed to sunlight or daylight, they react in a chemical
way, changing molecular structure, wich we see as the colour change.This process can not be reversed and this is why the band can not be cleaned.
Do not forget to rate please.
Posted on Jan 25, 2009
  • 2501 Answers
SOURCE: Where can I buy a new White Resin Nautica watch band.
If you go to the web site and select "service center" you will be able to see all the service centers. Choose your nearest and ask them.
Posted on Jan 26, 2010
Testimonial: "THANK YOU"
0 characters
1 Points
I just bought this watch Nautica A31504 and it does not seem that any of the chrono buttons work. Is it the watch that is defective, or am I doing something wrong. In the manual, it says that I can...
The watch has been displayed for long time. You have to replace new battery for the watch and then those functions will work again. Good luck! :)
Feb 10, 2011 | Nautica A31504 Watch
I just got the watch as a gift on x-mas it stopped working yesretday while I was wearing it mens giovanni self winding I pushed the second hand button A and nothing I didn't drop it or get it wet or...
Having read the limited instructions for this watch, it does not seem as though there are many options available!
If you haven't already done so, try pressing A again.
If nothing happens, press B
It could be that the watch has simply stopped because it needs re-winding (it depends on how long it had been running when you got it.
To wind the watch swing it gently from side to side for a few minutes. ( some makers say swing it 200-300 times!).
If you still have no joy, then contact the makers help line; go to to find your nearest service center.
Jan 03, 2011 | Raymond Weil Don Giovanni Chronograph...
The watch stopped running. It is an automatic watch.
Automatic watches will stop running if not worn for a few days.
Did you leave the watch off for more than 2 -3 days?.
If you did, then it can be restarted by either winding it using the crown wheel (may not be possible) or by holding the watch level and swinging it gently from side to side for a few minutes. (There is a weight inside which rotates with the motion of the wearer to wind it up- so don't swing it very rapidly).
If this does not work, then it may be that you have to take it to a dealer to have it examined.
Oct 31, 2010 | Cartier Roadster W62016V3 Wrist Watch
Hi. my fossil automatic watch stopped working. any advice?
Have you left it off for a few days? If an automatic watch is not worn, it will stop after 2-3 days.
You can get it started again by gently swinging it from side to side for a few minutes. For continuous working it needs continuous wearing.
Oct 22, 2010 | Fossil Watches
Do Carrera automatic watch need a battery to run? because it stop me alot that why it just run for a few mins and stop forever until i move again
Automatic watches are mechanical (spring driven) and they are wound by the gentle swinging of the arm as you walk.
If yours has stopped, then it needs to re-wound by swinging it side to side (keeping the watch face level).
You will need to do this for some time (as many as 300 times, according to one maker).
When fully would the watch should run for about 3 days if not worn.
These watches thrive on use!
Apr 29, 2010 | Tag Heuer Carrera Automatic Chronograph...
Hi can you help me get the instructions manual
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all NAUTICA watch manuals.Rate me, please
Mar 15, 2010 | Nautica Windseeker N14505 Watch for Men
Where can I buy a new White Resin Nautica watch band for Nautica N14537 Wrist Watch. Armando Mendizabal
Jan 25, 2010 | Nautica N07574 Wrist Watch
Nautica watch
The waterproof seal is not woking, or one of the controls was used while the watch was wet, and water came in to the watch. If this is not serviced soon, there will be eventual damage to the movement of the watch.
Jerry G.
Sep 14, 2008 | Nautica N07574 Wrist Watch
Nautica N07574 Wrist Watch Logo
116 people viewed this question
Top Nautica Watches Experts
Arturs Kalnins
Arturs Kalnins
L Pfaff
L Pfaff
Are you a Nautica Watch Expert? Answer questions, earn points and help others
