Question about Archos Jukebox Recorder MP3 Player
Deleting files I am trying to delete files from my Jukebox Recorder to free up some space on the disk. I have deleted several large folders, and it isn't saying that I have any more space on the disk. This seems like it should be simple. Am I missing something?
If you've got it connected to your computer, you can do the same things that you would with any connected hard drive. In this case you should be able to delete files and then empty the recycle bin.
After that, go to My Computer and right click the icon for your Jukebox and select Properties. There you should be able to use Disk Cleanup to purge old system files, etc.
Posted on Nov 08, 2007
How to solve low disk space warning on my Windows 7 laptop?
It sounds like you have too much running in the start menu. If you go there you have to be careful what you stop from loading. Go to your start and left click. The search box at the bottom type msconfig Go to the startup tab. Anything like Adobe reader, Java, any toolbars, quicktime, realplayer or anything that doesn't need to start when you boot the computer uncheck the box on the left beside it. When you click apply and ok it will ask you to restart the computer. After you do a box will popup and you can check the box and click and you won't see it again. But like I said you can stop the wrong things there. If you don't feel comfortable trying it get someone you know who is tech savvy to help you. Anything Microsoft, Intel, or with your computer brand name needs to stay.
Dec 10, 2014 | Toshiba Computers & Internet
I ca not perform the delete deleted items action , not enough space in local disk?
Find some other files to delete or move onto a flash drive to make some room. Make sure your recycle bin is empty.
Jan 11, 2014 | Microsoft Office Professional 2007 Full...
I was trying to update my map on my nuvi 1350 and it said the internal memory was full. i tried to clear up some space and i ended up deleting some folders. I did back it all up, but now it won't let me...
The only files you should delete are unused voice files (.vpm), pictures files (.jpg), sum files (.sum) and you can delete the gupdate.gcd file as it is not used once the unit has been updated. You can also delete archived gpx files (.gpx) within the gpx archive folder but do not delete the current.gpx file (this file holds your favorites) or the gpx folder. Deleting folders is not recommended. That is a good way to delete files that you may need.
You can also right click on the Nuvi's drive letter and select "tools" and run an error check on the flash drive to make sure there aren't any errors on it that may involve how much space is really free.
Lastly, you may have to limit the map region, so that the map isn't too large. For example, instead of having US & Canada on the map, perhaps only have the US with the lower 49 states. You can limit it even further by selecting lower 49 states and selecting regions like Southwest (SW) or northwest (NW) etc.
f you really want to bypass the whole memory issue, just put the map on an external micro 4GB SD card. This way, you don't have to worry about deleting anything off of the flash drive.
I hope this info helps.
SHARCNET-USA
www.sharcnet-usa.com
Nov 30, 2013 | Garmin nuvi 1350 Car GPS Receiver
NEED TO KNOW HOW I CAN PREVENT BACKUP FILES FROM GOING INTO MY RECOVERY(D), AND FILLING IT UP. I AM RECEIVING MESSAGE THAT I HAVE LOW DISK SPACE IN RECOVERY DISK. HOW DO I FREE UP THIS SPACE, AND HOW
Are you sure the files are going in there? Many times the manufacturers only allocate the size that they need partitioned on that drive. I have seen many cases where that drive is full from factory and people always get that message.
  1. Click Start c01508537.gif and right-click Computer .
  2. Select Properties .
  3. Click System Protection from the left side of the Window.
  4. In the section "Automatic restore points", remove the selection next to the D: drive, and then click OK . If the D: drive was not selected, close this window. Figure 3: System Protection tab with D: drive unselected
  5. Right-click Start Explore All Users .
  6. Before you can remove the backup files and folders, you need to be able to view hidden system files as follows:
    1. From the explorer window press the Alt key on the keyboard to make the menu bar appear in the window.
    2. From the file menu, click Tools , and then select Folder Options .
    3. Select the View tab.
    4. Select Show hidden files and folders , remove the selection from Hide protected operating system files and then click OK .
  7. From the Folder Options window in explorer, double-click Recovery (D:) .
  8. If a Window opens stating "You don't currently have permission to access this folder" opens. Click Continue .
  9. If you previously copied or created any files into Recovery (D:) and you want to keep them, copy them to another drive - such as the C: drive.
