Question about RCA RS2020 CD Shelf System
CD door won't stay closed
When I press the CD door to close, the clip does not grip the peg on the CD door. I don't know if a spring is broken or a tab is broken inside of the switch that should grip the peg on the CD door.
SOURCE: RCA RS2046 CD won't play
This is what I found: It worked for me.
You can try to reset the unit using the procedure below: Let the unit sit with the AC power cord out of the wall for a couple of hours. Then hit the power button 10-15 times (with the AC power cord still out of the wall socket!) and then try again. If you continue to have problems unfortunately it sounds as though it is within the electrical assembly. It is hard to say exactly what caused it or exactly what the problem with the circuits are without having a technician look at it. If the place of purchase can not simply exchange the product you can email me your...........
Full Name:
Full Address......................(no P.O. Box addresses, as UPS will not take them)
Zip Code:
E-Mail Address:
Date of Purchase:
Problem with machine: ....and I can send you the address to ship the unit in for repairs. Without ALL the information, I cannot issue an RA#. I will also need to know the date of purchase of the unit and whether there is a receipt for the purchase. Repair Policy The warranty is 1 year from the date of purchase. You will simply need to include a copy of any type proof of purchase you may have. Be sure to double check that all you information is included so I can get you the return authorization number and address A.S.A.P. The non-warranty cost of repair depends on the model number. You may send the machine to us by whatever method you prefer, but you are responsible for the cost of sending the unit to us. We recommend that the unit be shipped to us insured and that a signature be required when we receive it. Repairs generally take 4-6 weeks. Your unit will be returned to you at no charge to you via UPS. Repair Fee: The none warranty repair charge will depend on the model number. The repair fee for your model is $40.00. Regards,
Posted on Jan 12, 2009
0 characters
1 Points
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ... > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer ยท CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Shelf Systems
unfortunatly the mechanism is jammed up for one reason or the other reason #1 a cd is stuck inside #2 the gear just wore out and or it was forced closed by hand instead of pushing the eject/load can try to gently pry this door open while pressing open/eject button that works 40% of the time..if it does not work? it can then be deemed broken out of order.
it's worth a shot trying to pry it open but beware this could either work or really destroy the door/mech/player comes down to this "do you feel lucky" sadly? that's where we're at with this one.
Mar 20, 2014 | Electro Brand Nostalgic Stereo CD Music...
Cd door wont shut
this is possible but can lead to more frustration. The cd door usually has a plastic tab that depresses on a button or blocks the opto sensor to indicate it is closed. I presume that your cd door is missing this tab or the circuit that activates when the door is closed is faulty. Block the opto sensor manually using paper or keep the button depressed that the door tabe closes on. You will not need anything to keep door closed unless it is reqiured to play the cd then just use a brick
Aug 15, 2009 | GPX Karaoke Party Machine CD+G Portable...
The CD Tray won't open on my Sony MHC-GX250
te same thing happened to me know i juat turn the stereo off to where the red light is blinking then turn it back on after the standby message disappears and then i quickly pree the eject it! and let me know!
Jun 24, 2009 | Sony MHC-GX450 CD Shelf System
Cd tray not staying closed
gently push the cd door back in while pushing the door closed button , untill it closes if it still comes out then the cd laser mechanism is not lifting or something else has happened , then it will need to be tested to determine the exact cause
Oct 16, 2008 | Memorex MKS5001 Shelf System
Lid Closure
OK - There is nothing that drives the door to close and stay closed. There is a little plastic gismo the locks onto a little protruding tongue in the lid keeping it closed. To release the lid, you must press the lid foreward so that it releases the lock in the little plastic gismo. I found this out only after removing the board above the main deck of the player and which, fumble-fingers me, I managed to damage the board and will have to replace it along with the little plastic gismo that holds the door closed. I am not sure if either of these parts are available as I have had the unit for quite a while. This leaves me in a quandry as I really did like the little player. It was a dandy. So, if you ever get an inquiry on how to keep the lid closed on a JMC_800, tell them to replace the little plastic gismo and that will do it.
Aug 29, 2008 | Jensen JMC-800 CD Shelf System
CD player cover/door won't stay closed
The intermittent version of this seems to be related to the cable that goes to the subwoofer portion. Have seen this behavior when the cable got loose. Unfortunately, I believe that this behavior may get worse in the long run and cause CDs to not play at all.
Jan 25, 2008 | Teac CD-X8 CD Shelf System
Cd door won't open
you must turn it to cd mode and then try to open the dorr
Dec 08, 2007 | GPX HM3817DT Shelf System
Bang and Olufsen Beosound 4000
Sounds like the belt drive that controls the doors is broken. If you're a repair headed person, you can get the repair manual online for $25 or so. Parts may be harder to get, but with the proper imformation, you may be able to do the work yourself.  It's both tricky and super easy because the design is generally very very good, but knowing the technical details requires a decent amount of patient brain work and proper tools.  DaveA
Dec 02, 2007 | Bang and Olufsen Beosound 4000 Shelf...
CD Lid/door catch broken, will not stay closed
Chris, I know it has been a while since you posted this and I don't know if you ever solved your problem but if might want to check out this sight.
Mar 26, 2007 | Cambridge Soundworks C1MUSWKE CD Shelf...
RCA RS2020 CD Shelf System Logo
Top RCA Audio Shelf Systems Experts
Jaime Hernandez
Are you a RCA Audio Shelf System Expert? Answer questions, earn points and help others
