Question about Compaq Armada M700 Notebook
My Compac Armada M700 does not power up.
When the power ON is keyed, the battery charging LED flashes (Even when not connected to mains power) and turns off after few seconds. I've checked the battery, it shows full charge. The laptop was working fine, and was switched off normally the last time. Removing the battery out and re-trying to switch-ON using mains power gives the same result. Request for urgent help and advice from all who have encountered a similar problem.
  • 4 more comments
  • icdat Nov 05, 2007
    battery light blinks.even when the power supply is plugged in.but wont power on i have tryed it with the bat in and out .but all i get is the bat light blinking.the bat is showing a full charge. could it be the charging circuite !
  • baldbear Dec 06, 2007
    I have the exact same problem, but I don't think it's the power plug because it won't work in the docking station either.
  • Anonymous Dec 16, 2007
    mine got same prob it was on before but now. i try everythin it wont switch on, no lights no signals jus wont go on :(
  • johnn635 Dec 20, 2007
    Have had this problem for 6 months. If you take out the battery and wait 24-48hrs, then plug in the mains adapter, it will start almost every time. Shutdown and try to restart, it will just flash the charge light 8 times. Wait another couple of days, its OK again. I have taken out the CMOS battery, has no effect ( apart from a CMOS checksum error). Put in a charged main battery after waiting 48hrs, it starts OK from the battery. Also, makes no difference if I use a Multibay battery.
    Rang HP to ask what 8 flashes meant and they couldn't ( wouldn't) tell me.
    Only clue I have is the possibility I used a replacement 4400mAh battery 6 months ago, and it may have confused the power board/charging system which is designed for the Compaq 3200/3600mAh.
    On other Compaqs, 8 flashes is a bad BIOS checksum, buit when I was able to start it, I reflashed the BIOS but it made no difference.
    Other people say they have changed the power board, which made no difference, although it would seem the most likely cause.
    Since it is only worth £100 or so, a repair is uneconomic. In fact, its worth more as a spare screen, keyboard, hard drive, battery and memory. Mad or what?
  • Anonymous Apr 27, 2008
  • darkangel75 Feb 24, 2009
    hi ..
    i have the same problem the laptop restart after a second ,and some times i can get to the starting (splashing win) the it shuts itself up straight away. the laptop is presario c300. i am just wondering is it posible the problem be on the circut (mob) or the battery?is it the battery's fault? i cant even use it with ac adaptor as well...
    any help or advice appreciated..
Had the same problem with My Compaq M700 No Boot Or Post. Battery Light Flashes 8 Times, Have to Wait 24 to 48 hrs sometimes longer to get Laptop to Start. Tryed the DC Converter Board Change No Difference same Problem. Noticed When Laptop Did Start Clock Time Was always a Little Off 2-4 Hours sometimes more. So Figure CMOS Problem With Time Issues. Read About Battery Memory Transitor Voltage spike Detection Issues Corrected With Newer Bios Flash at HP Supports. So I Flashed Bios With Latest 686h. During the First Boot After Reflash Battery LED Did flash No Start, After pushing the power button again it Started. And has Every since.So Far Laptop Now Boots Everytime and CMOS Checksum Seems To Keep Time Correct In Windows. The Bios Flash Corrects a Voltage Spike Detecting Transistor In The Charging Circuit. During First Start after flash Bios will run system test on the charging system and Correct CMOS. Worked for Me Hope this Helps a Few.
Posted on May 30, 2008
    Problem Solver:
  • 9 Answers
Hi Friends,
Compaq Presario PC Notebook's main problem's are Audio Driver, Software Installation etc..
For these problems you can visit a link by just Click Here .
For any other problems with this Notebook you can Click Here .
Posted on Jul 22, 2010
I have the same prob
Posted on Jun 10, 2008
Further to my post of December 20th. I bought a 'for spares M700' which had a working motherboard and display.
From this I was able to isolate the problem to the dc-dc converter board - a well knpwn weak point.
I have seen posts that say that replacing the dc-dc conveter board did not solve it. I can only think the replacement was faulty too.