  10. Find and delete any files that you previously copied onto the Recovery (D:) drive.
    CAUTION:Do not delete any files that are associated to recovery! Do not delete the items RECOVERY, $RECYCLE.BIN, boot, hp, PC-Doctor, pcdr, or PRELOAD! Doing so can prevent a future system recovery from the hard drive. If you are not sure, do not delete the file.
    Press Shift + Delete to permanently remove the files.
    To delete files created from MS Backup (MS Backup files are not recovery files), find and delete the folder with the same name as the computer name in the Recovery (D:) partition. For example if the computer name is BOB-PC, the folder containing the backup files would be named BOB-PC and would be deleted.
  11. Several confirmation windows open. Click Continue , and Yes until the folder is deleted.
  12. To set Windows Folder Options back to their original setting as follows:
    1. From the explorer window press Alt to view the file menu.
    2. Click Tools , and then select Folder Options .
    3. Select do not show hidden files and folders and select Hide protected operating system files .
    4. Click OK .
  13. Close explorer. The Out of Disk Space errors should no longer appear. If you would like to use the Microsoft Backup Tool again, open it and select a different external backup device to store the backup files on.
Aug 17, 2012 | HEWLETT-PACKARD Computers & Internet
Hard drive space is being taken by unknown entity. HP mini 1000. Have read every blog. I cannot find what is taking my space and i want to remove it!
How do you know something is taking up space on your hard drive? What is your operating system? First thing you should do is check your waste basket. Is it full? Then check your cookies and temporary internet files. Delete all you do not need. Then if you go to your Windows Explorer, you can check the size of each file on you hard drive. Go to Local Disk C:. Open all folders by clicking on each + sign to the left of each folder. Then start at the top and work your way down checking each folder. You should see a folder that has a lot of files in it, or one large file, maybe a folder you do not recognize. Click on and delete the folder that is taking up to much space. If you delete any folders do not empty you waste basket until you are sure you did not delete anything you will need.
May 27, 2011 | Computers & Internet
Currently my 500 GB WD External Drive has 353GB as free space. But when I try and add a 6GB file I get the following message "Error Copying File or Folder Cannot copy filename: There is not enough free...
How many directory deep is the file going that you are trying to save? I believe the maximum NTFS file (location + name) of file length can not exceed 256 characters total.
Example: C:\user\documents\file.exe is OK
But: C:\user\documents\folder\folder\folder\folder\folder\this folder name 230 charicters long\file.exe BAD
Feb 05, 2010 | Western Digital My Book Essential Edition...
Deleting files does not free up disk space
Note that "deleted" items move from their location into the "Recycle Bin".
So, "empty" the Recycle Bin, in order to reclaim the space.
Or, when deleting:
1. click ONCE to select a file/folder to be deleted
2. hold the SHIFT key down
3. click the DELETE key
4. release the SHIFT key
This will "permanently" delete the file/folder, immediately freeing-up the disk-space.
Oct 27, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cannot delete files from D drive
Try deleting the files inside the folder first
If not
Copy some of the files off the drive onto a DVD or two that will make working space on your hard drive
Jun 25, 2009 | HP Pavilion DV2740SE Laptop
Not enough free space
sounds like you are connecting your Archos to either a Mac or a Linux box. When you place items in trash they're actually placed in a hidden .trash folder on the Archos's internal drive and so still take up space.
Start by reconnecting the device to your computer and when it appears on your desktop try emptying your trash can/recycle bin, this will empty all .trash folders including the one on the Archos.
If you're using a Mac you may also want to use a 'clean eject' app such as FinderCleaner to remove all the Apple system files from your Archos. Don't worry the only effect this has is to slow reconnection down by 1 or 2 seconds but it helps prevent problems like this and prevent the device from getting confused by Apple system files.
May 08, 2008 | Archos Jukebox Recorder MP3 Player
Sonic dvd writer for photo story
if you are using xp, you can save your files to all users shared documents folder ,here you can create a folder that everybody can open it.
Oct 30, 2007 | Computers & Internet
Archos Jukebox Recorder MP3 Player Logo
69 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
