Question about Aiwa AV-D58 Receiver
In Aiwa AV-D58 5.1 can't turn on [ it only ECO ]
Now I can't Turn on , but idcator display LEd on ECO
  • Anonymous Mar 05, 2008
    When i tried 2 turn it on nothing come up but the ECO light blinking can somebody help me with that please.
  • Mat Regelsberger Mar 08, 2008
    My Aiwa AV-D58 does not turn on. LED is on ECO. Aven with power removed or 5-10 min, no change in response.
When turning it on hold the enter key at the same time to reset the machine back to the factory settings
Posted on May 18, 2007
How do I turn on eco mode for toyota camry 2012 hv ?
Check your fuses in the fuses, box especially the relay.
Jan 22, 2015 | 2012 Toyota Camry
LED display has gone dark
Check if the display you this coming cathode voltage, which is 5VAC, chances are that there is this voltage, follows the line of this voltage, possibly find some open fuse. luck.
Oct 12, 2013 | Aiwa AV-X120
Fisher and Paykel Intuitive Eco led lights are flashing by chance the start screen might come up when i start the cycle the water runs into machine for about 3 seconds then it shuts of and the bowl st
The display screen clicks in.
Use a flat blade screwdriver to unclip the display.
Two low profile electrolytic capacitors need to be replaced,
Is a common problem in IW LCD display boards.
Mar 13, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
I have an AV-S17 and it's stuck on eco mode. I have tried doing what the form has said for me to do and it doesn't help.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-AV-S17-Receivers-manual/id/1076ag804/t/2/
Page 7:
To cancel the ECO mode
1 Press the ECO button to display ECO MODE while the unit is turned on.
2 Within 4 seconds, press the ENTER button.
3 Within 4 seconds, turn the MULTI JOG to select ECO OFF.
The mode will be automatically set after 4 seconds. It will also be set if the ENTER button is pressed within 4 seconds after step 3.
Mar 29, 2011 | Aiwa AV-S17 Receiver
My Aiwa NSX 990 wont come on. Only timer icon come in display and volumew LED keeps coming on and going off at regular intervals
Unplug the power cable completely to turn off and then turn back on again. Check whether there are no lose parts with missing contact.
Most probably it looks like a deeply digital problem with no do it yourself solutions - bring it to the repairman, but I even doubt he would fix it.
You can also download the Aiwa NSX-990 service manual and analyze more specifically your case. Download it from here: http://www.mediafire.com/?jc0ynzoiama or from here: http://www.4shared.com/document/rQ67hcpG/Aiwa_XG-990-NSX-990-NSX-992.html (click "Download Now", not any other button).
Dec 06, 2010 | Aiwa AV-S17 Receiver
Have a new GE Profile dishwasher. The LED time display started at 62 the first time we used the machine. It keeps going up and is now at 108. Is it broken and how do we reset the time back to something...
Have you tried to turn the mains power to dishwasher off and back on again.
It also possible the inlet water temperature is not at the recommended temperature so it is compensating for heating it to the desired temperature. Please check if your installation guide says you use cold water inlet or hot water inlet.
Try running on one of the eco cycles first to see if the heater is the cause. Eco cycles use lower temperature inlet water.
Dec 03, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
Dishwasher fdb4315lfc stuck with eco wash led and a pump running
Sounds like the Anti-flood switch has been triggered - possibly due to overfilling. Check seal of water level pipe at each end.
Feb 28, 2010 | Washing Machines
Aiwa AV-D58 Receiver Logo
1,526 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