Hope this helps a few people with the 8 flashes fault.
Posted on Jan 28, 2008
    Scholar:
  • 94 Answers
Replace the power plug. Often the solder joints become bad on these models.
Posted on Oct 30, 2006
Yellow led blink 8 times compaq m700
I'm not understanding what the problem is. If the battery is dead, and you remove it, how do you expect it to recharge? Why would you remove it? So, you take it out and nothing happens.So? What were you expecting to happen?
Before you do anything more, read the documentation that came with your laptop to learn how to care for your battery. The amber light usually blinks with the battery is running low. When you plug in the A/C adapter, the light usually becomes steady to indicate the battery is charging. At tleast until you remove it.
Hope this helps. Please rate this repsonse
Randy
Aug 31, 2012 | Compaq Armada M700 Notebook
I have a Compaq armada m700 and i dont know the power up password i put it in without realizing it
I'm copying someone else's answer; I can't vouch for it.
emove the main battery and mains power supply, hit the power switch to drain any retained charge. then remove the cmos battery and short out the contacts. the cmos battery is on the right under the panel at the top of the keyboard, which can be popped out by gently levering it up at the edges. the key board can then be folded clear, watch for the ribbon cable under it that connects to the motherboard.
Dec 14, 2008 | Compaq Armada M700 Notebook
Laptop only works with mains power supply connected
When you power your system up do you get a message saying battery charge failure or some other disappointing driver message? Try powering down, removing the battery, and look for a little button on the underneath of the battery. You should be able to press this button and a series of lights will or won't appear. If they light up it means the battery is truly charged. If not there is something wrong with the connection. Try wiping the surface off and replacing the battery. Also make sure the pin that you place into the laptop to charge the battery is free of dust, etc.
Aug 30, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700
Try this: Remove the power adapter and battery from the laptop.
Press and hold the power button for up to one minute to discharge the laptop. Try starting it.
Jun 02, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
Compaq Armada M700, Dim Screen
There is a dimmer function that is part of the keyboard on most notebooks. You use the Fn key and some other key (Mine is F1 and F1) Look for what looks like Sun in blue print on the key. You should find 2 of them. One will be the brightness up and the other brightness down. You can try those.
More likely, something has come loose internally.
1. It could be the backlight for the screen is broken or a connection loose. You should be able to see the light when you look at the side of the display.
2. The AC power connector may have been broken and the notebook is only on battery power. By default most systems are dimmer when on battery power. Check to see if your charge indicator light is on. If not, that may be the problem.
I hope this helps.
May 07, 2008 | Compaq Armada M700 Notebook
Battery for Compac Armada M700
Hello Felcen:
It could be just a coincidence...but lets try a few things...
Remove the battery and unplug from the wall. Hold the power button on...and then plug back into power...after 8 seconds release the power button. Once your computer boots to desktop...shut down...and replace the battery.
Changing the harddrive should have anything to do with teh battery...
See if your battery starts charging after this trick.
Let me know and good luck my friend.
Seek PC Repair
Feb 12, 2008 | Compaq Armada M700 Notebook
Loss of power
this is motherboard problem
Oct 23, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Shut Off During Windows XP Pro boot
remove the battery and directly connect to power and see.
Oct 09, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700
Always start with the simplest solution first so start by cleaning all the contacts, AC adapter laptop plug, laptop socket, laptop battery contacts and battery contacts. How have you confirmed power output from the AC adapter? have you used a voltmeter to ensure you are getting power at the laptop end? Have you used a voltmeter to test the battery? Assuming you have tried all this don't forget that almost any component can interrupt power on some laptops, however you're 2 main culprits with this kind of problem are usually power controller (voltage regulator) and in some cases, on a laptop of this vintage, the charge controller built in to the battery. Try it with a different battery if you have one.
Aug 10, 2007 | Compaq Armada M700 Notebook
Compaq armada m700 power failur...
try removing the large battery and powering off wall supply only...if ok, then replace battery
May 30, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
1,260 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
